Question about GE Freezers
Compressor getting hot
Should freezer compressor get very hot when waiting for freezer to get cold.
  • 226 Answers
The compressor as well as the evaporator coils will get hot when the freezer is getting cold. Simple principle: Refrigerant gets cold and there must be an equal reaction, something getting hot. Just like the heat transfer in your car with the engine heating the radiator which dissapates the heat. hope this helps you, Rick
Posted on Apr 26, 2009
Product thawed to cold in freezer...
If you had the door open for that long you will need to unplug and allow the ice buildup that happens when door is left open to thaw. After this you need only to plug the refrigerator back into the power source.Let me know what happens It is not going to work correctly until this is done. Sea Breeze
Jun 15, 2013 | Frigidaire 20.6 cu. ft. / 583 liter...
Frigidaire freezer compressor is hot to the touch and not cold inside
If the compressor is hot, then the temperature inside the unit may be compromised if there is a sealed system issue or a restriction in the unit. Call a professional to be safe.
Jul 26, 2012 | Frigidaire 14.1 cu. ft. Upright Freezer...
Not getting cold enough on the inside... the exterior too hot to touch.. why could this be?
Compressor relay could be fried. Feel the compressor. If it is too hot to touch then check your relay. The relays contacts could be welded together making bot windings stay powered up and overheating the compressor causing compressor shutdown on overload.
Sep 02, 2011 | Whirlpool 14.8 cu. ft. / 419 liter Chest...
I have a Artic Air White Reach In Freezer. It is not blowing cold air from he top where the cold air comes in. Freezer was at 60 degrees F. I turned the defrost switch to make sure it wasn't in...
Is the freezer itself getting cold.To blow cold air.the freezer should get cold/friezed.the cold air blows from freezer to fridge side.first the freezer side gets cold, then when the freezer side gets enough cool to its set cooling temperature, at that time the defrost cycle starts.In defrost cycle the fan in the freezer starts running and the cool air from freezer starts going to fridge side.There is a ventilation passage between fridge and freezer from where this cool air passes.---------------- If in your case, the freezer is getting proper cold, but its not blowing cold air from freezer to fridge, then possibility is that, there is a blockage in ventilations.But if ventilation its clear, then its defrost problem.First try manual defrost reset procedure. The procedure is as follows: ---- First unplug the unit from main power outlet. Then empty whole unit completely. Then keep both the doors open. Wait for 24 hours. All the ice collected on the coils and in the freezer section will get melted. Clean the water from the sections. Then Connect the power cord of the unit to main power outlet after 24 hours/.Then set the temperature to normal in both fridge and freezer section. It will take near to 4 hours to get run in its proper cooling cycle. Then check, if the problem returns again. Then its defrost board problem. ------------------------- BUT if in your case, the freezer section itself is not getting cold, then the problem is compressor related.The compressor is the part which cools the freezer frost.In the compressor, there is a refrigerant to cool the freezer.If the compressor gets weak or the refrigerant gets low, then it will not cool the freezer, if the freezer is not cool then it will blow warm air from freezer to fridge, in defrost cycle.In that case, the compressor is faulty and its the cause of problem.------------ So you will have to first check , that is your freezer getting cold or not.as per that you can start the troubleshooting.------------------
You can get required parts from from online sites like: --- www.repairclinic.com or from searspartsdirect online site. --------- This should help.Thanks.Helpmech.
May 01, 2011 | Arctic Air Freezers
My chest freezer recently beginonly freezez a little at the top but it 's just cool like a fridge at the bottom
Hi and welcome to FixYa. I am Kelly. This freezer uses the chassis to dissipate heat so that the freezer can freeze. There is not a condenser fan. So what you have is a basic and usually trouble free freezer. If your freezer is not cold at the bottom of the unit there can be a couple of causes:
1. The compressor is running slow due to the rotor dragging on the compressor stator.
2. The PTC relay contacts on the compressor are getting hot and the compressor is shutting off before the temp control cycles the compressor off. Usually that is how PTC relays fail.. one hot contact and the unit cycles much more rapidly than usual and eventually the compressor stops running completely.
3. The system Freon has leaked out of the system and the unit is running on low pressure. (If this is the case the symptom will only get worse and very soon)
4. There is a very remote possibility of the cold control being damaged from an external bump by someone due to the fact that it is located outside the freezer compartment on the chassis.
Thanks for choosing FixYa. Kelly
Jul 09, 2010 | Magic Chef Chest Freezer MCCF5WBX
Freezer is not cold and evaporator fan (inside
ok well... those pipes coming from your compressor one of them should be hot. if not your compressor is not running.
Nov 10, 2009 | Amana Freezers
Freezer not getting cold
Alissa,
Try placing two or three jugs of water in the freezer and wait 36 hrs. before opening.. If the water is frozen solid you have no problems.. if its not frozen, the call a service tech..
Jun 22, 2017 | GE 16.7 cu. ft. / 473 liter Upright...
Compressor very hot on Kenmore 7.5 c.f. upright freezer. It is too hot to touch and smells like burning paint, but stayed cold inside. Wondering if this is a bad compressor and about how much it costs to...
Compressors will normally run hot to the touch, but should not have a burning smell. If the compressor does need to be replaced you would be better off getting a new freezer. Compressor replacement with the labor can run into more than a new freezer.
Aug 27, 2009 | Kenmore Freezers
Chest freezer repair
I had the same problem with an upright and so I bought a piercing valve and charged the compressor with 134R and has been working great since.
Jul 05, 2009 | Freezers
1991 Kenmore 16 model 253 in storage for 7 years. Plugged it in and turned it nn last night and seemd to run fine, nice and quiet just like before. Today it is not cold and the comressor seems to be r
If the freezer was stored and not running for 7 years it may have lost coolant.  Since the compressor is running recharging the coolant may fix the problem.  Hot compressor might indicate low coolant since its motor is immersed in it.
May 30, 2009 | Kenmore 19.7 cu. ft. / 558 liter Chest...
Freezers Logo
376 people viewed this question
Top GE Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
John Tripp
John Tripp
Are you a GE Freezer Expert? Answer questions, earn points and help others
