Question about Stoves Ovens
Need info on usage of stoves double oven model no 058588056
  • Stoves Master
  • 17,115 Answers
What make is it?
Posted on Oct 14, 2013
5 Suggested Answers
  • 250 Answers
SOURCE: where can i get a operators manual for a stoves
If STOVES are not able to help at all, then ask them what the model number is. With that information you may be able to locate a handbook.
Posted on Feb 04, 2010
SOURCE: need to adjust clock setting
Press + and - at the same time (manual says hold for 3? seconds) and then + or - to set the time. If from power up, as I did yesterday, I don't think you need to hold them together for any length of time, but maybe it was my imagination, since I tried it first before I read the manual.
Posted on Nov 19, 2010
blackmar
  • 235 Answers
SOURCE: Double wall oven: Model JKP26GOP13G. The upper
I trust the door is sealed correctly. If heat is escaping this could be the problem. If the seal is okay the only thing it could be is the oven thermostat controller. It sounds like it is faulty and needs replacing.
Posted on Feb 13, 2011
SOURCE: Hi I urgently need a
Hi Malcolm, any chance you still have the pdf manual? If you could email it to me that would really handy.
Thanks Tom
Tom8pearce@gmail.com
Posted on Nov 30, 2012
How to set timer on stoves e2h600 double oven model no. 059041910
Please email manual of e2h600 to miraimx@gmail.com. Much appreciated!
Jan 08, 2013 | Stoves Premier 900GRa Gas Double Oven
I HAVE BOUGHT A SECOND HAND STOVE ELECTRIC OVEN MODEL NO. 720EF . CAN I GET A OPERATION HAND BOOK
STOVES don't have any and from past experience are reluctant to help. I now have a copy in .pdf format for anyone who wants it. All I need is an email address to send it to you.
Nov 22, 2010 | Stoves 720EF Electric Double Oven
I have a Stoves 720 ef cooker model no 059040415. The main oven door hinges need replacing but I can not find a replacement set for this model anywhere. Can anyone help? ...
Try espares. If the part is not listed, there is a contact on the website to obtain a quote for a part. Of course once you have the part number you can try elsewhere.
Nov 13, 2010 | Stoves 720EF Electric Double Oven
I have a Stoves double oven and after a power cut the clock has stopped working and the main oven is not working either. the clock is completely off. the small top oven is still working though. what can...
The clock controls the ovens. In other words, directly you set any time on the clock, a contact operates within it to provide power to the ovens. (Normally the grill remains operational). You may need a new clock/timer. Before you do so, try switching the power off at the main isolating switch and leaving it off for a few mins, then switching it back on, to try to get the clock to operate. You may need to do this a few times.
Normally Stoves stick a label identifying the model on the left hand edge of the lower oven. You see this when you lower the main oven door. it will probably start with a 05 and be 9 digits long. With this number you can identify the oven and obtain parts.
Nov 07, 2010 | Stoves 720EF Electric Double Oven
I have a Stoves double oven, but do not know how to use the automatic timer. Can anyone help?
I have posted this a number of times. Please look at other answers to obtain the info.
Oct 31, 2010 | Stoves 720EF Electric Double Oven
I have just got a new stoves cooker and i need the manual for it, the model number has worn away a bit but from what i can see this is the model number 039850512
If you contact STOVES with that number, they should be able to help you. If you want a copy of my 720EF manual, supply an email address and you can gave a copy.
Nov 01, 2009 | Stoves 720EF Electric Double Oven
Where can i get a operators manual for a stoves double oven model number 059043562
Oct 27, 2009 | Stoves 720EF Electric Double Oven
Schematic wiring diagram
I have a copy of a STOVES 720EF Manual (including wiring info) posted on BT Digital Vault. Supply an email address and I will give you access to take a copy.
parsonm
Oct 30, 2008 | Stoves 720EF Electric Double Oven
Open Questions:
Faulty obsolete (20yr old) oven thermostat with separate fan/light switch. Can't find a 'universal' replacement. If I fit a standard 2 tab thermostat, the fan and light will switch with the element Stoves oven DF550 SI with a 46thc502/G5 thermostat which controls well (if 40C higher relative to the oven thermometer). However after an overnight cool down the oven element switches on when the mains is turned back on, even though the oven control is off. I just twiddle the oven thermostat control slightly and all is well. I can't find a 250C, 1m phile, 24mmx6mm spindle thermostat with a separate connection tab for the internal recirculating fan and oven light anywhere. Otherwise the single oven cooker works and looks like new (nearly). I was wondering whether I have to piggy back a switch on the back of a standard 2 tab thermostat (or vica versa) or attach a separate switch to the oven. Can't believe I'm the only one with this problem. I'm guessing some fragile electrical contact occurs in the thermostat on cooldown to turn on the element and its in-series lamp, and this contact easily breaks by slightly turning the thermostat. ps there is no timer and I do have the circuit diagram. I found a working solution to this problem: When turning off the oven, I don't take it to the end stop. I turn it passed the click when the element and indicator turn off, then further till the ligth and fan turn off and just a fraction further but not to the end stop. Now the oven element doesnt turn on each time I turn the mains on for some other reason ( eg grill or igniters). I guess there is something wrong inside the thermostat, but this work arround seems OK if not ideal. I've marked a new stop position around the oven dial to remind me. This was easier than making a physical stop for the oven dial.
Feb 24, 2018 | Stoves Ovens
Ovens Logo
42 people viewed this question
Top Stoves Ovens Experts
ashburton
Dan Webster
Dan Webster
Are you a Stoves Oven Expert? Answer questions, earn points and help others
