Question about Seba Skates GT 90 - Size 10
The lever clasp on my Seba gt skates tightens but won't release. Could someone tell me how to release this clasp - across the instep with a metal lever
Tour trek pushcart replacement parts
Fixya does not sell replacement clasps.
Jul 26, 2017 | Cars & Trucks
My Nokia c3 won't turn on
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Aug 27, 2012 | Nokia C3 Cell Phone
How do i loosen the second strap!?
You have to pull the metal tab back all the way. It will click and lay flat, but you have to keep it pressed down for it has a tendency to snap shut). There are two ratchet stop check levers (black plastic pieces on the side of the strap). The way they look it would seem that you would have to squeeze them together, toward the strap, but you have to push them down towards the boot. Remember to keep the metal tab depressed so it doesn't snap shut on you. Once you push both levers down and clear the bevels on the strap, you can pull the strap back out. Open and close the strap a few times to get the "new" out of it. With more use, you will be able to squeeze the levers together (like you couldn't do the first time) and depress the levers in one motion making the taking off of your skate a lot easier. Hope this helped.
Sep 10, 2010 | Roller Derby Mens Spartan 9.9 InLine...
The front wheel of our instep safari double wobbles like crazy. Took it to a bike repair store and they couldn't fix it.
I had the same problem with front wheel wobble, the fix for me was easy. I removed the four screws holding the foot rest in place and tightened the bolt holding the front wheel on, to tight and the wheel won't turn so leave the foot rest off and try it out until you get the the right amount of tension.
Aug 22, 2010 | InSTEP Safari TT Double AR265 Jogger
How do you loosen the second strap of a men's roller derby spartan 9.9 skate?
Aug 16, 2010 | Roller Derby Mens Spartan 9.9 InLine...
How to loosen strap of roller derby's spartan 9.9 rollerblade. I can open the first strap but can't undo the second strap. I can only make it tighter.
You have to pull the metal tab back all the way. It will click and lay flat, but you have to keep it pressed down for it has a tendency to snap shut. There are two ratchet stop check levers (black plastic pieces on the side of the strap). The way they look it would seem that you would have to squeeze them together, toward the strap, but you have to push them down towards the boot. Remember to keep the metal tab depressed so it doesn't snap shut on you. Once you push both levers down and clear the bevels on the strap, you can pull the strap back out. Open and close the strap a few times to get the "new" out of it. With more use, you will be able to squeeze the levers together (like you couldn't do the first time) and depress the levers in one motion making the taking off of your skate a lot easier. Hope this helped.
Apr 01, 2010 | Roller Derby Mens Spartan 9.9 InLine...
How do you remove the pin out of Starck and Fossil PH1100 watch?
Ok, so if you are like me then you probably thought removing the three tiny screws from either side of the strap, and cutting segments of the strap and re-screwing the clasps back was going to do it. Unfortunately one realises that the clasps do not slacken to let the rubber straps out even after the screws are off. The critical point is to get the side pins out which is no simple feat. Getting the pins out releases the clasps and the rubber strap.
To get the pins out, use a wire cutter to cut down a paper clip to a length of 1 .5 cms or so. Hold this with a pair of tweezers along the axis of the pins while you hammer down in the direction of the small arrow inscribed on the metal clasp. With persistence a part of the pin comes out from the other end and you can then pull it out completely with a pair of pliers.
Removing the two pins with release the ends of the rubber straps. cut away segments as required while trying on so that you dont cut too many. Make sure you cut the same number of segments on each side. I had to cut three from each side since I have very thin wrists.
Now put the rubber strap back hold the clasps in position and push the pin back in place. Put the screws back and you should be in business.
It sounds complicated but is quite simple if someone shows you how....which I hope I have been able to.
Sudipto, India
Sep 09, 2009 | Watches
Hood on my 1999 Ford Mustang Gt Will not release and my Battery is dead.
try to have someone outside of that car and push down and pull up on the hood as you pull the lever..if the lever is broken off u can use a pair of pliers to pull the wires that pop the hood..you might have to strip off some of the black insulation good luck
Oct 28, 2008 | 2002 Ford Mustang
Cant fold my instep safari tt stroller
One-hand fold is not as quick and easy as it's name suggests. This model requires reclining seat all the way first, then step on the safety release lever (about shin-high) located above one of the rear wheel axles. While holding down safety release lever with your foot, then squeeze the one hand fold mechanism located near the parent console and the stroller will collapse. There is a lock bar/plate to hold stroller in place. It will not stand on its own in this position, but with the foot brake activated, will lean against something and stay in place.
Oct 11, 2008 | InSTEP Safari TT Single AR165 Jogger
Seba Skates GT 90 - Size 10 Logo
166 people viewed this question
Top Seba Skates Sport & Outdoor - Others Experts
Are you a Seba Skates Sport and Outdoor - Other Expert? Answer questions, earn points and help others
