Question about Acer K130 LED Projector
I have pluged a dongle wifi Tp-link on my acer K130 projector, but I can't not see any AcerProjecor network? Is there a way to use an other dongle than the acer dongle with the acer k130?
Why does my TL-MR3020 Portable Wireless N Router Keeping dropping out a few moments after appearing to be connected to the internet
Why have you two routers connected to the same network?
1. TL-MR3020 Portable Wireless N Router
2. Three ZTE MF730M dongle (router).
The problem is the router does not know which route to choose, so remove one of them and it should stop dropping out.
Nov 29, 2014 | TP-Link Technologies TP-Link TL-MR3020...
3g dongle support
Hi
Seems like it needs to be configured, though not all tablets support dongles i.e Karbonn-Samsung Galaxy and lenovoA1000 & A30
First, (1) put 3G sim into dongle and connect dongle to tablet. You may have to wait several minuets for tablet to find internet, if it does not, continue as below.
2. Now go to 'settings' and select the 'More' option .
3. Select 'Mobile Networks' > 'Access Point' Name (APN) 4. Then select New APN option.
5. All you have to do now is make the following changes in the bracketed entities [ Name, APN and Dial Number]:-
-> Set the network name. Eg:- For Tata photon just write Tata or TP or anything, as you like it.
-> Set the APN,> search the net for your service provider's APN. Then write it precisely.
-> All the dongles come with dial number. Check your dongle purchase paper or the manual or just search it Google. And then fill the same here as the Dial Number, save and you are done. eg. For Tata Docomo it is #999 and Reliance it is #777.
NOTE:
After plugging the dongle, a default APN gets created in the APN setting's page.Try to feed the settings by creating a new APN.
Karbonn, Samsung Galaxy and Lenovo A1000 & A3000 tablet does not support dongle.
By far and large the above steps will work with all the dongles and Tablets. You could also go to 'You Tube' and seach for Video info which may be quite helpful. Regards Silverfox160
Ssssss
Aa
You can aaa
aa
a
Aug 27, 2014 | Irulu 7 Inch Android 4.1 Jelly Bean...
Linksys wifi droping suddenly
What i would suggest is get another wifi receiver dongle if that one fails its probably your laptop needs repairing if you have a friend that has one you can borrow from or you can get them cheap on ebay i had the same problem with a laptop and i just plugged in a dongle i got on ebay and it worked it doesn't have to be a lynskys it can be any wifi dongle receiver if tht fails your router might be damaged your ISP provider may be able to help you determine the problem for free they can run tests with you over the phone too see if the signal is reaching the router or maybe you could try hard wiring the laptop to router with an ethernet cable see if that picks it up if tht does its either the router or dongle or you might have broken the wifi built into your laptop... Hope some of this helps..Sean
Jul 02, 2014 | Acer C7 Chromebook
How to convert a tata photon in to a wifi connection
First, you need an internet gateway. Do you have already some kind of internet connection through DSL, CABLE Modem, etc? The TP wifi will first have to be connected to your network (wired LAN). Then, once that is done, you need a computer with web browser to access and configure the setting in the TP. There is a CD that comes with the TP. It contains "Easy Setup Assistant" program to configure your TP wifi.
Feb 15, 2013 | TP-LINK TL-WR740N 150Mbps Wireless Lite N...
Error 045 when setup the modem with Win7 64 bit, connection to network failed.
What the problem? i'm also using this router...
how you setting the router?using wifi or LAN?
BEFORE THAT,
DOWNLOAD HERE
RUN INSTALLER FIRST BEFORE CONNECT TO YOUR ROUTER.
connect line rj11 to link dsl,rj45 to your pc/laptop.(dont use wifi to setup the router)
then plug the power and ON the wifi router.
After that, check light for ADSL, WLAN INTERNET AND PORT(1 OR 2 OR 3 OR 4) IS BLINK
..IF light is okay and blink, then you can setup the utilities.
Is easy. TP-LINK get ready with software that you can setting the router as like professional with the secure encryption. For receiver I'm preferred you using tp-link also. Then you can use QSS function only just click button QSS..
May 27, 2011 | TP-LINK 300Mbps Wireless N ADSL2+ Modem...
I am using a tp link 8901g router. my desk top and one of our laptops both work on wireless but our acer aspire lap top finds the router but does not ask for the wap key but will not connect it will...
Try going into the system then device manager uninstall the wifi driver. Reboot the pc and it should auto load the driver when getting back on the desktop. Then see if it ask for the WEP key
The wifi driver will say 802.g 111 or something so you know its not the 10/100 network.
Apr 30, 2011 | Computers & Internet
Getting my vodafone dongle to work with my acer aspire one z5
Try pluging the dongle, installing the software that will autorun (it's in the dongle memory) and let the software scan for the device. If it failed to regognize it call the vodafone helpdesk. Sometimes the dongles have problems. I suppose that they will change it.
Stelios.
Feb 22, 2010 | Acer Aspire One PC Notebook
Acer K130 LED Projector Logo
48 people viewed this question
Top Acer Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Acer Office Equipment and Supply Expert? Answer questions, earn points and help others
