Question about Whirlpool RBD305PR Electric Double Oven
Oven turns off. After running for a while the oven turns off with all power to the oven off. The first couple times it would turn back on in a few minutes with the clock reset and the PF display. Presently it stays off and doesn't return. I checked the homes circuit board for the oven and it was fine. I would like to see if I can replace a thermal fuse or something easier than the entire oven.
  • 87 Answers
SOURCE: display
Need new electronic module
Posted on Jun 14, 2007
wbwill
  • 68 Answers
SOURCE: After usung the self cleaning function the oven no longer works
Check for correct voltage at plug, in the mean time the oven will be disconnected from any power, see if it resets with no power for 10 minutes
Posted on Nov 13, 2008
SOURCE: Whirlpool Double Oven RBD305PDB7 - Upper Oven Won't Heat
I have the single oven of this style and I had to replace the thermocouple (part number 4450934) on the back of the oven three times (used the cleaning cycle three times). After using the cleaning cycle, the oven would not heat so each time I had to pull the oven out from the wall to access the back so I could change the part. Once a new part was put on the back of the oven, it worked fine. To pull the oven out, open the oven door and look down by the doors hinges. On each side you will see a screw that's holding the side molding on. Remove the screws and then the molding. That will give you access to the screws that hold the oven into the framing around the oven. Remove the screws and then you can pull the oven out to access the back to change the thermocouple. The oven is heavy so you may want some help to get out. It is not a one man job, maybe a one man and wife job. It is heavy. I hope this helps. Better late than never.
Posted on Nov 24, 2008
ginko
  • 19396 Answers
SOURCE: oven won't heat
Unplug the power cord for thirty minutes, this should reset the oven.
If this still does not work do the following:
Press clean and then cancel. This will reset the appliance.
If the error does not clear , then during the self cleaning cycle, the high temperature has probably damaged the temperature sensor probe, and it must be replaced.
Posted on Dec 03, 2008
heatman101
  • 43501 Answers
SOURCE: OVEN TURNS ON BUT WONT HEAT UP.
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Posted on Jul 30, 2010
The fan runs when power to the cooker is on but the oven itself is not switched on.
Probably the cooling fan. There is a cabinet thermostat on most ovens these days (Especially wall or underbench models) to keep the cooling fan running after the cooking has finished and oven turned off. This fan will run for a few minutes to cool down the outside of the oven so it doesn't burn / discolour the surrounding cabinet or workbench. If the fan stays on all the time, I would say that the thermostat has probably jammed in the run or on position.
Mar 21, 2017 | Ovens
Blomberg BEP 906. After power went out a couple
Hello.
When baking or cooking common foods in your oven, it is important that the oven heats to the proper temperature. Otherwise, the food in your oven could become over- or undercooked. The electric ovens are able to be calibrated if only slightly off, however, if the temperature is 25 degrees off or more, you should replace the oven sensor. The oven sensor is the device in the oven the detects the temperature. The control board increases or decreases the oven temperature, depending on the oven sensor reading. Before calling a repair technician, attempt to calibrate your oven or change the oven sensor.
Instruction
1 Turn on the oven and set the temperature to a medium-heat setting, such as 350 degrees.
2 Allow the oven to preheat and then open the door and insert the oven thermometer.
3 Allow the oven thermometer to remain in the oven for a few minutes and the look at the temperature reading, comparing it to the oven temperature setting.
4 Recalibrate the oven if the temperature is only slightly off, or replace the oven sensor if the temperature is greatly off, such as 25 degrees or more.
Calibrating the Oven
1 Turn off the oven to prior to calibrating.
2 Press and hold the "Bake" button until the calibration settings are displayed on the display.
3 Use the arrow buttons or "+" and "-" buttons to adjust the temperature the number of degrees that the oven is out of calibration.
4 Press the "Start" button to save the calibration settings.
Replacing the Oven Sensor
1 Unplug the oven from the wall or cut the power to the oven in your breaker panel.
2 Open the oven door and remove the oven racks.
3 Locate the oven sensor, located at the top-center of the rear oven wall.
4 Remove the mounting screw securing the oven sensor to the wall and then pull the oven sensor away from the wall.
5 Remove the cable connected to the terminal on the rear of the oven sensor and then discard the oven sensor.
6 Connect the cable to the terminal on the new oven sensor and then reposition the oven sensor and secure it using the mounting screw.
7 Replace the oven racks and then restore power to the oven.
Thanks.
Dec 23, 2011 | Ovens
This oven has always had a loud fan noise when it was on or during cooling off. A couple of times lately I have turned it on and it has only had a quiet hum. I've turned it off and turned it back on a few...
Anonymous, we're sorry for the inconvenience. We would like to discuss this further with you. Please email us at Whirlpool_Reviews@Whirlpool.com at your earliest convenience with your name, address, a phone number and best time to reach you along with your model and serial number.
Oct 21, 2017 | Whirlpool GMC305PRS Stainless Steel...
While cooking on my GE electric oven today I spilled water over the stove top by accident, now the iginite pilot wont stop sparking, what can I do to fix it? other than unplugging the oven as a quick...
If it's just water, unplug it for a couple of days and turn the switch back and forth a few times during these couple of days. The water should evaporate and your cooktop should start working again.If this did not help - one of the burner switches (or assembly with all switches and wiring, depending on model) will need replacement
Apr 03, 2010 | GE JKS06BFBB Electric Single Oven
Our electrolux eob5630 oven keeps turning off
its the thermal cut out. replace it. ISOLATE oven.
slide oven out a few inches, remove knobs, remove front panel(two screws)
you will only be able to pull panel 3-4" due to wires.
Cutout has 2 blue and 2 white wires..
you may need to snip a couple of cable ties.
Put new cutout in one wire at time( easy to forget where they go)
Tidy up wires. Put cover back. Secure oven in hole.
Turn on power. Reset clock(otherwise won't work)
Done 10 minute job
Jul 19, 2009 | Electrolux EOB5630 Ultrafan Electric...
When oven heats up the fan gets really loud and doesn't turn off for a long time
if your oven is fairly old, dust might be the enemy. FIRTS Turn off the breaker on your house electrical panel that feeds power to the oven before doing anything. Do not electrocute yourself!!
Remove the control console bezel where the control panel for your oven is..it's probably held on by a few screws. You'll see the fan is there somewhere inside the enclosre, it's purpose is to keep the circuit board cool but the fan grill is probably clogged with dust...remove the fan from the enclosure...try using a vacuum to get the dust out...you might need to use a small brush to loosen the dust film, clean the fan blades while you're at it. Reassemble and turn on the power ...you'll probably find the fan runs much quiter...good luck
Jun 08, 2009 | GE JTP15 Electric Single Oven
Error code E3 - F3 on Whirlpool oven, RBS275PDB12
Error E3-F3 says that the Oven temperature is too high(Clean mode).You might have to replace the Oven Temperature Sensor(RTD).
Apr 19, 2009 | Ovens
Smeg oven SA392EB cannot reset clock
Turn off at mains, turn on again. 0:00 will flash press the manual op key ( on mine button on right) use +/- keys to set the time. Don't use buttons with wavy lines as they are for setting auto cooking time.
Oct 31, 2008 | Smeg SE399X/5 Stainless Steel Electric...
Child lock code -5- has appeared.
Here is what worked for me.
Turn left to light on, then off
on/off (light)
on/off
on/off
(4-5 times)
do not run through the complete cycle of options
just to the light and back off.
Ken
Aug 16, 2008 | Neff U1661 Double circotherm super...
Whirlpool RBD305PR Electric Double Oven Logo
35 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal De
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
