Question about Minolta Office Equipment & Supplies
Dialta di2510 paper jam
  • Minolta Master
  • 6,161 Answers
Where? Which draw? bypass? Exit? Finisher. Fuser? These are locations which would help?
Posted on Jan 24, 2015
2 Suggested Answers
  • 170 Answers
SOURCE: My minolta copier Dialta Di
maybe the paper sensor actuator is not moving or mis align
Posted on Jan 14, 2010
Dialta di2510 not initializing
Unplug it from the wall, wait a while and plug it back in. If still not booting, Probably needs to have the firmware reloaded,or all the dimms (memory chips) need to be reseated, or the main board has failed. If you are not a tech, probably should call one.
Sep 02, 2014 | Konica Minolta Dialta Di2010 2510 Toner 2...
How to install Minolta dialta Di2510
Go to Konica Minolta Web site can use only windows 95 best is XP. If there is Windows 7 Go for it. This a legacy Minolta machine
Aug 24, 2014 | Konica Minolta di-2510 AFR-19 AFR19 ADF...
You must download the drivers from Konica's support website at the following link: http://kmbs.konicaminolta.us/wps/portal/web/home/home/businesssolutions
At the top of the page click on downloads
A new window will pop up for product self help support.
Type your model number Di2510 into the quick search box on the left side of the page and a link will appear to the drivers and documentation for your model.
Aug 24, 2014 | Konica Minolta Office Equipment & Supplies
I have a problem with my di183 copier.
Where is a paper jam located?Please relate detailed the jam location in fuser unit?in paper tray?in vertical transport?
Mar 30, 2013 | Minolta DiALTA Di183 Copier
Hw do i fix my minolta dialta di 552 for continuous paper jam
Where is it jamming, which draw are you using have you tried different draws or the by pass tray? Does it jam when copying versa printing? Have the draw rollers been cleaned? jamming in the fuser the hot part or under the drum before the fuser?
Mar 09, 2013 | Minolta Office Equipment & Supplies
Misfeed error but no paper jam in minolta di2510
Where is the miss feed detected 1,2,3,4 draw or bypass tray?
Oct 17, 2012 | Minolta DI2510 Black and White Copier
PLEASE HELP ME WITH CODE 0910
C0910 service code means that your tray 2 is not lifting the paper properly. Most often this is caused by the tray being loaded improperly. So to try and fix this I would open tray 2 and check the loading of the paper and correct if necessary. Reset the code by turning off then on the main power from the back left side of the machine. Leave tray 2 open until the copier warms up and says ready. Then close tray 2 and wait to see if the code comes back. If it does then you have a motor lift problem or the sensor that detects the lift is bad. You can always leave tray 2 open and inch or 2 so that you can still use the copier as this will keep the code from coming on.
Good Luck and Thank You for using Fixya.
Sep 13, 2010 | Minolta DiALTA DI2510F All-In-One Laser...
After making a lot of copies- Dialta 3010 copier jams every time
you probably need you fuser rebuilt. the heat roller melts the toner into the papew. it is covered in teflon. over time the teflon wears off anf toner sticks to it causing paper jams when the copier gets hot
Dec 30, 2009 | Konica Minolta DiALTA CF910 Copier
Minolta dialta di181 c1300 error
C1301 errors after setting up the Di181.
Solution:
Replace PWB-A, part number 1177-0106-03 for C1301.
Jul 30, 2008 | Minolta DiALTA Di181 Printer
Minolta keeps jamming
Hi Daryl, what does the paper look like? Is there a "nick" in the leading edge of the paper or any signs of damage to the paper? Remove it carefully an look, but be careful cause the toner isn't fused yet, so it will get on your hands and clothes.
Nov 15, 2007 | Konica Minolta DiALTA Di200 Copier
24 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
