Question about Bernina Artista 180
When I turn on my machine, it is on stitch #1, as usual. If I don't begin sewing in a minute or two, it switches to stitch #11 and won't allow me to change to any other stitch. If I begin sewing as soon as I turn on the machine, it will stay on stitch #1 unless I stop sewing. If I stop, it changes to stitch #11 and won't allow me to change stitches, so I have to keep turning off and on my machine to get any sewing done. I can't even change the stitch length, or it goes to stitch #11. Help!
  • Bernina Master
  • 7,365 Answers
The sewing machine needs to be checked, because it should not be change with out you changing it...
Posted on Oct 14, 2013
5 Suggested Answers
  • 55 Answers
SOURCE: bernina 1080 stitch length and needle jumping problem
you will most likely find that just adjusting the stitch length and width controls for a while will correct the problem (if the machine has been sitting idle for some time the stepper motor linkages seem to stiffen up a bit but i have good success with continual adjustment until they free-up.
also try switching machine off and on again to ensure it resets correctly.
the combination of both above fixes works 95% of the time - otherwise, as you mentioned circuit board and or stepper motor replacement may be necessary (however if both length and width are playing up it is unlikely to be an electrical fault).
scott
Posted on Jul 27, 2009
Tally Girl
  • 1122 Answers
SOURCE: my sewing machine was working fine until I changed
So is the stitch length now back on 2.5 for a normal straight stitch?
Or have you perhaps put it into a buttonhole sequence or something where it is sewing in the same spot.
Or have the feed dogs been disengaged accidentally, this would also mean no forward motion during stitching. Can you run it slowly, no thread, no presser foot and see if the feed dogs are going through their normal up and backwards movement to check this?
Have you got the manual to trouble shoot and find how to renegage the feed dogs if this is the cause. Sometimes it is a slide mechanicsm on the free arm or at the back of the main sewing area.
Posted on Apr 15, 2011
  • 166 Answers
SOURCE: Why doesn't my bernnina sewing machine change
Depends upon the model ... what model of Bernina are you having problems with ?
Posted on Jan 16, 2012
SOURCE: Bernina 1130 zigzag stitch for applique stops moving
have you tried changing the needle
Posted on Apr 25, 2012
Testimonial: "Will try that, thanks."
My machine keeps skipping stitches. I have had it werviced three times in the last n6 months, by two different repairmen, and it works for awhile, then starts backnup again. Any suggestions?
Usually, the first thing to try when a machine skips stitches is install a brand new needle. Also, be sure you are using the right type of needle for the fabric and thread you are using, ie ball point needle for knits, sharp needle for wovens, leather needle for thick fabrics/denim/leather... Needles do wear out with use, so changing needles frequently could be helpful. (Needles are the least expensive solution to most sewing problems!)
You can also try removing the upper thread. ALWAYS raise the presser foot and rethread from the beginning. Verify the thread path is correct.
What to Do If Your Sewing Machine Is Skipping Stitches
10 reasons for skipped stitches
Don Ignore Your Sewing Machine Skipping Stitches Simple Solutions
If the problem continues, it could very well be something within your machine that has not been appropriately addressed by the technicians.
Dec 29, 2016 | Sewing Machines
Machine does not appear to have a button to sew in reverse
try these suggestions
Reduce the stitch length to zero. The machine will stitch in place and form a locked stitch
1) rotate the material and sew over the same stitching. Leave the needle down in the work and raise the presser foot, then turn the fabric around.
2) decrease the stitch length to very small for a few stitches
OR
3) hold the fabric and prevent it from feeding at the beginning and end of a seam, which makes very short stitches
4) stitch about 1/2", raise the needle and presser foot, return the fabric to the beginning position and stitch over the first half inch of seam again. Do the same at the end
Jun 17, 2015 | Euro-Pro Sewing Machines
When I put the presser foot down and begin to stitch, the needle just keeps sewing in the same place, and the presser foot won't allow me to easily move the fabric.
Try removing the metal plate covering the bobbin case and clean out that area. I use a small paint brush. Sometimes if that area is dirty, the feeders won't move, and therefor won't pull the fabric.
Jun 13, 2014 | Singer 3116 Simple
Bernina buttonhole 730
Use your ruler and measure your button. Then transfer those measurements to your garment.
Use chalk to mark the center cut line of your button hole. Mark the end or stop point of the button hole per the measurement.
Practice on a scrap of the same fabric before you begin on your garment.
Set your machine the satin stitch zig zag at a fairly narrow width.
Begin satin on one side of the center line of the mark. Slowly stitch down that side until you get to the end. STOP. Widen your satin stitch to the max. sew about 1/8" and stop with the needle down on the opposite side to your first line of stitching. Turn the fabric, narrow the stitch to match original satin stitch. Sew slowly down the other side of the center mark. STOP, lengthen the stitch, sew 1/8" then do a couple back stitches.
That's one way. Another older way is to sew 2 or tree straight stitch lines around the center line. Remove then use a hand rendered button hole stitch after you cut the hole.
Oct 27, 2013 | Husqvarna Sewing Machines
Sewing machine won't stitch
try changing the needle
rethread the machine top & bobbin
if the suggestions don't work, it's possible that the machine
may have jumped time,, taking it to a sewing machine shop
the technican can tell you for sure
Jul 27, 2012 | Sewing Machines
When I begin a sewing stitch, the speed starts slow and increases every time. How do I change it so that I can begin a stitch fast or slow and control it without having to ease up to speed every time?
Good day!!!
please apply a some oil on the motor and other moving parts inside you sewing machine..
After that reboot the machine and used it....first try is persisted but when you used it continuously for at least 10 minutes your machine is OK...
thanks for using fixya
Jun 29, 2011 | Husqvarna Viking 1
Hello. I hope u can help me. I cannot get my stitching tight? If I pull the thread it comes right out. Thanks Jodie
You need to backstitch over the beginning and end of your stitching, Jodie. When you start out, manually turn the wheel to put the needle into the fabric. Push the foot pedal to stitch forward a little. Now, reverse over those stitches to nearly where you started stitching. Use the foot pedal to go forward again, stitch to where you want to end. Reverse again, just a 1/4 inch or so. Then take the fabric out and cut your stitching.
This backstitching keeps your thread from pulling straight out. You should always use it with straight stitches and general zigzag stitches. Don't use it with decorative or embroidery stitches, though, as it mars the appearance of them. But if you're doing any type of topstitching that uses straight stitches, backstitch in the area that will be in the seam allowance, ever so slightly, or your top stitching will pull out, too.
Hope that helps!
May 19, 2011 | Kenmore 16622 Mechanical Sewing Machine
VIK ROSE 45010050 Stitch size button will go up but not down in size...
Possibly the touch pad is bad. Are they any other buttons that don't work? Usually when the touch pad is bad other buttons won't work either. If only the stitch length won't work then the step motor for the feed is bad or you have a bad board.
Apr 20, 2011 | Husqvarna Rose
Can't select stitches 11-21
To select stitches 11-21 you position the stitch length dial on the "SS" setting , and the pattern selecting dial on the desired stitch number.
Mar 08, 2008 | Brother XL-5700 Mechanical Sewing Machine
Sewing Machines Logo
89 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Derek Massey
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
