Question about Hamilton Beach Blenders
Model # 50199H blender: The blade assembly has frozen-it simply will not rotate at all. Can it be easily replaced with household tools? Thanks!
SOURCE: cuisinart sealing gasket
The gasket goes between the cutting assembly and the glass. So you slip it on over the top of the blades and then put the glass jar over top of that. Screw the bottom cap on to tighten everything together.
Posted on Nov 02, 2007
cactus bob
  • 267 Answers
SOURCE: blender blade not turning, rotating piece on base not connected
this is getting more and more common there is a part between the motor and the drive gear that snaps for no reason . its job is to snap if the blades jam as a "fuse" to save your house from a overheating ,jammed motor . the problem is there are no parts to buy to fix this . if its new take it back to where you bought it . otherwise shipping it 2 ways for repair to the factory is sometimes as much or more as a new blender ........ i would recomend you do one of two things : go to a goodwill or other type shop and get a nice vintage blender , it will last forever ! or move up to a vita mix . its costly but it will realy last you ... this new made in china junk is just bad news even when it has the kitchen aid name on it . its still the same junk ..... good luck........ Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob .
Posted on Mar 24, 2009
EwingElect
  • 276 Answers
SOURCE: Kitchen Aid Blender - blade not rotating
You will definitely need to change the clutch blade i.e. the black rubber rotating bit. Chaging it on the base unit may be difficult, I would check with your local Kitcheaid repairer for spare parts and repair advice.
Also check the clutch blade on the jug itself.
Posted on Apr 07, 2009
SOURCE: Can't find replacement parts for my Thunderstick Pro blender
I can sell you part of mine. I getting a new one to replace a part for mine.
Posted on Jun 10, 2009
SOURCE: GE Blender Jar loose rotator
Remove the bottom clean the unit fully. Add the bottom blad assebly and this will fix your problem. The "sooty" is plastic shavings. Take note that the fitting were the "jar" connects to the motor that this is not wearing away. The unit i have broke and i am unable to find a replacement blade assembly.
Posted on Aug 13, 2009
Blender does not blend, only buzzes. So I took the blender jar off the motor base and tried running it. It ran just fine. Put the jar back on the base and it only buzzed. Figured a piece of frozen fruit...
Smart move. The blade assembly is almost frozen and the motor does not have enough torque.. You need to remove the blade assembly and completely clean out the bearing and reassemble after the Mr. clean operation. A lite dab of oil is also called for.
Sep 10, 2017 | Oster 006832000000 10Speed Blender
`my blender leaks out the things i put in it
The seal on the rotating shaft has either worn out or hardened and if constructed like most, the seal cannot be replaced since the chopping blade and shaft are permanently fastened together. Your only recourse is to buy a new blade assembly which should be available.
I would search for it with the model number of the blender and 'cutter' or 'blade' assembly.
Jun 16, 2010 | Black & Decker BL600 ProBlend Work Top...
Apr 04, 2009 | Blenders
Poor function of my Oster classic blender
Yeah, the blades probably need to be replaced. The replacement blade assemblies for most models can be ordered directly from Oster - their phone # is 1-800-334-0759 - you have to go through an elaborate menu tree to get to the right place.
Apr 03, 2009 | Oster 4093-8 Osterizer Classic Blender...
Older Vitamix Problem
I want you to try this,
1.Remove the blender jar from the blender motor .
2. Check the jar by turning the shaft by hand to see if it rotates easily. .If not, disassemble the blade and ring. Check for obstructions or misalignment. It is better to change the shaft which holds the blade......
If it fails you again, you have to contact with the service center or visit this site
www.vitamix.com/household/service/service.asp
Hope my info helps you,
Thanx for using fixya,
Waiting to help you from your comments.....
Oct 01, 2008 | Vitamix Super 5000 Work Top Blender
Replacement parts
My blade assembly leaks just as you are describing. I found a website that offers replacement parts for Black and Decker appliances:
[Note: I have not ordered from this site yet so I can't say how reputable they are.]
They offer the glass jar, blade assembly, and other parts for the BL1900R. Judging from reviews, it may not be long until something else goes wrong.. I am gong to order the replacement part this one time. If anything else goes wrong though, forget it. Too bad. Black and Decker usually makes good stuff.
Jan 04, 2008 | Black & Decker BL1900R Blender
Something got stripped in my VillaWare 5787
you may have stripped the motor gear sek out a new unit
Dec 27, 2007 | VillaWare 5787 Double Smoothee Work Top...
Blender blade assembly no longer turns
I had this problem and, after seeing these posts, was motivated to avoid paying the cost of a new blade unit. Here's how it can be fixed:
1. Take a kitchen hotpad and hold the blade (top) side of the unit in your hand as you unscrew the rubber gear on the base. This is a left-handed screw, so you must turn it clockwise, to free it up. This should be doable by hand. Be careful, removing the gear exposes a washer note which side is up, and place both the gear and washer aside.
2. With the blades held in the hotpad, unscrew the top nut, again clockwise. This takes more effort, but it will eventually give way. As this nut comes off, it exposes a rectangular post, to which everything is attached.
3. Remove a washer with a rectangular cutout. Make sure you remember which side is up (I think it makes no difference). This may require some rocking to remove the washer from the round-threaded end. It will come off.
4. Remove both blades in a similar manner. Note their orientation, which is important.
5. Next, remove a rubber gasket. On mine, it has a groove which is asymmetric. I don't think the orientation is important, but, again, you may want to note it.
6. What is left is an axle inside a sleeve. There are no bearings. In mine, I had to tap/drive this out. Take a flat-ended rod (ideas: I used the hex-shaped post end of a nut socket. An old drill bit you don't care about, rotated would also work). Place the unit on the edge of the counter, up-side pointing up, in a way so the bottom end of the axle could fall free when you drive it out. Gently tap the axle through the unit, using the helper tool when the axle is within the sleeve. It will drive completely out.
7. Clean everything. I simply scrubbed the axle and took a small brush to the inside of the sleeve. This doen't need to be perfect, but anything left on either surface may ultimately impair the functioning of the axle.
8. Lubricate the axle with household oil or a dab of grease. You will find that the axle will now slide into the sleeve fairly easily (I had the best luck from the top.)
9. Reattach the base gear, then the top in the obvious order. Everything should spin freely from this point on.
REMEMBER: always use the hotpad whenever you grip the blades and to tighten the bolt on top so that the axle protrudes slightly above the nut.
Nov 02, 2007 | Cuisinart SPB-7 SmartPower Work Top...
Blade turns with difficulty
Check the blade assembly it may be worn out.
Mar 27, 2007 | Vitamix 5000 Work Top Blender
Blenders Logo
Top Hamilton Beach Blenders Experts
John Tripp
John Tripp
Craig Butler
Craig Butler
eyecam
Are you a Hamilton Beach Blender Expert? Answer questions, earn points and help others
