Question about Hayward Navigator Pool Cleaner
I have no suction on the navigator - Hayward Navigator Pool Cleaner
    Champion:
  • 305 Answers
Use new hose. if no change then prob is from equipment, or navigator itself. they have a preset from factory button on bottom. its green i believe. if ever altered it affects performance
Posted on Dec 05, 2013
My hayward navigator doesn't walk
not a problem with return pressure. navigators run off suction pressure. ensure proper suction from skimmer or designated suction line. then check the hose attached to navigator. put a new hose on, if this works then the hose was issue.....if no difference then replace the navigator
Mar 07, 2014 | Hayward Navigator Pool Cleaner
Shark navigator no suction and getting hot
sounds to me there's a blockage somewhere .the link below is the manual it will show you where to look for blockages..
http://www.totalvac.com/manuals/Shark_Navigator_Infinity_Owners_Guide.pdf
Feb 23, 2013 | Euro-Pro NV22 Shark Navigator Bagless...
Navigator pool cleaner just skims the bottom of the pool and does not sit on the bottom, it moves all around the pool but appears to be floating a little. How can we fix this so it will sit and move on the...
Interesting question. Do you have the special Lead Hose, the one with a colored cuff attached to the Navigator itself? Other causes can be, too little or too much hose, a pinhole leak in one of the hoses above water causing the hoses to float, not enough suction on the Navigator. You didn't say if you have the Navigator plugged into a skimmer or in a dedicated suction port in the wall. I would first try increasing the suction to the unit and see if your problem doesn't go away.
Sep 03, 2011 | Hayward Navigator Pool Cleaner
Navigator sticks to the bottom of the pool and won't move. I replaced the turbine and the A frames are good. Will new feet help? the current ones are worn.
The feet might be the problem, but more than likely, you have too much suction on the pool vac. There is a suction gauge that comes with all new cleaners and most pool stores will have them available (maybe as a loaner even) to allow you to adjust the suction to your pool cleaner.
Try adjusting your suction to your cleaner to reduce the amount of direct suction to the cleaner to see if it operates, but if your feet are worn, you should definitely replace them.
Dec 05, 2010 | Hayward Navigator Pool Cleaner
POOL CLEANER GETS STUCK ON THE MAIN DRAIN
If it's an older Navigator and it just recently started to hang up on the drain cover, replace the throat assembly, part 29. The lugs or hold offs on the bottom of the assembly have worn down and are not breaking the suction as the Navigator travels over the top of the domed drain cover. Replaced mine and no longer have the "my navigator gets stuck on the main drain" problem.
Aug 06, 2010 | Hayward Navigator Pool Cleaner
My pool navigator will not stay at the bottom its always coming to the top to clean and hovers there.
if by saying at the top you mean running around the top of the walls then reduce the suction on the vacuum by opening another valve slightly... if by at the top you mean floating around in the water then make sure the vacuum is getting enough suction.... it can be a number of issues causing loss of suction but most likely is going to be too many sources on suction side of pump.
May 31, 2010 | Hayward Navigator Pool Cleaner
MY NAVIGATOR IS MOVING VERY SLOW AND GETS STUCK OFTEN ON THE DRAI
Take it apart and make sure it doesn't have trash in the wrong places or broken gears, also check the other end of the hose and make sure you have suction at the unit.
Sep 13, 2009 | Hayward Navigator Pool Cleaner
Hayward Navigator Moves very slow
check the bearings on the turbine and "a" frames.
also make sure the left and right pods are tightened properly and the pod shoes are in good shape.
Sep 05, 2009 | Hayward Navigator Pool Cleaner
Adjust navigator suction
hi
1st make sure the navigator is clean and wheel is free to trun also at the filter u might have a handle that controls the suction for ur pool swep
May 24, 2009 | Hayward Navigator Pool Cleaner
Hayward Navigator Pool Cleaner Logo
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
