Question about Lorex SG6163F Weatherproof Mini Color Camera
Wires cut need to rewire\ color codes for wiring
Wires cut need to rewire\ color codes for wiring please
How do I rewire a cut harness car radio of a chrysler town country 2010
If you have original cables match pins. Otherwise there should be a diagram or table (paperwork) explaining where to wire in the new to old wires.
Feb 07, 2015 | Chrysler Cars & Trucks
Wires has been cut under dash of a 1997 ford escort need help rewiring so car will run
HOW CAN THE WIRE BEEN CUT,
DO YOU HAVE TILT WHEEL, REMOVE STEERING COVER OD THE IGNITION STEERING AREA, LOOK AT THE WIRES, DO THEY LOOK LIKE SOME ONE CUT THEM OR THEY CHANGE COLORS DO TO A ALARM SYSTEM, IF THEY CHANGE COLOR, COULD BE THE AFTER MARKET ALARM RELAY THAT WONT ALLOWED YOU TO START, IF YOU DO NOT KNOW WERE IT IS, IS OK, OPEN THE CONNECTION AND REMOVE THE WIRE COMING FROM ALARM TO IGNITION SWITCH WIRE, FIND THE OTHER END OF THE IGNITION WIRE THAT WAS CUT OUT , SEPARATE FROM THE OTHER WIRE ALSO FROM THE ALARM, AND RECONNECT BOTH IDENTICAL COLOR WIRE TOGETHER AND IT WELL START, UNLESS YOU HAVE A SECURITY LIGHT ON THE DASH, CHECK THIS OUT FIRST., PROGRAMING MAY BE NEED IT OR OTHER PROBLEMS ARE THERE.
May 24, 2014 | Cars & Trucks
Rear light wiring.
All OEMs have their own common wire color coding. Look at and other Suzuki street bike tail light wiring to determine which color is the tail light/ brake light/ left and right turn signal colors. The ground will be the same color for all of these lights.
Dec 30, 2012 | 1986 Suzuki GV 1400 Cavalcade LXE
My car stereo was stole they cut the factory wiring harness from the durango i need to know the color codes of the wires please
That's hard to answer cause it depends on how far back on the wire harness they cut. Plus if you have a Bose system or not. I would highly suggest to take it into a stereo install shop to at least check it out but maybe install the new stereo.
There is a wiring color code that all vehicles use but if the wires have been cut to far back they will be different colors. If you have a factory amp then you will have to rewire for the speakers to bypass it.
I added below the color code. Make sure you disconnect your battery before you start wiring anything.
Please note: You can do major damage to your truck computer and other components if you wire it wrong.
Proceed at your own risk
moz-screenshot.pnghttp://i.ehow.com/images/a05/32/br/hardwire-car-stereo-800X800.jpg
Feb 26, 2011 | Dodge Car Audio & Video
My 2003 Durango has an after market trailer hitch on which the wiring converter has literally exploded leaving me with no tail lights and fried wire ends on the vehicle side of the converter. Since I am...
You should not have to rewire anything.
Hitch wires are just "pig-tailed" on to the original vehicle wiring. Just cut off the hitch wires cleanly and tape the cut end.
You have probably burned out the stop and tail lamp fuses also. Read you owner manual for fuse location.
Please rate is answer by checking the "Hands" below. Thanks j
Feb 09, 2011 | 2000 Dodge Durango
I have a envision h1981 lcd flat screen someone cut the signal cord off. its a vga hookup on it so i need a wiring diagram that would show me how to rewire a new signal cable to it or if all vga cables are...
They are usually the same! But be careful ok, I will check around and see what wires I have available but I did the same exact thing for another client..
Nov 26, 2009 | Computers & Internet
Seats wires were cut, between the two front seats and also from the drivers seat to the panel. Need to know instructions to rewire
what u need to do is count how many wires are cut and will the wires reach eachother like do you need extra wiring to make up the differance all the wires are in colors like blue and red black and white 2 colors per wire some wires are a single colre ie blu blk rd yl match up youre wires to each other blu to blu red to red etc you will need **** connectors u can get at any automotive parts store or even walmart will have these u will need 1 **** connector per broken/cut wire all u do is strip the end of each wire about 3-8ths long slide one end into the **** connector and crimp that side then strip the other wire of the same color about3-8ths of an inch slide it in to the corresponding color **** connector
Oct 10, 2009 | 1995 Mercury Cougar
Rewireing 93 harley davidson FXLR to 96 Handle bar
On the handlebar switches, Harley hasn't changed the color code scheme very much over the years but you really need a good schematic to know exactly how they are wired up. If you can find either a Harley service manual for a 96 model or a Clymer's manual, it would be helpful. I have a schmatic for a 94 FXDWG that should be alright for your 93 FXR but you need a schmatic for a 96 model bike.
Oct 07, 2009 | 2000 Harley Davidson FXD Dyna Super Glide
Rewire lorex SG6153P camera
I HAVE A SECURITY CAMERA GOT WITH THE WIRES RIPD FROM BACK OF IT 4 WITH WIRES 1 RED 1 WHITE 1 YELLOW AND 1 THICK BLACK WIRE HOW CAN I REWIRE IT?????
Jun 04, 2009 | Lorex SG6153 / Weather Resistant Mini...
Rewiring taillights for a 1990 corsica
The color coded wires are alike for both side with the exception of the directional lamp. The color will be the same although a different colored stripe will be on it.
May 27, 2009 | 1990 Chevrolet Corsica
Lorex SG6163F Weatherproof Mini Color Camera  Logo
Top Lorex Home Security Experts
Henry  Thomas
Henry Thomas
Lawrence Oravetz
Are you a Lorex Home Security Expert? Answer questions, earn points and help others
