Question about Kitchen Ranges
Kitchen Aid built in oven control panel flashing intermittently
  • Phoebe112 Oct 16, 2013
    This is a double oven unit model # KEBC208. When I turn it off at times the digital ocntrol panel flashes with very rapidly off and on. We replaced the thermocoupler on it when it was just out of warranty ( naturally). We had bouorght the oven while strting ot build our house and of course it was very delayed getting installed. Kitchen Aid was no help whatsoever with diagnosing the problem or caring tht it had just beeen installed just a fw onths before. It quit working when I tried the self clean mode and I was told ( on website) tht i tis was a very common problem. I have not had any trouble with the self clean mode since. This flashing business is worrryig me tht it might go out soon, thouogh. Should I be ready to intall a new control board? I have a Kitchen Aid built in type fridge unit also and we have had nothing brut trouble with itf. It is 5 years old and KA does not make the control panel for it any longer and nobody else does , either as we researched the devil out of it. Had to have it rebuilt. Does this mean yoiu spend $5,000 for a refrigerator that they expect to last only 5 years? I never will I buy another KA product and told them so. My kitchen is natcurally all KA products!
  • Richard Roth
    Richard Roth Oct 17, 2013
    I personally do not like Kitchenaid since they are so problematic and prefer Whirlpool. But, Whirlpool make the Kitchenaid brand! Go figure! Anyways, here is a link to the control board to order and it comes with a 365 day, any part, any reason return policy.http://bit.ly/19c69xi
    Top Expert:
  • Kitchen Ranges Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Oct 16, 2013
Testimonial: "Model # KEBC208"
  • 833 Answers
SOURCE: kitchen aid stove problem
Peter,
First...be sure you cut power to the stove before you do anything. This is 220 volts and it can kill you. 220 Volts is based on two different lines of power coming to the stove, each of which is 110 volts...but opposite each other in phase. This may mean that some power to the stove is on and some is not. Let's go on.
I suspect a few things: First, the coil control for the burner is probably finished. What I also suspect is that it opened one of the two breakers (they are usually tied together in the panel and are either 40/50/60 amp units) causing some lights but no action.
What to do: Reset the breakers as a pair by turning them off and on. If one snaps off, you have a problem at the stove. If not,...which I doubt...you're in business.
Let's look at replacing the control. Shut the breakers. Now, take the burned control and remove it. Note the wiring positions if they are not on a plug. If they are terminals, tape the ends. Now, reset those breakers. If the other burners work, replace the control. Take the old one to the parts store. If it doesn't work, look around the burned area for broken wires. Repair and tape them up. Try again. Oh, and don't let anyone touch the stove while you're working with those breakers.
Posted on Dec 03, 2007
  • 2318 Answers
SOURCE: Kitchen Aid KGRA806PSS
Check HERE for more info.
Posted on Mar 03, 2008
SOURCE: Kitchen Aid Double Convection Oven stopped during Self Cleaning
same thing happened to me yesterday took all day to figure it out was the themal fuse on the back of the oven the part number for my kitchen aid is 8300802 if you want the doors to unlock and reset the display you can take the leads off the fuse touch them together and the door will unlock however it is best to change the part took me 5 minutes once i knew what to look for
you have to remove the back panel and you will see the part with the number on it cost me 50 dollars but better than the 8o bucks to have a sevice guy come and do it next time i self clean i will pull the stove away from the wall to help keep it from ver heating
Posted on Apr 04, 2008
Cyril J
  • 45 Answers
SOURCE: Kitchenaid Selectra Range Fuse location?
unit does not have fuses , if the top works ok then you are getting 220 volts , you probly have a bad control
Posted on May 16, 2008
SOURCE: Kitchen Aid KGRC608
Hi does this range have a fuse for the circuit/timer board its not on at all but burners still lite and starter works if the is a fuse will you tell me where its at or is the top board fryed or the bottom board yes there is a bottom board on the right sie base in draw area dont know what to change i thought maybe it was only a fuse but can't locate it thanks for your help with this . model kgrc608lss0
Posted on Oct 25, 2008
We have a kitchen aid KGSA906PSS00 gas range. for the first time today the wife decided to run the self clean function. At some point through the self clean the oven shut off and the control panel died....
Sounds like my problem two days ago. I have a Kitchen Aid free standing gas oven/range model
KGRI801PWH00. I read online that the thermo-fuse might've blown. I found the thermo-fuse after removing the rear panel. It was at the top/center. Mine is T-O-D (brand) 60F24; Westinghouse #8300802. I ordered mine from appliancepartspros.com for only $34.75; arrived in 36 hrs with regular shipping!! Easy to fix, sure beats several hundred $$ to repairman.
Don't bother to call Kitchen Aid - they'll just blow you off just like the hundreds of complaints said that I found online.
Jan 27, 2011 | KitchenAid KGSA906PSS Gas Kitchen Range
My kitchen aid read f1 e2. the oven does not work
Your EOC electronic control panel(clock) is bad. It must be replaced.
Apr 18, 2010 | KitchenAid Kitchen Ranges
How do I remove the built in oven to replace the
there are no internal fuses, chk your houses main power panel and stove plug to make sure you have 240 volts for proper unit operation
Nov 03, 2009 | KitchenAid KEBC107 Electric Single Oven
Kitchen Aid KESC307 Electric Range oven shuts down unexpectedly
We've seen similar problems due to an intermittent failure in the control board. If you can have it removed we can likely repair it for you.
Best Regards,
Bruce
www.fixyourboard.com
Oct 12, 2009 | KitchenAid KESC307 Electric Kitchen Range
Blown fuse inmy kitchen aid range
if you havnt lost your main input 120/240 voltage then check around the control panel,you'll probably find a special control fuse in this area
Jul 14, 2009 | KitchenAid KGRA806PSS Gas Kitchen Range
Service Manual
when you took down the control panel and gained acess to the upper cavity , there wasnt a service manual just to the left inside a red plastic bag???, if not there is another fuse loacted just behind the micro front looks to be atop the capacitor area
Mar 09, 2008 | KitchenAid Architect Series KEMC308KSS...
Kitchen Ranges Logo
53 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
