Question about Microsoft Office Standard for PC
Microsoft Office XP fax templates
When I try to open a word fax template, it freezes upon opening. It eventually moves on to the item you clicked on but it will not type anything. I am using Microsoft 2000 SP4.
    Novelist:
  • 233 Answers
Go to the "Add and Remove Programs" in your Control panel. Do a "Change" and do the 'repair program' utility.
That should fix it, good as new.
Be sure to have your INSTALL disk handy.
Posted on Oct 13, 2007
SOURCE:
I can't open my docs yet I KNOW they haven't been deleted because I am able to email them. How do I fix this?
MS Word offers several different views in which you can read and work on documents.
The view you are using when you save a document will be the default view when you open that same document the next time.
Likewise, if you open a document created by someone else, the view in which they saved it will be the default for that file unless you change it and save it again.
You can change your default Word template, though, so that new Word documents always open in the view of your choice.
Close any Microsoft Word documents or windows on your computer.
Locate the \"Normal.dot\" file on your computer.
This is the default template for all new Word documents. If you are using Windows XP, navigate to \"c:\\documents and settings\\username\\application data\\Microsoft\\templates\", changing \"username\" to your user name on the computer.
For Windows Vista or Windows 7, go to \"c:\\users\\username\\appdata\\roaming\\Microsoft\\templates\", again, changing the username to your user name on Windows.
Right-click \"Normal.dot\" and select \"Open.\"
A new Word document will open, which is actually the default document template.
Change the view to the one you desire.
To do so in Word 2003, go to the \"View\" menu and click on the view you want to use.
In Word 2007 or 2010, go to the \"View\" tab and select a view.
Type something into the document and then delete it.
This allows Word to recognize that a change has been made to the template without adding any unwanted items.
Click the \"Save\" button or press the \"Ctrl\" and \"S\" keys to save the changes to your default Word template.
http://word.mvps.org/FAQs/General/SaveViewAndZoom.htm
Aug 29, 2013 | Microsoft Word 2010
How do I set up an out of office message in Outlook 2010?
You can create part-time or temporary 'Out of Office' automated replies in Microsoft Outlook. These can be set so that whenever you leave the office, an auto reply is sent.
This is useful if you have a high volume of e-mail messages and are expected to reply to them quickly.
You can fully customize your auto reply in Microsoft Outlook 2010.
Launch Microsoft Outlook from the Start Menu.
Click "New E-mail." Click "Plain Text."
Enter the message for your out-of-office reply in the main body of the text.
Click "File," then "Save As." Click the "Save as type" list and select "Outlook Template." Enter a name such as "out of office" and click "Save."
Click "File," then "Info." Click "Rules and Alerts," then "New Rule."
Click "Start from a blank rule," then "Check messages when they arrive," then "Next." Set "Sent Only to Me" in the conditions list and click "Next."
Select "Reply using a specific template," then choose "Specific template" on the next page as well.
Click "Select a Reply Template." Choose the template you already created and click "Open." Click "Finish," then "OK." All e-mails will now have the out-of-office reply. Disable it in "Rules" to switch it off.
Hope this helps
Oct 26, 2012 | Microsoft Outlook 2010
When I open Word 2007 to write a letter, or anything taking more than one line, each additional line is in double spacing. How do I change to single spacing as it did in Word 2003?
Your normal template has probably been edited to double spaced text.
To fix this you need to edit your normal template file - it will live inside C:Program Files/Microsoft Office/ Templates or a folder under this or something similar to this.
Open your template and change the line spacing to single, then save it over the existing template.
Feb 23, 2011 | Microsoft Office Word 2007 Home and...
How to print envelopes?
use the hp software ..and use the envelopes templates in the setup of the page ..or ...just open Microsoft office word ..and select the mailings and in the left side will be the envelopes template ..(office 2007)
Jun 03, 2010 | HP DeskJet 940c InkJet Printer
Printer prints a page then sends thru a blank page... prints page then blank page...
I posted this video a long time ago...hope it helps!
utube.png You-Tube video "WrxT2_T6JVA" placeholder (do not delete) utube.png
Good Luck!
Jan 02, 2010 | HP Photosmart C7280 Printer
My MS Word 2007 has been giving me problems for about a week or so. It's part of MS Office Home and Student 2007. The problem is that it keeps freezing up on me and I lose typed text. Eventually I can...
Rename all instances of your document template files (Normal.dotm or Normal.dot). This will prevent formatting changes, AutoText entries, and macros that are stored in the global template (Normalm.dot or Normal.dot) from affecting the behavior of Word and documents that are opened.Renaming the template will let you quickly determine whether the global template is causing the issue.
When you rename the Normal.dotm template in Word 2007 or the Normal.dot template in Word 2003 and in earlier versions of Word, you reset several options to the default settings. These include custom styles, custom toolbars, macros, and AutoText entries.
Jul 03, 2009 | Microsoft Office Professional 2007 Full...
MS word not responding
Rename all instances of your document template files (Normal.dotm or Normal.dot) This will prevent formatting changes, AutoText entries, and macros that are stored in the global template (Normalm.dot or Normal.dot) from affecting the behavior of Word and documents that are opened.
Renaming the template lets you quickly determine whether the global template is causing the issue.
Dec 15, 2008 | Microsoft Office Outlook 2003 for PC
Office XP Pro
The "Normal" template opens whenever you start Word, and it includes the default settings for your new documents... as well as any customizations you may have opted for along the way. Sounds like your version of the normal template now includes the text of this document.
On the File menu, click Open, and then navigate to C:\Documents and Settings\user name\Application Data\Microsoft\Templates and look for "Normal.dot". You may need to change the Files of Type drop box to "Document Templates" to see it.
Open the file, select all the text you see there and delete it. Save the file and close it. You should get clean pages now when you open a new document.
Alternatively, you can use Windows Explorer to navigate to that same directory and delete the entire Normal.dot file. MS Office will simply create a fresh one when you launch Word again.
Hope that helps!
Good luck.
Sep 09, 2008 | Microsoft Office XP Professional OEM w/...
Microsoft WORD pdf menus and pdf conversion facility
try this Deran 1. Open the Microsoft Office program (Word, Excel, Publisher, or Excel). 2. Go to Help > About [program name]. 3. Click Disabled Items. 4. Select Adobe PDF from the list and click Enable. 5. Quit the Microsoft Office program and then restart it. Note:Microsoft Office Applications disable add-ins as a failsafe if the application is prematurely closed (for example, system wasn't shut off properly or the application crashed).
Sep 25, 2007 | Computers & Internet
Microsoft Office Standard for PC Logo
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
