Question about Samsung SF-5100 Plain Paper Laser Fax
Fax just has RX on it and nothing comes out. - Samsung SF-5100 Plain Paper Laser Fax
The fax is going but not coming i check the system setup please any boldy he know about system please tell me in detail how select and which is select
Posted on Nov 21, 2013
Trying to send a fax and get the TX #0259 what does it mean and what do i do to be able to send the fax
tx/rx/#0259 is just the number of the fax sent or recieved and the next one will be 0260,it has nothing to do with the fax sending!Make sure the line is connected in the L on the fax and that there is a dailing tone!Good Luck!
Apr 07, 2010 | Canon FAXPHONE L80 Laser
I cannot receive faxes. The machine rings, the
check to see how the rx mode is set up as it may be set to manual it should be auto.. this means if a fax comes in you will have to lift phone or pressthe start button to receive the fax in manual mode whereas the auto or fax mode will turn the fax on automatically
Aug 13, 2009 | Office Equipment & Supplies
Cannot fax or receive fax
The modem card in our fax machine needs replacing, we now have it in for repair. Thanks
Jan 07, 2009 | Samsung SF-5100 Plain Paper Laser Fax
Need to change my ring tone in Fax Canon laser class 2050 G3
Press dataregestration,use the arrow to go to rx settings,select rx settings with the set button,go to incoming ring,select and switch it to on,and then cange the ring count to the amount of rings you desire.
Jan 06, 2009 | Office Equipment & Supplies
Fax Report Question
i believe it means rx receive and tx transmitt
in rs 232 communication (serial communication modem fax etc) line 2 is tx (transmitt and 3 is receive rx hope that helps
Dec 30, 2008 | Brother IntelliFAX 2800 Laser Fax
How do I turn on the Fax conformation
you need to go into rx setting and turn rx report back to on,
and go to TX settings and turn Tx report on.
this can be found in menu, device settings, fax setting, (tx and rx report will be shown) change it from there
hope this helps
Oct 16, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Problem receiving fax from outside source . phone rings acknowledges receive on screen but no fax comes through. other source sends faxes to other sources no problem & i receive faxes from other...
In the last statement you said you RX faxes from other sources? which means you can't RX from one or a certain source??
1- could be area code
2-could be your memory is almost full and their faxes are too long
Jul 31, 2008 | Samsung Office Equipment & Supplies
Error message
when you look at the front of the fax. above the paper cassette there is a gray,blue cover where the paper comes out when receiving or coping , that cover needs to be seated properly there is a mag switch that will shout down machine till it is in place.
Never have I seen this sensore go oit just the cover is out of position,
hope all will be OK
Jul 23, 2008 | Sharp FO 5700 Plain Paper Laser Fax
Mx300 fax / printer
I found this on Canon's website.
Remote RX If the fax interrupts telephone conversations after the initial sixty seconds that it uses to monitor for fax signals, change the Remote RX ID number. The default Remote RX ID number is 25. See the folloing steps to change the Remote RX ID number.
  1. Press the <FAX> button to enter the Fax menu.
  2. Press the <Menu> button.
  3. Press the left or right arrow to select [RX SETTINGS], then press <OK>.
  4. Press the left or right arrow to select [REMOTE RX], then press <OK>.
  5. Press the left or right arrow to select [ON] or [OFF], then press <OK>.
    Note: The default setting is [ON].
    1. If [Remote RX] is set to [ON], a window will appear displaying the current REMOTE RX ID.
    2. Use the left or right arrow to select the preferred ID value (from 00 through 99).
    3. Press <OK> to set the ID.
  6. Press the <Fax> button to return to Fax standby mode.
If the fax continues to interrupt telephone conversations after the Remote RX ID number was changed, turn off Remote RX. The default setting from the factory is ON. See the folloing steps to turn off Remote RX.
1. Press the <Menu> button until [FAX SETTINGS] is displayed.
2. Use the [ left.gif] or [ right.gif] to select [RX SETTINGS] then press <OK>.
3. Use the [ left.gif] or [ right.gif] to select [REMOTE RX] then press <OK>.
4. Use the [ left.gif] or [ right.gif] to select [OFF] then press <OK>.
5. Press <Stop/Reset>.
Apr 09, 2008 | Canon MX300 Office All-In-One Printer
Canon Fax JX200 - fax interupts phone calls
Canon Support suggest changing the Remote RX code or turning off remote RX.
Goto fax settings -> RX settings-> remote RX
Nov 22, 2007 | Canon FAX-JX200
Samsung SF-5100 Plain Paper Laser Fax Logo
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
