Question about Craftsman Garden
Model 358 797170
DOESN'T START, NO GAS AT CHOCK
Why does my Briggs & stratton 24 hp intek v-twin **** and pop at full throttle causing black smoke out of the exhaust?
Does it do this when you start it or turn it off? If yes to either one you must install a gas chock in the fuel line. It's a valve. You turn the valve off and let the engine run out of gas. When starting you turn it on obviously. By draining the carburetor of gas it won't overload anymore and backfire when turned on/of f.
Sep 17, 2014 | Cub Cadet Garden
Will start with chock on but wont stay running with it off
the idle jet or the float valve is blocked
you need to strip the carb and unscrew the jets and clean them
i use small interdental brushes ...
Mar 23, 2014 | Stihl Blower Handle Moulding Bg Sh 45 55...
My MAC 3227 trimmer will start an only run for a short time (less than a minute). It needs for the chock to be in the half chock position to start. If I move the chock to non-chock it stops. If I...
remove the carburator.. It's plugged.
disassemble and soak the body in fresh gasoline for about 10 mins.
Blow out all the ports with small engine carb cleaner and reassemble.
Drain the gas tank , clean it and refill with fresh gas mixture
It doesn't take much to clog those little carbs
May 23, 2011 | Garden
2005 vt750 shadow aero has been sitting for 8 month I put stalbe in the gas befoe sitting , this week before starting i replaced the gas with fresh gas and drained the oil and replace it with the battery...
I assume this is a curbreted model. Most likely the pilot jet is plugged. Pull the carburetor and clean the jets and passages with the proper tools and cleaners. Do not use wire to clean the jets, use an appropriate carb cleaner or the proper jet drills if you have/know how to use them.
Oct 30, 2010 | Honda VF 750 S Motorcycles
Cant start ryobi 890r brushcutter
My Ryobi 890r brush cutter will start and then die
May 16, 2010 | Ryobi Factory-Reconditioned 30cc 18" Gas...
Chainsaw starts and runs fine for a few minutes
Try fresh fuel making sure oil and gas mixture is correct. Carb might need cleaning and adjustment.
Jul 26, 2009 | Garden
Carburetor
there is an air fuel ratio screw loosen that off and it will run off choke
Jul 24, 2009 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
Garden Logo
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
