Question about Lincoln Industrial 82730 POWER MASTER 4 PUMP AIRMOTOR - 20% Off
Would like a manual for this pump - Lincoln Industrial 82730 POWER MASTER 4 PUMP AIRMOTOR - 20% Off
I need a shop manual
Shop Manual...???
Like a generic repair manual, with instructional step-by-step repair instructions for all types of swimming pool pumps and motors? That's usually what a shop manual refers to...? Or are you looking for a specific owners manual for a specific pump?
if so, then we need a make and model of your swimming pool pump.
Apr 21, 2015 | Pool & Spa
Which brand chainsaws have manual oil pump
None use a manual oil pump anymore. Automatic oiling is the way to go.
Dec 26, 2009 | McCulloch Garden
Need a manual for a salt water pump
What brand of pump do you have with the pool? It should have a manufacturer name, or model number, located somewhere on the pump. Look for a sticker on the pump basket area or motor. You will be looking for the pool company/pump maker name, NOT the manufacturer of the motor.
Many pool equipment companies do not make the motors that go on the pump. AO Smith and Centurion are common motor manufacturers. Once you find out the name, or model of the pump, many companies have Owner's Manuals online. For Sta-Rite and Pentair Owner's Manuals, follow the link below:
http://www.pentairpool.com/techinfo/datasheets2.php?d=2
If you still can not find an Owner's Manual online, then you need to call the company and see if they will send one out to you. If you need more assistance, just let me know and I will help you look for one.
Jul 01, 2009 | Intex Automatic Salt Water System for ...
I have a 89saab. I have no power to the fuel pump?
Check fuse 22 (10 A - 1989 to 93) it's the fuel system, and fuse 30 (20 A) it's for the fuel pump; there is a relay located behind right side trim panel in front of passenger foot well.
To test the relay, remove it and jumper between sockets 30 and 87b (middle and bottom); if the pump runs, the pump is OK and the relay suspect. If the pump doesn't run, then a circuit is suspect, eg power from relay to pump, or power from battery to relay, or a ground connection. To check these you'll need a wiring diagram - get the "Bentley Bible" - aka the Saab 900 Official Service Manual, costs about $40 from Amazon!
16 valve manual: http://www.amazon.com/Saab-900-Valve-Service-Manual/dp/0837603137
8 valve manual :http://www.amazon.com/Eight-Official-Service-Manual-1981-1988/dp/0837603102
get the appropriate manual for your car and enjoy the Saab!
Most likely it's the relay.
Possible other causes are:
blocked fuel filter - under right rear, in front of gas tank (fuel spills are dangerous - don't smoke, etc!);
broken wire connection to pump - check continuity between fuse 30 and pump connection;
dead pump - you could provide power to the pump to check if it runs;
Apr 21, 2009 | 1988 Saab 900
Lincoln Industrial 82730 POWER MASTER 4 PUMP AIRMOTOR - 20% Off Logo
Top Lincoln Industrial Plumbing Experts
Donni Steen
Tom Chichester
Are you a Lincoln Industrial Plumbing Expert? Answer questions, earn points and help others
