Grunaire inverter unit GMU243HX Heatpump
I need parts source for main circuit board for outdoor unit
2 Suggested Answers
shastalaker7
  • 1515 Answers
SOURCE: an air conditioner spit sys inverter, I need the
Hi, here is the information you need to get any part you may need for this unit.
Quality Matters, Amcor
Toll-Free 866-725-9980
530-946-5869
This is all you will need. Parts for this unit are under warranty for 3 years, compressor, 1 year, with 1 year labor. Please rate me for my help to you. Thank you,
Shastalaker7
A/C, & Heating Contractor
Posted on Feb 24, 2011
How do I fix a black screen on copy tftv4025. I can see things like a shadow in the back when I press source but nothing shows up
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Sep 26, 2016 | Televison & Video
Samsung UN40JU6500F had picture on intial power up, changed source and lost picture. Can't get it back, only sound. See faint images. Bottom back shows blue lights on. Inverter? Power board?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Jul 26, 2016 | Samsung UN Televison & Video
Samsung TV no picture from any sources.
Sounds like Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Jul 26, 2016 | Samsung Televison & Video
Sansui sled 55015. Source menu remains on power light blinks rapidly . Now when I turn it on I get the flash screen and the tv turns off
http://electro-medical.blogspot.com/
Jun 28, 2016 | Sansui Televison & Video
Is the Backlight inverter and the power supply unit in the same board for this tv?
May 18, 2016 | Televison & Video
When we put on the air conditioner it shows F1 or ERROR on the window. What is the problem?
Hi Charity, F1 is a communication fault, I hope this helps......... CHEERS..
1?Check whether the connection of the outdoor unit and indoor unit is one to one, otherwise connect the L, N and communication line of the indoor unit and outdoor unit one to one.
2?Measure whether the voltage between the zero line and the communication line is 18V-30AC half-wave signal, check whether the communication circuit on the indoor and outdoor electric control board has been damaged, otherwise replace it.
3?Check whether the LED on the outdoor power board has been on, otherwise replace the electric control board.
4?Check whether the unit is abnormal caused by the external interference, if it is, then find the interfering source, and removes it.
http://www.chigo.bg/resources/pdf/Failure-code-manual.pdf
May 10, 2016 | grunaire GSI241HXB / GSU241HXB 24,000 BTU...
Power light turns blue, source light appears bright, then fades. Picture flashes on, then disappears, screen remains black.
Apr 14, 2016 | Sceptre X42GV-Naga 42 in. LCD Television
Samsung LED TV picture went dark, still watchable but backlight is set @ 10, Contrast 95, Brightness 100, Sharpness 67, color 32
Apr 06, 2016 | Samsung Televison & Video
I have a grunaire split ac system. I moved in and just was given the remote. What do all the symbols mean? How do you get the ac to work?
Service Manual - Grunaire - LoPDF
www.lopdf.net/...,/Service-Manual-Grunaire.html?...Grunaire-Remote-C... 1 Summary and features Indoor Unit GSI091HXD GSI121HXD Outdoor Unit GSU091HXD GSU121HXD Remote control window YT1FF Summary and features.
hope this is your unit, on page 11 it tells you what the buttons on remote do
Mar 03, 2015 | Heating & Cooling
Compressor shutting down
FC IS FREON CHARGE, WHAT YOU ARE GETTING IS A HIGH PRESURE CUT OFF  FAILURE. THE LABEL PRESURE IS TEST PRESURE. THE RUN PRESURE ON LOW SIDE IN AC MODE IS ABOUT 65 AT 75 T0 80 DEGREES INSIDE AND ABOUT 200-300 HIGH SIDE AT 75 -85 OUTSIDE TEMP. IN HEAT THE LARGE COPPER LINE BECOMES HIGH SIDE HOT WHEN YOU FEEL IT. IF YOUR FREON IS LOW WILL WILL ALSO GET SHUTDOWN. YOU WILL NEED SET OF FREON GAGES AND CONTACT ME BACK
Apr 23, 2010 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
