Question about Barcalounger Furniture
Foot rest spring popped out...can't get it back
Spring loaded foot rest
You replace with another spring that has similar characteristics.
Sep 03, 2017 | Cars & Trucks
Lazyboy recliner foot rest will not stay up!
Check the spring that holds the foot rest closed or open. Flip the chair over and take a look.
Mar 30, 2014 | Furniture
Bobbin case
Is it the whole case or just the bobbin? There are several things that can cause this. Your bobbin case may not be seated evenly. Check that all four sides rest evenly in the basket. You may not have inserted it properly, so that the "nub" or "hook" rests against the spring, which is there to prevent the case from spinning. The spring itself may have popped out; if so, it's an easy matter to put it back in again.
Mar 05, 2014 | Singer 8763 Curvy
Lafer spring
I have Lafer Kiri chair and spring for foot rest broke
i found replacement spring at Lowes
It is Hillman replacement spring 2 per pkg
Bar code 08236 80104
Works great
Nov 30, 2013 | Lafer Kiri Recliner Chair Cherry Red,...
Barcalounger foot rest spring popped out, and I don't know where it goes...easy fix if I know where to put it... please help!
Most Barcaloungers have a foot rest mechanism spring on right and left side. Look on the opposite side and see if you can locate the same spring to reinstall.
Sep 28, 2013 | Barcalounger Furniture
Recliner foot rest bolt broke and spring came off
looking for two small springs that go in the foot lift section of a lazy boy recliner. these springs allow you to raise the foot lift to different positions. these are very small springs and attach to each side of two small drum types.
Mar 22, 2013 | Lazy Boy La-Z-Boy Power Lift Recliner...
Loose drive belt
the belt could be warn out or have a broken spring look under the foot rest there is a diagram for the drive belt under the foot rest
Jul 05, 2012 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
I cannot figure out how the shank attaches to the pressure foot.
Make sure you get a foot designed for this Singer sewing machine. Then for snap-on feet, push down slightly on the front of the foot then pull forward (with some you pull to the left). To insert a new foot, push the foot towards the connector (back or to the right) and then push the back of the foot up (once in contact with the connector) while still moving into the connector. (You should feel the spring lift up and snap around the foot.)
For shanked feet, loosen the thumbscrew and slide the open side over the screw and press against the shaft. Then tighten the thumbscrew.
I hope this helps.
(my older Singer uses a snap-on zig-zag foot. This foot gets pushed in from the front . Keep the foot below the shank until you have the bars centered around the base of the shank. Then bring the foot up and push back until it snaps into place. There is a horizontal rod between the bars and the shanks locks around that rod. The rest of the feet are shanked.)
Oct 27, 2010 | Singer 5050 Mechanical Sewing Machine
Need interior diagram of Sunbeam MixMaster Model 2486
Here's the solution. The spring controls the beater eject button. The spring is mounted on the metal shaft and is oriented so that the straight side of the spring rests along the white plastic part adjacent to the shaft, and the curved side of the spring points outward and downward so that it will rest against the case when the unit is reassembled. See photo.
Dec 26, 2009 | Sunbeam Food Mixers
Furniture Logo
63 people viewed this question
Top Barcalounger Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Barcalounger Furniture Expert? Answer questions, earn points and help others
