Question about Maytag Kitchen Ranges
Oven "on indicator" light doesn't go out. Everything else appears fine,but the indicator light stays lit all the time even when oven is off. Model number mer5752baq
  • 667 Answers
Unplug for 10 minutes
Posted on Oct 14, 2013
fridgetech
  • 473 Answers
SOURCE: Oven takes a long time to preheat
Before we go into diagnosis mode, call the customer service # in the owners manual and complain about the problem.  They usually will make a concession when it is this close to the warranty period.  Let me know what you find out.
Posted on Oct 25, 2007
SOURCE: Oven will not stay lit,
Sounds to me like a bad thermal fuse. Call a tech in to replace it.
Posted on Aug 20, 2008
  • 3 Answers
SOURCE: I have a Garland stove series #G286, the oven won't stay lit.
it sounds like a venting problem, the oven heats up and it not venting,it will put the pilot out.
Posted on Oct 16, 2009
SOURCE: Oven pilot light won't light
It is usually a bad thermocouple. Mine had only had a weak pilot flame and the problem turned out to be a corroded and leaking pilot gas line. It was leaking whee it enters at the bottom of the oven chamber.
Posted on Feb 03, 2010
SOURCE: Oven won't stay lit
gas oven ignites and lights then flame goes out
Posted on Nov 29, 2010
Will not stay on will shut off
Whirlpool Gas Oven Will Not Stay Lit - Appliance Repair Forum
forum.appliancepartspros.com/oven.../482851-whirlpool-gas-oven-will-...
Jun 20, 2012 - 2 posts - ‎1 author
My Whirlpool gas oven will light but not stay lit. It has a glow plug igniter that heats up enough to allow the gas valve to open. Once the burner ... oven lights, but does not remain lit
Feb 19, 2013
Oven does not stay lit
Jun 19, 2012
Oven will ignite but will not stay lit
Aug 3, 2010
Gas Oven won't stay lit
Mar 25, 2008
More results from forum.appliancepartspros.com
Jan 04, 2016 | Ovens
I hav whirlpool accubake.oven wont stay lit.it ignites then flame goes right back out
Whirlpool oven won't light - Appliance Repair Forum
forum.appliancepartspros.com/oven.../225907-whirlpool-oven-wont-lig...
May 19, 2011 - 10 posts - ‎2 authors
I have a Whirlpool Accubake oven (SF362LXSS0) that doesn't seem to be consistently turning on, and the problem's getting worse. ... If I try to turn it on to bake, I hear several clicks, but not that "gas oven turning on" sound and no heat comes out (but a slight smell of gas is ... Whirlpool Gas Oven won't stay lit
1 post
Oct 25, 2012
whirlpool oven won't stay on
1 post
Aug 13, 2012
Jun 20, 2012
whirlpool accubake oven will not stay lit
1 post
Nov 9, 2009
Whirlpool Accubake Model # GW395LEGQ4 - Oven won't Start ...
Dec 12, 2015 | Stoves Ovens
Pilot light stays lit but oven will not stay lit
I would be interested to know just how long it is that the oven does stay lit. All ovens, gas and electric, cycle off and on throughout a baking cycle, to maintain the proper temp. If the flames or the power to the element were to stay on at full power for the life of the food's required time in the oven it would most likely wind up charred. The temp would simply continue to rise, up and up and up. If that's what it appears to be doing, then it's just working normally. If it goes out completely and stays off, doesn't come back on in a few minutes, then it may be in a keep warm mode. Many ranges have a TIMED BAKE cycle available, so you can set the clock to start the oven at such and such a time, cook the food and then shut off. Once it's finished with the cooking cycle, it goes into a keep warm mode, where it will come on for a short time and then go off, to maintain about 180 degrees. Not hot enough to really cook anything anymore, but hot enough to keep it warm for you when you get ready to eat.
If this seems to be the way it's acting, then look for the timed bake function on the console and set things back to a manual mode.
Apr 22, 2011 | Kitchen Ranges
I have a garland oven model st286 it wont light even though there is gas getting to it and the spark is working. It lights if you light it manually
Instructions
  1. Access the burners inside your oven by removing the access panel in the front of the oven or by opening the broiling drawer, depending on your particular model.
  2. Determine if the pilot itself is lit, since some ovens have a small flame on the pilot at all times that then grows and extends to the burner when the oven is turned on. The lack of a pilot flame indicates the oven thermostat is malfunctioning or there is a problem with the gas hose. Check the pilot itself to see if it is clogged with debris or grease that could be preventing the flame from staying lit.
  3. Determine if the pilot flame will grow if it is lit by turning on the thermostat. If the pilot flame doesn't extend, the thermostat itself likely needs replacement. If the flame is extending but the gas valve is not opening, the safety valve could be dirty or defective. The flame should be blue in color. A yellow flame indicates the pilot is dirty and is not burning hot enough to get the main burner to ignite.
  4. Light the burner on the top of the oven with a match if the igniter doesn't appear to be effective. If it lights manually but will not light automatically, the igniter is likely faulty. Do not do this if there is a heavy smell of gas in the kitchen, since there could be a risk of a fire. In that circumstance, turn the oven off, ventilate the room and call a technician.
  5. Listen for any sounds of gas hissing or a clicking sound indicating the oven is trying to turn on. If there is no response from the oven at all, the gas may not be functioning properly and will need to be examined by a technician for safety purposes
Jan 26, 2011 | Ovens
Model FEFL78CBC frigidaire oven bottom (bake) burner won't work everything else works fine --even broiler element works fine. Just used self-cleaning cycle, which did work. Next morning oven won't heat ....
We had the same thing happen and now they came and said it was the clock that needs to be replaced. They said that controls the oven. Even though clock is on and working the function for turning on the oven is not
Nov 28, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
My gas oven stays warm even though it is turned off
A standing pilot such as this will give off heat. So long as the gas bake burner is not lit also, you will be fine. If the bake burner IS lit you have a defective oven control.
Jun 26, 2009 | GE Ovens
My oven - St George UGM-4 model - won't light. I don't know how old the oven is. There have been problems for a while, with the flame going out after about 5 minutes when it's first lit (it makes a...
this one is hands on fix,many times the spark ignition the one that makes the clicking noise is clicking on a different position,so you most look inside the oven to see the spark, you can see it better at night or when is dark to see the spark, that spark is right at the tip of the oven pilot, make sure you see the spark lighting the pilot.as long as the pilot does not ignite.the clicking sounds continues making the noise. if the pilot lights the noise will stop, if the oven burner does not light after pilot is being for about 1 minute and a half the safety valve needs replacing
Dec 06, 2008 | Kitchen Ranges
U1721 Strange Problem
could be a clock fault - try bypassing the auto function on clock.
otherwise, check the terminal block where mains is connected. these quite commonly burn out
Jul 06, 2008 | Neff U1721 Double circotherm Electric Oven
Oven won't stay lit
I had the same problem - it was because we were closing the oven door too hard and it was blowing the pilot out
Dec 27, 2006 | Equipex PZ-330 Electric Single Oven
Kitchen Ranges Logo
67 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
