Question about Alpine Natural Air 3000 Air Purifier
How do you clean the fan blades? - Alpine Natural Air 3000 Air Purifier
    Scholar:
  • 111 Answers
If it is not easily accessible, Id recommending taking it outside and blow it out with a air compresser that has a blow spout attachement on it, if that is not available, most towns have tire changing companies that sell used ties, most of these places would be willing to blow it out for you for a few dollars im sure, sometimes thinking outside the box can save you some money on the long run.
Hope this helps.
Posted on Oct 17, 2013
Need to replace fan blade. doi just the other blade off or do i need a tool
You should be able to get the fan off w/ a small screwdriver & some needle nose pliers for the metal clamp that holds the fan onto the shaft. Look on Google for suppliers to get a new fan & clamp. It shouldn't be expensive.
Apr 04, 2014 | Ecoquest Breeze AT Living Air Purifier
Holmes blizzard table fan
take it to your nearest gas station and get the air hose and spray it with the air then take some w-d 40 and with the long red tube attachment that comes with it spray it in the middle moving parts of the fan.the air from the air hose might turn the blades so stick a pencil or something in there first to keep blades from rotating then spray the dust off the blades with the airhose
Jun 16, 2013 | Holmes HAOF90UC Blizzard 8" Three-Speed...
Fan noise ecoquest 2.1
sounds like the bearings are going bad on the motor check and make sure the fan blades aren't rubbing anything at higher speeds sometime's they will flex
Jul 04, 2012 | Ecoquest Fresh Air Air Purifier
How to Clean electric motor in air purifier
replce the mtors as there is nothing in them to clean
May 23, 2017 | Air Purifiers
I cleaned my Flair air purifier, The motor turns on but not the fan even after lubricating the fan shaft and giving the fan blades a little push. Any suggestions on how to get this going?
The Flair is no longer manufactured nor serviced by EcoQuest, and the company is now Vollara. If what you're hearing is the fan motor (there is no other motor associated with this machine), it might mean that either it's totally seized up, or that the oil just has not penetrated deeply enough.
1) Turn the machine over and remove the large screw in the bottom. The chassis will then slide out (I assume you've already done this in order to reach the fan shaft.)
2) Firmly pull on the fan blades near the center in order to pull them free of the shaft.
3) Turn the chassis on its back, so the fan shaft points up. Drip a small amount of lightweight oil (sewing machine, hair clipper, 3-in-1) on the shaft and turn it manually to work the oil down the shaft. Continue doing this if you feel the shaft loosening up.
4) Set the chassis upright, tilt it forward, and drip a small amount of oil on the rear opening to the fan shaft. Continue manually turning the shaft and tilting the machine to work the oil in.
5) Replace the fan blades and turn on the machine, depressing the safety switch manually, to see if the fan will begin to turn.
If it won't turn, it might mean that the fan motor is entirely seized up. You may be able to find a local small appliance repair person who could replace that motor.
Your other option is to call Vollara customer service at 800-989-2299 and ask them to explain your options. Use #16618 if you need a dealer referral number.
Feb 11, 2011 | Ecoquest Flair Air Purifier
Do I need a new fan blade if I replace the fan or will the old one go back on fairly easy? Ecoquest fresh air
If you need to replace the fan motor, the fan blade can be removed by grasphing the center hub of the fan and pull the fan straight out of the purifier. I remove it every time I clean my machine, since it easy to clean it once it is removed.
Nov 21, 2009 | Ecoquest Fresh Air Air Purifier
Makes a funny sound when turned on
Something is touching the fan blades.
Apr 18, 2009 | Ecoquest Flair Air Purifier
Fan blade broke
Remove the 4 screws on the front grill. Grasp the fan with both hands and pull the fan off. Kind of prying it out using your hands as levers works best. It may be stuck if you have never removed it for cleaning, which you should do, periodically. The new one slides on flush with the end of the shaft.
Mar 30, 2009 | Ecoquest Breeze AT Living Air Purifier
Honeywell HFD 135 FAN BLADES DIRTY
I used a can of compressed air to clean my fan blades and this did the job. I bought a 6-pack of 3M Dust Remover at Sams Club to save money. Hope this helps.
George
Dec 18, 2007 | Kaz Honeywell QuietClean HFD-135 Air...
Alpine Natural Air 3000 Air Purifier Logo
Top Alpine Air Purifiers Experts
Are you an Alpine Air Purifier Expert? Answer questions, earn points and help others
