Question about M&S Systems M & S SYSTEMS DMC1CDB Whole House CD Player for DMC1 CD Player
I am receiving a ticking sound through my master panel inside the house. It happened last year but stopped on its own. The ticking sound has started again and seems to occur when it rains. I have a speaker on an outside covered patio and a covered front porch. M & S Intercom. C. Ryan
  • 652 Answers
Replace the reset switch
Posted on Oct 14, 2013
It makes a loud ticking noise when it comes on
It sounds like the first signs of the master control panel going bad. My ice maker stopped working and eventually the water dispenser would cut out and back on. My control panel lasted for aroundd a year until the refrigerator and freezer stopped working. The control panel costs around $100, more or less. The good news is that it's very easy to replace it yourself. You can access it by unscrewing 4 maybe 5 screws (depending on your model) from a plate on the back of the refrigerator.
Dec 09, 2015 | LEC Refrigerators
I have a Whirlpool Duet Dryer that I purchased in 2006. It runs fine but during the day when it is not running, it makes some sizzling, zapping noises that sound like they are coming out of the control...
HI KEN,ITS LASTED YOU VERY WELL.THE LAST TIME I OPENED
A DRYER THAT OLD THE INSIDE WAS LITERALLY FULL OF FLUFF AND FIBRES,AND SCORCH MARKS IN SEVERAL AREAS.IT SOUNDS TO ME LIKE A LOW VOLTAGE SHORT
ON YOUR FUNCTION BOARD.MY ADVISE IF YOU CAN AFFORD IT GET RID,UPGRADE TO NEW.IF NOT PLEASE GET A SERVICE GUY TO OPEN IT UP FOR A LOOK.IF YOU CAN WATCH HIM EVEN BETTER BECAUSE YOU WILL SEE ALL THE FLUFF N BITS INSIDE..NOT TO WORRY YOU BUT LEFT UNCHECKED,WORSE CASE?IT BURNS YOUR HOUSE DOWN MATE,IT IS CURRENTLY A TICKING TIMEBOMB..ALL THE BEST MARK IN SWANSEA
Mar 31, 2015 | Whirlpool Washing Machines
We have several 11 year old Craftmade ceiling fans that have developed a ticking sound, mostly on the medium speed. Is there a way to lubricate them or is there some other way to stop the ticking?
Several things besides lack of lubrication can cause the problem.
One or more of the fan blade irons may be loose. As well as the wooden blade itself. In both cases a Phillips screw driver will solve the problem.
The pull chains are clicking against the the fan. I've see this happen many times. Simply putting some tape around the chain, where it touches the fan, will generally silence it.
And last, but not least ... The fans may be out of balance. But, this may be due to loose screws in the fan blade irons.
As far as lubrication is concerned. Older unit (10 to 15 years) have sealed motors that were to be permanently lubricated. Even some of today's brands and models are too. At best, if none of the above silenced the ticking, is to use a little WD40 with a straw nozzle up into the fan housing. Be careful doing this as the WD40 may drip. Be sure the wall switch for each fan is OFF, before attempting this.
Hope this helps you and thanks for choosing FixYa.
Aug 27, 2011 | Heating & Cooling
Not working at all. my washer was on working and i heard a big bang and my electrics went off, i turned everything back on and the washer started up again but then stopped and now will not work. when...
The ticking that you hear is probably the timing motor for the dial.
Was the "bang" from outside the house? If so, then a transformer probably blew and hit your house with a power surge. Motor is likely damaged, and will need replacement.
If the bang was inside the house, the capacitor on the motor probably blew (unusual failure mode though), and will need to be replaced, motor is likely damaged as well.
Sep 18, 2010 | Hoover Washing Machines
My first alert smoke detector went off at midnight last night. It is doing the three beeps, pausing and then another three beeps. This happened for about 3 minutes, stopped and then started again...
Change brand new battery,every three months.Take some rubbing achahol clean the test button metal contact inside the detector.Well works correctly after these steps.
Dec 15, 2009 | First Alert SA302 Dual System Smoke...
1994 Carrier 58 PAV
sounds like the relay for the unit may be bad, usually if a blower motor goes it stops or has a very loud humm and only goes slow
Aug 03, 2009 | Heating & Cooling
3 year old Lennox system stops intermittently 2-3times past 24hrs
i would have the thermostat receiving 24 volts all the time by running the c terminal from the air handler to the thermostat and go from there
Jun 21, 2009 | Honeywell Heating & Cooling
Water begins to fill then stops followed by ticking sounds, was working for the last 3 years!
Relays on the ECU are failed. You must replace the ECU to solve.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 29, 2009 | Kenmore Washing Machines
Phantom ticking
wait about three days to see if it stops this is typical when you clean one this way as water can get in the ignighter switches if not you have to replace the switches which are on the knob shaft behind the panel and come in sets of four and its not hard
Jun 20, 2008 | Ovens
Ticking sound
its natural...its just the sound of the oil warming up inside,it pops for a few minutes
Dec 03, 2007 | Lakewood (5500) Oil Filled Radiator Heater
138 people viewed this question
Top M&S Systems Audio Players & Recorders Experts
Colin Stickland
Colin Stickland
Tre Elkins
Are you a M&S Systems Audio Player and Recorder Expert? Answer questions, earn points and help others
