Question about Sport & Outdoor - Others
I have some Seba GT skates. The lever clasp over the instep tightens but won't release. Can someone tell me how to get this clasp to release?
2 Suggested Answers
  • 1243 Answers
SOURCE: shift lever lock won't release when brake pedal is
do the brake lights work? most of the time the problem is a broken wire at the brake light switch under the dash on the brake pedal. the ECM does not see the signal from the switch so it won't allow the car to shift from park.
Posted on Jul 19, 2011
My Nokia c3 won't turn on
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Aug 27, 2012 | Nokia C3 Cell Phone
Parking brake won;t release
if it willnot release, then most likely one of two things has happened.
1. The release inside the vehicle has broken away from the the actual cable,
2. The cable it self is frozen.
Either way, you will need to get under the vehicle to see what happens when some one inside the vehicle is trying the release.
Does the brake light stay on, indicating that the brake is on?
Dec 07, 2010 | 2000 Dodge Grand Caravan
The front wheel of our instep safari double wobbles like crazy. Took it to a bike repair store and they couldn't fix it.
I had the same problem with front wheel wobble, the fix for me was easy. I removed the four screws holding the foot rest in place and tightened the bolt holding the front wheel on, to tight and the wheel won't turn so leave the foot rest off and try it out until you get the the right amount of tension.
Aug 22, 2010 | InSTEP Safari TT Double AR265 Jogger
Opened hood now it won`t close
this is common it needs to be lubed, you will have to spray it good with wd40, then locate the release arm that the cable pulls to release the hood,push the arm back, have someone inside to pull the hood release lever,do this a few times and respray it until its free, here a picture of the latch, i put an arrow pointing at the lever to push back and free. hope this helps you.0429669.jpg
Mar 01, 2010 | 1999 Ford Expedition
Hood on my 1999 Ford Mustang Gt Will not release and my Battery is dead.
try to have someone outside of that car and push down and pull up on the hood as you pull the lever..if the lever is broken off u can use a pair of pliers to pull the wires that pop the hood..you might have to strip off some of the black insulation good luck
Oct 28, 2008 | 2002 Ford Mustang
Cant fold my instep safari tt stroller
One-hand fold is not as quick and easy as it's name suggests. This model requires reclining seat all the way first, then step on the safety release lever (about shin-high) located above one of the rear wheel axles. While holding down safety release lever with your foot, then squeeze the one hand fold mechanism located near the parent console and the stroller will collapse. There is a lock bar/plate to hold stroller in place. It will not stand on its own in this position, but with the foot brake activated, will lean against something and stay in place.
Oct 11, 2008 | InSTEP Safari TT Single AR165 Jogger
Hood release lever
usually just a cable that needs tightened.. look for screw attached to cable near the latch thats on the hood use a screwdriver to tighten. worked for me ;) goodluck
Jun 29, 2008 | 1999 Dodge Intrepid
Sport & Outdoor - Others Logo
279 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
