Question about Refrigerators
Crisper drawers freezing
There is frost on the rear wall up to the shelf just above the crisper drawers. It is a brand new fridge, so there was only one thing in each drawer, and both things froze. Meanwhile, food on the top shelf is still rather warm.
    Champion:
  • 210 Answers
Probably defrost problem.
Posted on Oct 15, 2013
  • 42 Answers
SOURCE: kenmore elite fridge crisper drawer freezing stuff
If you have a side by side model you need to look at the refrigerator compartment wall on the left of the bottom drawer and move the slide control to the warmer/fruit/vegitable setting instead of the meat setting.
I hope this helped. Please rate my help or ask for more help please. supertechks
Posted on Apr 06, 2008
SOURCE: Vegetable and fruit crisper drawers freezing foods
I had the same problem. Apparently the problem is the main control board. According to the technician that came out to fix mine there is a design flaw and these boards are very sensitive and can blow a circuit or malfunction from the slightest power surge. What happens then is that the control board doesn't "tell" the fan to turn on and off at the right time so the fridge and freezer warm up too much before the fan kicks in and then it cools everything down but since the fan isn't running at the correct intervals and circulating the air all of the cold air settles to the bottom which causes the produce in the drawers to freeze while the top shelves get warmer. I had done a fair bit of research before calling GE and came to the conclusion that this was a common problem. So I pressed them and was able to get the fee for the part waived (before I made the service call appointment) which was around $150. The part now has a 5 year waranty which I find funny, because I'm not sure why it wouldn't have that upfront as my refridgerator is only 2 years old. Whatever!! Unfortunately, unless you have indepth knowledge of refridgerator repair there is no way around the service call and labor. Anyone buying a new model of refridgerator (any company) should consider an extended waranty. The service tech also told me that all refridgerators made after 2001 are required, by law, to have an electronic mother board which in all likelyhood will fail at somepoint prior to when you are ready to buy a new fridge!
Good Lucak!
Posted on Feb 11, 2009
  • 1218 Answers
SOURCE: Salad in drawer is freezing
Good day,
One user claims that the return air vents or vent located at the bottom rear of the fresh food compartment, have collected enough junk to block the cold air from returning to the freezer compartment. You can clean them out but I cannot verify that solution.
The crispers are located in the coldest part of the fresh food compartment.
This problem can occur when the machine gets light usage especially in colder weather, when the machine running time drops and the air in the fresh food stratifies, causing to cold air to pool in the bottom.
Normal may no longer be normal. Controls by their design will tend to run colder as they age. You might try tweaking the control warmer.
Patience and time are the most important tool you have to work with in dealing with this issue.
Posted on Dec 04, 2009
iwillfixforu
  • 619 Answers
SOURCE: puddles on top shelf and under crisper drawers
This is not a major repair and also a very common problem. You will need to turn unit off and remove everything from inside the freezer. After this remove the back panel of the freezer and you will see ice built up at the bottom of the coils. You will have to remove all this ice and clear the defrost drain trough and tube. After the ice is removed you will see the defrost drain located about midways. Use a hair dryer to melt this then take a cup of very very very hot water and pour a little in the tube. Let stand for 5 minutes then dry it up real good and repeat. Do this till the drain clears and water flows freely. Then reassemble and you are good to go.
Posted on May 28, 2010
MNTECH
  • 1543 Answers
SOURCE: Hi, my GE refrigerator has ice developing on the
Unplug refrig. Empty all food from freezer side and remove shelves from freezer. Remove back metal cover from inside freezer. Melt frost with a hair blower. Examine defrost heater at very bottom of the coils you defrosted. If heater coil inside glass tube is broken, replace defrost heater. (note: replacement may look different, but insturctions included with replacement address that) If heater is not broken, replace the small white pencil shapped sensor at the top of the cooling coils.
Posted on Dec 26, 2010
I have a 601 R sub zero, my veggies are freezing on the shelf above the crisper
Check if Your fridge has ice or moisture on the back wall, behind that drawer, and if service light or vacuum condenser lights are on, if so : you will need to go thru this repair I show on my youtube chanel. Hope It helps. How To Replace Sub Zero Evaporator HD 1080
Jan 04, 2015 | Sub-Zero 601R
Why are only drawers in fridge cold & not making ice?
Contact a professional. Sounds like either your damper door is not operating correctly and not letting enough cool air from the freezer enter, or there is an air leak that is making ice form .
Aug 12, 2012 | Frigidaire FRS3R5EMB Side by Side...
Water in wood's fridge
If you have the wire metal shelf model, there is a wrap around cooling plate (back and two sides) at the top of the inside. The frost that forms on this while it is running melts off after the compressor stops and the water runs down, into the drip channel, and out the drain hole at the center of the channel on the back wall. Clean out that hole so the water will flow out instead of down the walls to the bottom of your refrig.
If you have the glass shelf model, you have to remove the metal cover at the bottom back of the refrig and clean out the defrost drain hole located there.
May 21, 2010 | Refrigerators
I can't get the crispers and shelf back in after cleaning.
The bar goes into slots right above the drawers and under the shelf above the drawers. It's not obvious to see at first. It's at the very front of the shelf. You have to slide one end of the bar in first then the other side. The bar sticks out a little on each side so it can sit in the groves on the side walls of the fridge. For the longest we tried to put it underneath the drawers even though we knew it wasn't right. Hope this helps. The Whirlpool website can give you a parts manual if you enter the model number.
Jan 24, 2010 | Refrigerators
Fridge freezes up and then meltsw
I FOUND A PROBLEM WITH A COUPLE OF THESE THAT THE AIR FUNNEL ALONG THE BACK WALL WAS SEPERATED FROM THE FLOOR OF THE REFRIGERATOR REMOVE THE CRISPERS AND LOOK AT THE BACK WALL. IF THERE IS A GAP AT THE BOTTOM AIR DUCT APPLY SILICONE {FOOD GRADE ONLY} TO SEAL THE GAP
Jan 12, 2010 | LG LRBN20510WW Bottom Freezer Refrigerator
Amana Bx22s5W freezes food in the crispers
I've had the same issue with an Amana BX21TL. In my case, the problem was that the various air flow adjustments were all directing the cold air to the bottom of the fridge, underneath the vegetable crispers.
What I've done to fix this was:
1- Made sure there was a tight seal between the vent opening at the back of the fridge (at about mid-height) and the rubber/plastic duct that directs air to the meat/cheese drawer.
2- Made sure that the adjustable opening at the back of the meat/cheese drawer was fully open.
3- Made sure that the adjustable opening at the back of both vegetable crispers were fully open.
Hope this helps.
Jan 25, 2009 | Amana Refrigerators
Ice forming on the a shelf in my refrigerator
Hi .Thanks For The Question. You Probably Have A Drain Problem, From The Freezer TO The Back Of The Fridge. Pull Fridge Away From Wall ,Remove Back Panel Clean All Coils. Locate Drain Hose From Freezer. Clean Tube. And Fridge Is A Bit Too Cold
Aug 23, 2008 | Maytag MSD2656G Side by Side Refrigerator
Kenmore elite fridge crisper drawer freezing stuff
Apr 05, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Freezer/water not coming out
An Ice/thick frost build up on the back wall of the freezer if a side by side .The tank will be behind the crisper drawers you will see it frozen block of ice verses water in it you can tap it to see if the water moves.. Your water inlet valve on the disp. side maybe bad as well. Is the refrig section cooling ok??
Feb 11, 2008 | GE GSS20IEM Side by Side Refrigerator
Refrigerators Logo
195 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
