SOURCE: My old Kenmore sewing machine makes a loud squealing noise.
It sounds as if your machine needs a little oiling. If you have a clear machine oil (not 3 in 1). place a drop in the bobbin case area and if you will notice, you will see small holes on the bed and on the top of the machine. place a drop of oil into each of these holes. If you can take the top and bottom covers off, you can put a drop of oil every where you see a hole..some of the machines actually have the oil holes painted a red color. Also place a drop at the handwheel as well. Just remember when oiling, less is better. After oiling, run for a few minutes, if you feel it still needs a litte more, do the same, one drop at a time. After this, if you machine sets for a while, oil just before starting to sew, that way when you put the machine away the oil has been worked through and it should help prevent the squeaking when starting up again.
SOURCE: euro pro 9110 sewing machine doesn't work
The direct number to Euro-Pro's sewing machine phone reps is 1-800-361-4639. I've read of other people calling and Euro-Pro sends the parts they need (no charge).
SOURCE: Squealing noise from the right side of the machine when begin sewing
sounds like it needs to be cleaned. check the belt first.
SOURCE: Squealing noise Husquvarna 3310 sewing machine.
My Designer 1 started squeaking recently and, like you, I was concerned even though it sewed like usual. I emailed my tech. and he suggested either feed lifter mechanism or feed cam were the most likely causes - simple to repair but I would need to bring machine in for him to hear because there could be other reasons for the squeak. Well I did not have time to go then and there. Next day when I sewed, the squeak was gone!
At the time it squeaked I was sewing through several fairly thick layers (making a pot holder) and sewing very slowly. The next day I sewed normal cloth at normal speed but no matter how slowly I sewed, I could not get it to squeak. I will get it checked eventually but as long as it is squeak-less I'm not going to be concerned.
If yours squeaks all the time no matter what you are sewing then, yes, I think you should get it looked at. Be sure that nothing is rubbing against the body of the machine i.e. accessory tray and making the noise.
