Question about Exercise & Fitness
I am looking for greenfit motor board, please where can i get one.
    Top Expert:
  • 12,223 Answers
Go to www.fitnessrepairparts.com and get it
God bless you
Posted on Oct 15, 2013
Goodman furnace GMP-050-3 no power to vent motor
if you look at wiring diagram find ventor motor terminals and work your way back till find voltage . component not allowing voltage to pass is culprit. sounds like you spent alot of unnecessary money :(
Nov 05, 2013 | Heating & Cooling
Sears botched repair on my LG washer (Model WM2701HV). Replaced both boards but suddenly motor does not spin - only hums. Tech claims motor needs to be replaced but it was fine until they replaced the...
If a LG washer hums look into a part called a HALL SENSER it is a small part that go's in the motor at the rear of unit they are known to go and the humming is the give away ..If this helped please vote if you need more help please feel free to contact me..czerney@msn.com
Feb 02, 2011 | LG WM2701HV Washer
Machine won't agitate
the neptune unit has a control board located on the bottom of unit called a motor controller ...
it is possible the motor controller has failed.. prior to looking at it though check the main control board for failure such as a burnt resistor on board... usually jp4 resistor on board.. if the board looks good then probley going to be the motor controller board.... good luck to you...
Jan 09, 2011 | Maytag Neptune MAH5500B Front Load Washer
Outside unit works great, but inside fan unit\r\nwill not come on.
Hi, what you need to do, is pull the panel to get to the control board and blower motor. Take a look at the run capacitor mounted along side of the blower assembly to see if it is swollen or leaking oil. If so, replace it and try and start the motor. If its not to late if the run cap was bad, the motor will run. If its good, look on the board with a good light, look for the connections for the blower motor. Blower-1 and 2. You need to purchase a cheap electrical meter to check these leads for power when the outdoor unit is running. You can also kill power and see how hard it is to turn the wheel on the blower. If the motor has power to it, it is faulty. These will burn out if the air filter isn't changed on a regular basis, or they collect a lot of dust around the windings anyway causing them to over heat. Make sure this indoor unit doesn't have a door panel switch that kills power to the blower if its not on right or when you check it for power you will need to tape it down. More then likely, you have a bad motor. If you have no power to it, the control blower board is faulty. Please try and do these checks for me, and keep me posted. I will be here to help you solve this. Please be kind when you rate me, I thank you.
Sincerely,
Shastalaker7
A/C & Heating Contractor
Jul 02, 2010 | Ruud Central System Air Conditioner
I have a goodman gas furnace with ac. the motor caught fire, replaced the motor,turned the system on, the outside condincing unit comes on, the relay will click but the fan will not run. i checked the...
First - you should be very careful when checking for 'power' with a ohm meter. I'm assuming you are pretty mechanical inclined (if you changed the motor yourself), but - just be sure to 'never' put an ohm meter (set on ohms) across power.
That being said - if you (indeed) have no power coming out of the circuit board - I would check and see if you have power 'into' the board - and generally speaking if you have power to the board but not out to your motor leads you are probably safe to assume the board is bad but not in all cases.
NOTE: Since your motor caught fire - I'm not sure I wouldn't have a "Service Tech" take a look at your problem and the entire unit just to make sure 'everything' is ok.
good luck!
May 07, 2010 | Heating & Cooling
What does a fault F01 signify on a Hotpoint Ultima 7kg washing machine?
Error code F01 indicates a short circuit motor triac.
Thoroughly check all connections on the motor, the motor plug, and the electronic module board..
Look for a broken wire, or a bad connection.
Please rate my solution.
Thankyou.
Jan 22, 2010 | Hotpoint Ultima WF860 Front Load Washer
DC15 Animal brush motor not working?
Just had the same problem. Switches and motor checked ok, then found the circuit board on the left hand side of cleaner. The fuse (on the board) looked ok, but when removed and checked for continuity I found it had blown. The problem I have now found is that the fuse cannot be ordered only the complete board. Hope it gets the brush roller going again.
Mar 01, 2009 | Dyson DC15 All Floors - The Ball Bagless...
Won't extract water/Maytag Neptune MAH3000AWW
To be 100 % sure ,do this ,pull the whole face panel forward (remove the 3 screws on top face panel and may have 2 more in the back of the face panel)Once youve pulled the panel forward you will see your control board facing you.Look closely at the circuit board and look for a burnt circuit (CALLED R-11) .iF YOU SEE IT BURNT ,REPLACE THE WHOLE BOARD. I HAVE A COUPLE OF BOARDS AVAILABLE AND WAX MOTORS BUT I'LL NEED THE SERIAL NUMBER FIRST. Either way the board is easy to install the wax motor is a little more difficult.
Please Rate This !!!!
Jun 02, 2008 | Maytag Neptune MAH5500B Front Load Washer
Exercise & Fitness Logo
93 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
