Question about Emerson Microwave Ovens
Microwave shuts off and trips circuit breaker when opening door.
  • 667 Answers
Replace this unit to avoid problems
Posted on Oct 14, 2013
4 Suggested Answers
MicrowaveSvc
  • 9098 Answers
SOURCE: No power
The door switches are designed to prevent the unit from running while the door is open. You probably have a blown fuse, and it's a white or dark grey ceramic fuse of 15A or 20A, available from local big box stores or appliance parts stores. The fuse is usually located on the floor of the chassis behind the control panel, or mounted in the same area as the door switches. Also, I'm really curious how the door switch got stuck while cleaning? That sounds scary...
Posted on Nov 13, 2006
  • 57 Answers
SOURCE: No Power Whirlpool MH7140XF
does it not light up at all? A microwave has a fuse on it. Probably accessible from the back panel. if not you would need to disassemble it. Most likely cause of this is slamming the door broke one of the safety switches the door has so the microwave knows when the door is open. And it shorted against something when it broke. It might have simply blew the fuse but then again you might have fried it.
Posted on Oct 01, 2007
Gort007
  • 1187 Answers
SOURCE: microwave trips circuit breaker when plugged in
The circuit is probably a 20Amp circuit (see the number stamped on the circuit breaker switch). Most likely, it is the same circuit as the refrigerator, crock pot, window A/C unit, etc....
Also, if you are using an extension cord or a power strip or a surge protector. Those may not have a high enough power rating.
One other possibility (not likely) is that the circuit breaker is a 15Amp and the microwave is 1500 watts.
What else is cut off when the circuit breaker is tripped?
Solution is to use a different outlet for the microwave, or turn off any other applicance in the same circuit (except the refrigerator, of course).
Hope this helps!
Posted on Sep 16, 2009
How can I stop my G9115SL microwave from tripping my circuit breaker?
I run into this problem when people are running their microwave off a 15amp line. Especially if it is sharing the line with another appliance like a refrigerator or large over head light or in my wife's case...the vacuum cleaner. Step one is to count the amps on the line. Step 2 is to replace the breaker. They do go bad but not often. Good luck.
Mar 27, 2015 | Emerson MWG9111SL Microwave Oven With...
Circuit breaker trips
stop using - the microwave is short inside or in plug - get it checked by a experienced person.
Dec 15, 2013 | Samsung SMH7178STD Microwave Oven
Mcd 1311st blowing circuit breaker
Generally microwaves should be on their own breaker. Hard wired ones are required to be by code.
If yours has a plug - make sure the plug is original with the unit, not added later or spliced onto hard-wired power leads.
Plug into and outlet rated 15A as the only thing on a 15A branch circuit and try again. If it still trips, try a 20A line and circuit. If it trips that, trash the microwave and buy a new one. Nothing is meant to be repaired inside.
Nov 03, 2017 | Microwave Ovens
GE microwave (Model JE2160SF03) trips breaker when door opened
Remove the control panel, take pictures of the door switch wiring while they are still connected to the door switches, then remove the door switch assembly. Have someone at the appliance store check each switch and repair the ones that are defective.
I purchased a switch for $7, reinstalled the door switch assembly and the microwave is working fine now.
Jul 02, 2012 | GE Microwave Ovens
Emerson Microwave MW8115SS --
I would suggest you check the door switches inside the microwave oven just below the keypad, rectangular in shape. The switches are normally open or closed, set meter to ohms, unhook lead from one side and test with door open and closed. If readings are the same both ways the switch is defective. "check all switches"
Mar 19, 2012 | Emerson Fans Emerson MW8115SS Microwave...
We have a GE Profile microwave and every time we open the door it trips the breaker. We turn the breaker back on and use the microwave and as soon as the food is done cooking and we open the door - bam,...
For a breaker to trip, you have to have an over voltage condition that is usually referred to as a short. Since your unit works in the cook cycle and only trips the circuit breaker when you open the door the short has to be in the door latch switch or reset circuit. So it wouldn't be that hard to repair, but since it is 7 years old and not the most energy efficient unit, if you aren't able do the repair yourself, then I would replace it!
You can get an idea of how hard the repair would be by going to the searspartsdirect.com web site and putting in the model # off the ID TAG. Then look for the door latch assembly and that will give you an idea of the cost of the parts and get an idea of how hard it is to replace.
Aug 07, 2011 | Microwave Ovens
GE Spacemaker Microwave JVM1441 BH04 tripping circuit breaker
your power transformer for the magnetron could have a shorted primary power winding,the door safety interlock switch could be mis-adjusted,this normally blows the internal unit fuse,a shorted high voltage capacitor,or diode,a bare wire inside the unit,more than the microwave on that circuit or a weak circuit breaker in the house power panel
Jun 19, 2010 | GE JVM1441 Microwave Oven
The microwave won't stop.
You probably have a bad door switch or door switch mount. See this file.
May 05, 2010 | Frigidaire Built-In Microwave
Opening the door blows the fuse
more than likely you door safety switch has a short and every time you pull the door open the connections arc and trip the breaker or blows the fuse.
Aug 24, 2009 | GE JVM1190SY/WY/AY/BY Microwave Oven
Tripping of circuit breaker
Check what other appliances are on your circuit. What goes off when the breaker is tripped. You may need to relocate the microwave to a different circuit. Try to stay away from the refrigerator or AC circuits.
Nov 03, 2007 | GE JVM1440 Microwave Oven
Microwave Ovens Logo
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
