Question about GE JVM1790 Convection / Microwave Oven
FAN BLOWS ON INSIDE WHEN DOOR IS OPEN
WHEN THE DOOR IS CLOSED THE MICROWAVE DOESN'T OPERATE BUT WHEN YOU OPEN THE DOOR THE FAN INSIDE THE OVEN CONTINUOUSLY RUNS. I TRIED TO SET THE OVEN TO WORK AND IT JUST TICKS LIKE A CAR WITH A DEAD BATTERY AND DOES NOTHING...OPEN THE DOOR AND THE INSIDE FAN JUST BLOWS. I LOVE MY OVEN BUT CAN'T AFFORD A NEW ONE (JUST FINISHED PAYING FOR THIS ONE)
  • 652 Answers
Replace fan switch
Posted on Oct 14, 2013
4 Suggested Answers
  • 108 Answers
SOURCE: GE XL1800 Micro fan won't shut off after light burned out
The problem appears, at least in part, to the door latch circuitry which cannot be serviced by the owner. If the unit is still in warranty, call GE customer care. If not, replacing the unit is your best bet. I just bought a new GE 1100 watt oven with great features for less than $100 If the door dosen't latch correctly, you could be exposed to dangerous microwave energy.
Ray
Posted on Nov 16, 2008
SOURCE: Internal fan on microwave runs with door open
I have the same problem with mine!!
Posted on Apr 11, 2009
wiringlunati
  • 576 Answers
SOURCE: Microwave GE Spacemaker JVM1650SH05 - The light
The bulb may have blown. It is often under an access panel on the side or back that is held on with a screw or two.
Posted on Jan 26, 2010
Fan and light stay on when door closed. Shut off when door is open. Still heats. Door latch and spring are intact.
These door open or closed mixups are usually caused by the micro switches that are controlled mechanically inside by action of the latch when the door is closed/opened. There are usually 3 or 4 of those switches. Make sure the door protrusions are activating them. They can be replaced by generic ones of the same rating. I would replace them all! They cost less than $2 each. Order them online from a company like Mouser Elec or Digikey. You can test them for operation with the ohms function of a digital voltmeter. Be careful inside of a microwave. Deadly voltages even when off! Get some electrical help if you are unsure.
Nov 16, 2015 | Sharp R530E 2.0 Cu. Ft. Full Size...
Jvm1790sk fan comes on when i OPEN the door
Pretty sure its the door interlock switches.
you might need a service call from the authorized rep.... sorry.
Oct 14, 2013 | GE JVM1790SK Convection/Microwave Oven
Fan Ventilation panel on my GE Profile Spacesaver doesn't operate or close now.
For help with louver operation, see the owner's manual and for further help ask here.
Sep 04, 2012 | Microwave Ovens
GE Spacesaver Microwave not heating, inside fan not working
I suggest you have the microwave oven replaced, the prices have dropped considerably for the last several years and you have got your money worth out of the unit.
Mar 02, 2012 | GE JVM1640 Microwave Oven
GE Profile JE2160 - Just stopped working. Touch pad works, light goes on when door opens. When starting, timer counts down, can hear a relay click, but nothing (no fan, no turntable, no magnetron. Fuse...
Hi
If the fuse isn't the problem, check the door hooks and the door-release button. When these are broken, the door switch doesn't activate, so the oven can't work. You should check the internal door switches, the high voltage circuitry and the circuit board for this kind of problems. But for that you will need a certified technician to help you make these repairs.
Aug 19, 2011 | GE JE2160 Microwave Oven
After shutting the door and starting the microwave oven a "popping" noise was heard and the microwave oven went dead. What do I do?
I suspect your oven has a stuck interlock monitor switch. This is one of several switches inside that are operated by the door latches, and its contacts are supposed to open when you close the door. If the switch is stuck or is out of adjustment, it will cause the fuse to blow when you start the cook cycle. If there isn't any other cause for the fuse blowing, the switch can be adjusted or replaced as required. Microwaves are dangerous to work on, and door repairs can result in microwave leakage if they aren't done correctly. You should let a professional do the repair if you want to keep this oven.
Apr 19, 2011 | GE Microwave Ovens
Every time I open the door to the microwave, it goes on automatically. Even if I press the button on the door, the microwave goes on. Should I just buy a new one, or is it an easy fix?
most likely the door latch assembly and or the door switch has failed... there are approx. 3 micro switches located where the door closes... these switches all operate items such as the cooling fan,timer, clock assembly etc... sounds like one of these micr switches have failed and will require getting inside to exam with a meter and check contuinity on close and open when switch is open...good luck to you...
Jan 19, 2011 | GE Monogram ZE1660SA Microwave Oven
Microwave oven only operates if the door is held closed
If the microwave oven operates with the door open it is a serious issue. DO NOT OPERATE IT. Call a technician immediately. The RF frequency is extremely dangerous. the safety switches inside the oven are malfunctioning and needs to be replaced
Jul 03, 2009 | Microwave Ovens
Please help me
Q - My microwave went dead when I opened the door ( same problem as closed the door ).
A - This often is a stuck or faulty door switch and it has blown the interior microwave fuse.
Q - My microwave is completely dead.
A - House fuse has blown or interior fuse inside the microwave has blown ( usually a part inside the microwave makes this fuse blow ) Sometimes a bad fuse holder inside the microwave cannot hold the fuse tight enough and the fuse will blow as well.
Q - My microwave blows the fuse inside itself as soon as I push the start button.
A - Usually a shorted high voltage capacitor...see components section.
Q - I burnt something in my microwave and now it is dead...help!
A - The fuse inside the microwave may have blown, but more commonly the flame/oven thermostat has sensed the over cooked food and the flame/oven/cavity thermostat has opened up - Info on that
Q - My microwave seems to shut off every once in a while, what might be wrong?
A - Make sure you hear the fan is still operating in your microwave. Next is to make sure the air intake grill on your microwave is not plugged up with air borne dust and dirt.
Q - The microwave makes a loud "hum or buzz" noise but will not heat up the food?
A - 9 times out of 10 this is usually this is a bad magnetron, the other time is sometimes a bad high voltage diode. See components section.
Jan 02, 2009 | Sharp R-242 Microwave Oven
GE JVM1790 Convection / Microwave Oven Logo
101 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
