Question about Optics
Tasco 4x32 rifle scope has "spot" or "blur" on inside of eyepiece lens...how do we clean or remove this?
  • 243 Answers
You don't. Send it back to Tasco for repair or replacement.
Posted on Apr 20, 2014
2 Suggested Answers
miket756
  • 2702 Answers
SOURCE: i have a tasco 4x32 rifle scope and the cross
you dont fix a tasco scope there so cheep you just throw them away,, and buy a new one,,,sorry but thats the way it is with tasco
Posted on Nov 17, 2009
HOW DO I ADUST THE LENS ON BARNETT 4X32 SCOPE
4x32 mm Illuminated Crossbow Scope Owner's Manual - Crosman
https://support.crosman.com/hc/en-us/article_attachments/.../432RGMK-515.pdf
E. Windage (horizontal) Adjustment. F. Objective lens. 2. EYEPIECE FOCUSING. Without using your scope, look at a distant object for several seconds.
[PDF]4x32 Crossbow instructions - Mission Archery
missionarchery.com/wp-content/uploads/2014/07/4x32-Crossbow-instructions.pdf Keep the protective lens covers in place when the scope is not in use. ... This optimum adjustment may also require the rings to be moved along the scope rail.
Barnett Crossbow Scope Review - 4x32mm - HuntingOptics.net
huntingoptics.net/crossbow-scopes-reviews/barnett-crossbow-scope-review-4x32mm/ This is a bit above the curve for 32mm objective lens scopes, so I'd call the field of ... The Barnett 4×32 multi-reticle crossbow scope is very easy to sight in, once ... Thanks for reading my review of the Barnett 4x32 multi-reticle crossbow scope.
How to zero a crossbow scope (Tutorial) - YouTube
? 7:55
https://www.youtube.com/watch?v=Td-qESCt7Gw Nov 7, 2013 - Uploaded by Weaponsandstuff93
How to zero a crossbow compatible scope to shoot accurate groups with bolts. ... Some of them crossbows ...
Sighting in a Crossbow Scope - YouTube
? 3:03
https://www.youtube.com/watch?v=TnOIy1ZTe1U Aug 23, 2012 - Uploaded by Ghostkamo
Easy steps to sight in a Red Dot Scope. ... Just bought a Barnett Ghost 410 and needed to check how to ...
HOW DO I ADUST THE LENS ON BARNETT 4X32 SCOPE - Fixya
www.fixya.com/support/t26743320-adust_lens_barnett_4x32_scope 25 mins ago - If your rifle is taped for scope rings this is a easy thing to do, if you do not have any screw holes on top of the barrel you will have to have a smith ...
Sighting in my Barnett scope - HuntingNet.com Forums
www.huntingnet.com > HuntingNet.com Forums > Archery Forums > Crossbows Sep 1, 2009 - 10 posts - ‎7 authors
I have the Barnett 4x32 Multi Reticle scope and as per the instruction it tells me to set the top reticle line at 10 yards. So after about 10 shots I ...
barnett 4x32 scope Questions & Answers (with Pictures) - Fixya
www.fixya.com > Forum > Tags Get free help, tips & support from top experts on barnett 4x32 scope related issues. ... I have a chipped lens on the inside of the scope how do i get it fixed this will need to be sent to ... How do I adjust the reticle for a Simmons Mag 4X32 ...4X32 ... ADUST THE LENS ON BARNETT 4X32 SCOPE Google Search
Sep 18, 2017 | Optics
How to disassemble my bushnell sportsman rifle scopes coz i wnt to clean it
On my Bushnell scope I have an adjustable angle ring that will bring in the view, it is held in place with 1 screw. remove it and pull down towards the windage and elevation adjustment screws. There are 3 tiny phillips screws, remove them. Then unscrew the end of the Eye Peice end peice with the lens in it. inside on the outer edge of the main tube there is a locking ring that keeps the eye peice from unscrewing off, remove it and unscrew the entire eye peice. you are now ready remove the inner tube. Be careful here this is where you can damage the cross hairs and lose the leaf spring that maintains pressure against the windage and elevation screws. When you reassemble after cleaning and with the elevation screw at 12 o'clock and windage screw at 3 o;colck, the leaf spring will be in the 7 or 8 O"clock position, it just sits in there up against a little ridge inside, with the bow facing to the center. Back off the elevation and windage screws all the way so they don't block the inner tube from going in all the way. Once it is in adjust it so the cross hairs are orented correctly and put it back together. If you want to refill with Nitrogen remove the front lense and take to someone that fills tires with Nitrogen and inject the nitrogen into the scope, Quickly reinstall the front lens as nitrogen is about 3% lighter than air and if you take too long it will all escape.
This worked well for me. Good Luck and Happy shooting
Apr 27, 2011 | Bushnell Sportsman 4x32 Riflescope (4x32...
Tasco scope
Sight in rifle.Put top(elevation)cap back on with the"0" facing back.Be careful not to make it "click"as this will change point of impact.The way this works is you aim at animal and adjust the power(3-9)until the animal's body is between the 2 lines.Look in the little window on eyepiece to see distance of selected animal.Then click top knob to the correct distance(200,300,etc.)This should raise bullet impact for that distance.I've had this scope on a .270 since 1980 and never used this feature.(I only bought it because the scope was on sale)
Jan 03, 2010 | Tasco Hunting World Class Scopes Standard...
I have a tasco 4x32 rifle scope and the cross hairs spin inside how can this be fixed
Nov 13, 2009 | Optics
Blurred brand new tasco RF37X20 3X-7X20 scope
You have moisture inside the barrel. Remove the eyepiece and objective to air out and the-assemble after a few days. Be sure to mark which end is which!
Oct 24, 2009 | Bushnell Tasco Telescope Galaxsee 525x60mm...
Rifle scope is hitting 5 feet high but dead center
mounts are probably too high.....had the same prob on a .22 rifle with high mounts for open site shooting also. i bought a lower mount and zeroed it in with no prob
Nov 24, 2008 | Bushnell Sportsman 4x32 Riflescope (4x32...
Tasco Rifle scope repairs
Try calling Customer Service at 1-800-423-3537. They should be able to assist you with your needs.
Sep 22, 2008 | Zeiss CONQUEST 3-9X40 MATTE Z PLEX
this will need to be sent to bushnell for repair and they can be reached at 800-423-3537 option 1.
Jul 04, 2008 | Bushnell Sportsman 4x32 Riflescope (4x32...
Tasco propoint PDP2 scope
Are you looking set the eye relief or the focus ring?
For eye relief you need to loosen the scope in the rings, mount the rifle to your shoulder with your standard hold and cheek weld. At this point, slide the scope back and forth in the rings until you obtain a full field of view. Tighten one of the rings slightly, dismount and remount the rifle several times to ensure correct adjustment. Level scope and tighten rings a final time.
For focus adjustment (remember that you are using the eyepiece to focus on the cross hair, not your target!) loosen the lock ring and turn the eyepiece until the cross hair is focused. It is best if you check it several times by closing and opening your eye several times. The crosshair should be instantly in focus. If your eye must adjust, then you need to refocus until the focus is instant.
The two dials on the scope are for adjusting the bullet point of impact. They will typically move POI 1/4 inch at 100 yards.
Nov 08, 2007 | Optics
Optics Logo
41 people viewed this question
Top Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you an Optic Expert? Answer questions, earn points and help others
