Question about Olympia OL6010 (olyol6010) Audio Conference
Olympia OL6010 The conference unit speakers and microphones no longer work. Calls can be made and received but without sound.
Uniden turn off vox
Hi Jon,
The problem is easy to solve, so here goes:
vox indicates that your unit is set to work via the microphone(if you have one), and is activated when you start to speak, (hence vox=voice activated microphone), if you don't have the microphone that came with the unit, you will need to buy/borrow one and connect it to the unit, before you can turn off vox, so that the unit can work with or without the microphone(vox will no longer show), once you have done this.
I hope this helps.
Cheers,
Peter
Feb 22, 2013 | Uniden Radio Communications
(1) Is it possible to have a bi-amp hookup to speakers that has twin wire lugs when playing just two front speakers, and how is it done ?. (2) can a regular microphone work in the microphone jack to...
1) Not with this unit. WHY bother? Sending identical program to two drivers over separate wires is the same as sending it over one pair.
2) No. Insertion of a microphone tells the unit you're doing setup. The microphone picks it up and sends it to a microprocessor for evaluation. The sound from the mic never finds its way out to a speaker. THAT would be a feedback loop and the tweeters wouldn't like it. (sizzle sizzle)
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Harman-Kardon-AVR-435-Receivers-manual/id/386bh037/t/2/
Apr 07, 2011 | Harman Kardon AVR 435 Receiver
How do I start a conference call on a Mitel 5303 Conference Phone? It states it only hosts up to 8-10 people.
I'm assuming you are using this on a 3300 ICP. In that case, the phone system is only able to do 8 party conference calls without an external Conference server.
You can dial the first number, press the flash button, dial the next number, dial the feature code (get from your vendor), repeat until you have all parties as part of the call.
The 5310 IP conference unit works much easier than this phone. A conference bridge such as Audio Web Conference with the appropriate licensing will allow for extended conference calls... it will also allow you to record the call for later "off-air" participation.
Sep 23, 2010 | Mitel 5303 Conference (50001905)
How do I put my Mitel Superset 4015 on speaker phone during a call?
Sorry to tell you, but the Superset 4015 is not capable of doing this conference feature.
It has loud speaker capabililties (for paging, or listening to calls), but no microphone for your conference meeting.
Apr 10, 2009 | Mitel Superset 4015 Corded Phone
Polycom sound station 2 conference set conference problem
sounds strange, it lookslike a main board problem, considering that u have been using similar unit before.there is not much that u can do from the menu options.u will have to refer ur vendor for rpairs
Jan 15, 2009 | Polycom SoundStation 2W (2200-07800-001)...
Microphone hissing sound
That sounds alot like the microphone booster in control panel. Depending on what version of windows your are using, you can just open the sound control from the taskbar and go to the advanced settings and uncheck the setting "microphone booster". Adjust microhpone volume accordingly.
Dec 31, 2008 | Yamaha WaveForce 192XG Sound Card
The unit will power down during conference by it self.
Which exact unit ? This is a known problem with orignal 'Spider' PSUs for the Viewtation range (reboot issue).
Sep 30, 2008 | Polycom ViewStation ISDN (pcy220011323001)...
Phone calls drop after an hour
try in radio shack -take it and go there and ask for a new compitable one(it does not matter if more in amp)-same voltage-same dimenshion are important
Jul 22, 2008 | Olympia OL6010 (olyol6010) Audio...
No dial tone
please go to line outlet of phone in wall and connect any phone if you get duial tone-check you cable to machine-and then repeat your setup.
Apr 01, 2008 | Olympia OL6010 (olyol6010) Audio...
Olympia OL6010 (olyol6010) Audio Conference Logo
Top Olympia Lands Phones Experts
ray gallant
ray gallant
Jose Ma DM.
Jose Ma DM.
Tom Chichester
Are you an Olympia Lands Phone Expert? Answer questions, earn points and help others
