Question about Frigidaire Dishwashers
Frigidaire dishwasher does not drain - Frigidaire Dishwashers
  • 652 Answers
Check for plugged hose
Posted on Oct 14, 2013
I have a Frigidaire dishwasher model number FGBD2431KF purchased around 2009. Water is not pumping out.
Sc. Check the drain valve, remove the pump and test it. If it is not the pump then probably a relay or switch. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Dishwasher Diagnostic Repair Not draining Frigidaire Electrolux...
Dishwasher Not Draining Dishwasher Drain Pump Replacement Part 5304463777
Frigidaire Dishwasher Not Draining
http://www.partselect.com/Repair/Dishwasher/Not-Draining
May 08, 2016 | Frigidaire Washing Machines
Water not draining fully on dishwasher.FRIGIDAIRE model GLDB653AQ1
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems -
Water will not drain out
heatman101
Jan 15, 2011 | Frigidaire Dishwashers
I have a 8 month old Frigidaire Professional dishwasher which will not drain. What do I need todo? Email: cujobuddy12@yahoo.com
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
Dishwasher Problems - Water will not drain out
heatman101
Sep 08, 2010 | Frigidaire Dishwashers
My Frigidaire Ultra Quiet Plus dishwasher is not draining after final rinse. What can I do?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 07, 2010 | Frigidaire Dishwashers
Frigidaire Dishwasher won't drain
Try cleaning out the drain line behind the dishwasher, this is a very common problem with draining. If not that then might need a valve or if you have a new garbage disposal you need to punch out a peice of the plastic or it wont drain. Hope this helped, good luck
Jul 15, 2009 | Frigidaire Dishwashers
My Frigidaire Dishwasher is not draining
Check the direction of the drain from the dishwasher. It should go into a slightly pointed downward "TEE".
Mar 05, 2009 | Frigidaire Dishwashers
Frigidaire 18 in built in dishwasher ...
It is unrelated...
heatman101
Jan 20, 2009 | Frigidaire 18 in. FDR252RB Built-in...
A common problem with dishwashers is the non-draining machine. If you are having trouble, check to see if the drainpipe and sink trap are clogged. If you still have drainage problems after doing this, check your drain hose to make sure there are no kinks or bends. if the hose looks worn out you can replace the hose pretty inexpensivley. if your have thoughly checked from dishwasher to trap under the sink where your dishwasher should drain to and it seems clear you may have to call in the repair man.
Jun 18, 2008 | Frigidaire 24 in. FDB510LC Free-standing...
Dishwashers Logo
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
