Question about Frigidaire GLER341A Electric Dryer
Kenmore dryer 110.68722700 made a loud pop and stopped working
  • 64 Answers
IF there is a 'capacitor' in the 'motor circuit', this could well have 'blown', usually indicated by a smell of aniseed (no joke!!)
Take a look inside the cabinet
Posted on Oct 16, 2013
I have a Kenmore Elite Dryer Model 110.66992500 that will not start. When the start button is pushed, it only makes a click. During the last use, the dryer was working fine then all of a sudden while...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Apr 01, 2011 | Kenmore Elite HE4 Electric Dryer
Kenmore 90 series dryer, motor wont start, loud
  • Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
  • If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.
  • Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Hope this will fix your problem for sure.
May 10, 2010 | Kenmore Dryers
Cycle Signal keeps beeping loud-soft every 15 seconds while dryin
Hi Celine, I just experienced the same exact problem. I came here looking for a solution. I got mine to stop by holding down the cycle signal button for 3 seconds, releasing it for three seconds, and repeating until both lights (loud and soft) went off. Hope it helps.
peter
Apr 21, 2010 | Kenmore Elite Oasis 6808 Electric Dryer
Dryer won't do anything
remove plug and then check where cord comes into machine sounds like you have a short
May 02, 2009 | Dryers
When I start dryer makes a loud hollowing noice and smells burnt.
hi dcimproveman,most common noise on whirlpool/kenmore dryers are the rollers.i would describe that noise as a klunk,klunk.klunk.what you do is unplug unit,pop the top,take off the frount,loose belt and remove drum.takes me less than 5 min.clean inspect/oil /no wd-40 replace worn parts as needed.if you get stuck,just send an email
Jan 01, 2009 | Kenmore 62602 Electric Dryer
2 year old Kenmore Elite Front Load Dryer makes loud squeaking
We can fix this. your dryer has some wheels/rollers and an idler pulley they get worn and or plug up with fabric sheet guu.what you do is pop the top,that the frount off and this will expose the drum,undo the belt the clean inspect /oil and replace worn parts.sounds like you wont see much wear because it stops after[gets warm]so may get buy with oil/cleaning Ps unplug before working
Dec 31, 2008 | Kenmore Elite HE4 Electric Dryer
Dryer stopped working
The dryers drive belt most likely broke. it must be replaced with a new one.
Dec 20, 2008 | Kenmore 88752 Top Load Stacked Washer /...
Kenmore gas dryer 97273100 was drying, but making a loud noise
You need a belt. Here's a link to a site with a good set of instructions if you want to try repairing it yourself. (You should DIY. You can save a bunch on the service call and the belt is only about $20.)
http://repair2000.com/wpoolbelt.htm
Dec 08, 2008 | Kenmore 72982 Gas Dryer
Kenmore 90 plus series dryer won't work
Sounds like the belt has broken. You could probably also use new drum support rollers. Check out this site which shows how to change a dryer belt:
It's not a difficult job if you're comfortable working with hand tools.
Oct 17, 2008 | Kenmore 62872 Electric Dryer
Timed drying knob doesnt move
hi .thanks for the question. if its the timed dry cycle that s not working .replace the timer .thanks the appliance doc
Apr 17, 2008 | Kenmore 74602 Gas Dryer
Frigidaire GLER341A Electric Dryer Logo
52 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
