Question about Westinghouse DPF-1411 Digital Picture Frame
My digital picture frame is plugged into a usb port, but my computer doesn't recognize it.
IPhoto stopped recognizing my camera. iPhoto was working until yesterday and now it doesn't. Image capture recognizes the camera but does not give the option to import. The USB port works. The hard...
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use iPhoto.
Sep 30, 2011 | Panasonic Lumix DMC-FX3 Digital Camera
I can not download photos from computer to picture frame. It does not recognize the UBS port. The red light is on but no connect is recognized. I bought this picture frame. Is there something wrong...
Are the pictures you are transferring in a format that is recognizable to the picture frame? Check manual for acceptable formats. You may have to convert the files to work - but freeware is available for that so it is no sweat.
Aug 28, 2017 | SmartParts SPDPF70P Digital Picture Frame,...
Digital Royal Key Chain - How do I download pictures?
Hi, the Digital Royal Key Chain has a mini USB port located somewhere, this should also be the port for the adapter to the built in lithium battery inside. There after, just plug in your computer and Plug and Play software should detect it. Then you can move your picture files, (.jpg, .mpeg, .gif, etc) and drag them in the drives folder. They should display then.
Mar 15, 2009 | Coby DP-768 7-Inch Widescreen Digital...
No power
You have to plug it into the wall for power. It does not get power from the USB port.
Mar 08, 2009 | SmartParts INC. digital frame. 7.0 in....
Can't get photos from MAC to load to Digital Photo Frame
To connect to a Macintosh computer:
1 Plug in and turn on the digital picture frame.
2 Connect the small end of the usb cable to the usb port on the side of the digital picture frame.
3 Connect the larger end of the usb cable to a USB port on your Macintosh computer. The Macintosh will recognize the digital picture frame as an external storage device, and an icon will appear representing the device.
4 Drag and drop your photos on to the icon...
5. After you finish, press the eject button, and disconnect the usb cable once the icon has dissappeared
If there is still a problem, try restarting the macbook. and make sure no other programs are running in the background that may interfere with the process. Also, make sure the laptop is plugged in, or the battery power is sufficient.
Hope this helps!
Let me know!
enov8
Feb 19, 2009 | Computers & Internet
I do i get pictures from my camera to my digital from with my usb
hi you can plug in your secure digital card into the digital frame,or if your camera does not use a secure digital card,you will need to buy a memory pen stick where you can store any picture you want on it,they are very cheap and they just plug into your usb port,hope this helps
Jan 04, 2009 | Coby DP-768 7-Inch Widescreen Digital...
7" sunpak frame wont recognize usb connection
How do I get my computer to recoginze the connection of my USB?
Dec 31, 2008 | Sunpak (SDPF-070AW-0US) Digital Picture...
USB Connection
Hi Amanda and Lisa. Are you making sure the picture frame is off BEFORE you plug it in to your computers? Make sure you:
Turn it off before pluging it in, then plug in the USB cable. Now you can turn on the picture frame and you should see the frame's memory and any SD cards you have plugged into it in the removable drives section.
Let me know if that helps. If not let me know, and thanks for coming to FixYa. If you're happy with my answer then don't forget to rate it appropriately.
Rob
Dec 23, 2008 | PANDIGITAL 8.0" Digital Photo Frame...
Westinghouse DPF-1411 Digital Picture Frame Logo
Top Westinghouse Photography Experts
Ed Mac
teddyboy
Tom Chichester
Are you a Westinghouse Photography Expert? Answer questions, earn points and help others
