Question about Exercise & Fitness
Proform crosswalk 400e
I can power up my treadmill but when I push the start button the belt will not turn, does this sound like a display or motor?
    Top Expert:
  • 12,223 Answers
See the video and fix it. God bless you
Lube the rollers bearing front+back and test the drive belt motor, and replace it if necessary.
Posted on Oct 15, 2013
5 Suggested Answers
  • 64 Answers
SOURCE: Proform Crosswalk Dual Motion Cross Trainer
I think you are talking about the front roller. It has a rubber sleeve that helps to grip the walking belt. Sometimes you can tighten this enough to keep it from slipping but you run the risk of overtightening and damaging both rollers. We recomend replacing that roller.
Posted on Nov 18, 2009
  • 31 Answers
SOURCE: My treadmill Proform Crosswalk 400e feels like it
If it feels like you are walking/sliding on ice, the walkbelt or the motor drive belt is loose.
Posted on Jan 16, 2010
  • 148 Answers
SOURCE: if i let my proform 400e crosswalk plug in for
It sounds like the display is overheating, look for an opening around the housing and check that for dust. The vent holes that are there to keep the temperature down might be clogged by dust etc, this will cause overheating and malfunctiion.
Good luck and please rate, thank you!
Posted on Feb 03, 2010
SOURCE: My treadmill Proform Crosswalk 400e stop, speed
we have the same problem, did you solved it?
Posted on May 07, 2010
I have a proform crosswalk 400e, and the circuit breaker on the treadmill trips whenever I plug it in
Many motor may have two stages, the first starts it turning and then the second stage takes over to keep it running. The 2nd stage of the motor may be faulty and drawing two much current or leaking current to the earth. Your breaker may not be the correct rating for the machine and needs uprating.
Something could have slipped in or moved around that could be jamming the belt or something else in the machine preventing it from starting up and causing an overload that triggers the breaker.
Feb 15, 2015 | Proform Crosswalk 400e Treadmill Total...
Why won't my treadmill incline or decline?
Hi there, checked both upper and lower bolted connections, and check that lift motor hasn't cracked and frame is intact with no blockages to a possible scissor arm-lift assembly underneath the unit ? If this all checks out, maybe a small gearbox on the lift motor failed internally. Good luck.
Feb 02, 2015 | Proform Excellent Condition Pro-form 400e...
Proform crosswalk 515 control board works but belt won't move/
lube the deck belt, you have deck worn, proceed in according with the instruction manual maintenance. 2) check the drive belt and replace it if necessary and tight 3) tes the input voltage motor, if there are the motor need repair or replace 4) test the output voltage from main board, for input voltage for the main motor, if there are NOT, the board is faulty.
Try if you can RUN the software calibration for diagnose and troubleshooting.
sincerely. God bless you.
Apr 28, 2012 | Proform Crosswalk 500 Treadmill
If i let my proform 400e crosswalk plug in for long time the display dont work.
Feb 03, 2010 | Exercise & Fitness
My treadmill Proform Crosswalk 400e feels like it is going to throw me off. Is the belt slipping?
Jan 15, 2010 | Exercise & Fitness
Recently purchased the Crosswalk 570. Assembled
recently purchased a crosswalk 570 treadmill and used it and it worked fine but when we tried to use it today the machine made a strange noise under the hood. we noticed that the belt on the track was slightly rubbing against the hood. How can we fix it?
Jun 11, 2009 | Proform 575 Crosstrainer Treadmill
Exercise & Fitness Logo
122 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
