Question about Crafts & Hobbies
Roller bar will not move - Crafts & Hobbies
  • Katie Rutt
    Katie Rutt Oct 14, 2013
    Roller Bar will not move when I turn on the Cricut Expression, I am able to roll it when it's not turned on.
2 Suggested Answers
  • 389 Answers
SOURCE: have a dyson dc07 -roller bar broken. have
It always feels like something must break as it's a really tight fit, but go to www.dysonmedic.com then scroll to the bottom of the page and click on DC07 belt and brushroll replacement guide. You'll find everything you need there. Good luck!
Posted on Jan 25, 2010
The brush bar on my v6 cordless is not working The bar that it goes on is it moving
Hello, this is Ava with Think Crucial.
There are a number of reasons why your brush roller has stopped moving. General maintenance to your vacuum is crucial and will help it work at peak performance.
First things first lets focus on the brush roller. Unplug the vacuum and turn it on its side. Look for any noticeable clumps of debris or hair strands that may be caught in the brush roller. Remove these obstructions, probably best to do so with a scissor if it's hair or long pieces of carpet fibers. After removing the debris try manually rotating the brush roller to uncover other hidden clogs. Another thing to take note of is the condition of the bristles on the roll itself. Are they loose or worn down? These are signs that your brush roller is in need of replacing.
While checking out your brush roll you might as well take a look at your vacuums belt. Your belt should be replaced about every three months. After regular usage, the belt will stretch out, lessening the tension on the brush roller. Lesser tension diminishes the brush roller's turn rate and speed. If the belt feels loose then it certainly is affecting your vacuums suction as well as your brush roll not moving at all.
You can purchase a wide variety of high quality Dyson replacement parts for your Dyson vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=dyson
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Jan 03, 2017 | Dyson Vacuums
ERROR CODE MC COMM ERROR, MC COMM TIMEOUT
The out-feed Rollers will move all the way towards the machine to start. There's a stainless static bar with bristles on it right after that. If you have that upside down it stops the roller bar from getting to it's home position. This causes that alarm. To test remove static bar and hit "C" to reset. It should clear. You may have to push the roller bar in manually. If you remove the front plastic cover there are two gears on the right. One on top has a strip of metal that goes between a c shaped proximity switch. If that Roller bar is restricted it won't go into the proximity switch.
Jan 30, 2014 | Formax FD-280-20 High-Volume Tab Delivery...
Roller bar is moving slowly,making sounds while turning and motor seems to be getting hot.
Sounds like you have something wrapped around the roller than should not be there.
Sep 26, 2013 | Electrolux Epic 6500 Vacuum
What do the numbers on the Kirby G5 beater bar end caps mean?
The numbers on the beater bar end caps are used to lower the brush down as the bristles wear down. When you bought the machine, the brush roller started in the 1 setting. One year later, after the bristles have worn down, you can move the numbers to 2, then 3, etc.
It's a pretty neat concept by Kirby, it prolongs the life of the roller brush significantly.
Hope this helped you,
Chris Jones
GoVacuum.com
Jan 05, 2011 | Kirby Ultimate G Bagged Upright Vacuum
'move fric.lever' message. Kindly please explain. Thanks
It is telling you to move the friction lever.
The friction bar holds the paper against the platen roller, it must be in the closed position to advance the paper.
The lever should be to one side of the roller.
Jun 29, 2010 | Dataproducts 8524 Matrix Printer
Have a dyson dc07 -roller bar broken. have
Jan 24, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
The roller bar area is not working
It sounds like the touchpad needs replacing. Contact me if you can't get it repaired locally.
Jan 09, 2010 | HP Compaq 236076-001 Touchpad
Does not move on carpet. The roller bar is
Remove the roller from the head and check the end bearings for binding (note how the belt is attached). Remove all of the wound up thread, hair, and string from the entire roller. Clean the bearings and lightly oil with 3in1 or similar. Check the belt for worn or burned areas (replace if so). Belt should be tight when reassembled. Clean the air passages of any potential clogs. Make sure all of the wheels turn freely--if any problems, remove the same debris from the bearings and lightly oil. Wipe away any excess oil. Hope this helps.
Nov 12, 2009 | Vacuums
Crafts & Hobbies Logo
50 people viewed this question
Top Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Debbie
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
