Question about Canon PowerShot SX120 IS Digital Camera
My camera always after replacing new charged batteries shows low battery after 2 or 3 shots
    Champion:
  • Canon Expert
  • 319 Answers
Main board faulty
Posted on Oct 16, 2013
4 Suggested Answers
  • 3 Answers
SOURCE: Low Batterie Sign
I had the same prolem. OK, try this. Try to discharge the AA batteries in some use, flashlight or else,,,,then recharge them, full charge, install the batteriers ...they should work fine....
I read somewhere that canon is able free of charge to correct a shortcircuit that the camera is susceptible to develop in the installation of batteries......But I hope the advise will work...
Remove batteries when not in use.
Posted on Nov 13, 2008
  • 6 Answers
SOURCE: canon a590 always low battery with new battey
Don't use regular alkaline batteries (even though you can...) It's a pain to splurge for the more expensive lithium or photo-specific batteries, but they do last. I take A LOT of pictures with my A590, and can usually get several hundred shots out of a set of good batteries. Try Energizer's web site for a coupon, sometimes they have them available.
Posted on Nov 22, 2009
johex
  • 75 Answers
SOURCE: with fresh batterys after a few shots camera shows
i am afraid u are using a low mAh rating battery. u have not mentioned the type of battery ur using. most digital cameras will use batteries with at least 700mAh rating. if it is AA size battery use 1300mAh rating or more if u want to capture videos as well.
Posted on Mar 12, 2010
Just purchased lithium batteries and indicator showing low battery
Are you sure you bought lithium cells? In your camera you should use Ni-MH batteries. The SNB-2512 could be very expensive, but normal Ni-MH from any brand should work fine.
Depending of what you use, always be sure all batteries are the same, charged and suited for your camera. Most of the time even new Ni-CD rechargeable batteries won't work, because the voltage is low, according to NiMH or alkaline batteries.
Always charge NiMH batteries before using them for the first time, or if they have not been used for a long period. 3 months is a very long period.
Always charge sets of batteries (2 or 4) together.
Do not use alkaline batteries unless it is absolutely necessary. In some cases, alkaline batteries may have a shorter service life than NiMH. Alkaline battery performance is limited, especially at low temperatures. The use of NiMH batteries is recommended.
Never use manganese (Zinc-Carbon) batteries in your camera.
Jan 09, 2014 | Samsung S860 Digital Cameras. 8-megapixel...
Battery not charge
the battery may have developed a memory from continually recharging a partially used battery. The battery charges to this point and reads fully charged but when used it shows as flat because the charged portion is the bit that is used and not the whole battery. Replace the battery with a new one and only charge the battery when it shows as flat.
Sep 15, 2013 | Sony Cyber-Shot DSC-F717 Digital Camera
Always lowbat
Replace the battery if, even after you charge it, it shows Low Battery. If it is a new battery, your battery contacts in the camera may be faulty, or something in the camera may be faulty. I am sure it is just a bad battery though.
Mar 08, 2011 | Olympus FE-170 Digital Camera
Good Day..Is it needed to replace a new battery if it is always draining?thanks.BRAND IS DSC-T50
If battery is 2-3 years old then buy new battery because these batteries have limited life span and lose its charge storage capacity after long run.
Buy new original battery from Sony Accessories Store for your DSC-T50
Thanks.
Jul 25, 2010 | Sony Cyber-Shot DSC-T1 Digital Camera
Kodak Easy Share z712 IS not detecting charged battery
I have the exact same camera almost a year too. It is a total "swinka" on batteries. About 10-15 shots on super ni-cads, and quits without warning.
A pair of Energizer 7X gave me near 500 shots. Much cheaper but still ...
So 4 months ago I bought a charger and 2 rechargeables. Charge one while using the other one.
I may get 70-90 shots per charge on these lithium-ion rechargeable batteries, without flash.
Testing the batteries without a load doesn't really tell you anything.
What's the reading? Should be well over 4 volts when fully charged. Mine show 4.2V
Jul 24, 2009 | Kodak Cameras
I have Canon power shot S2 IS digital camera.I bought it around 2 years back.Now my camera is showing the sign of "change the batteries" even though the batteries are fully charged and the lens does not...
i suggest replacing a fresh battery will most likely solve your prob, overtime rechargeable battery can drain easily, try changing with a new battery and see if it does work well, there might be insufficient current, thats why it tends to drop of voltage easily upon using,
there is a specified lifetime for rechargeable battery, depends on your usage and charging method, theymaybe fully charged but sometimes wont give you enough power to drive
cheers
Nov 26, 2008 | Canon PowerShot A540 Digital Camera
False low battery warning
Same thing happened to me when I used alkaline batteries. Have you tried fully charged NiMH? If not you may have a "leak". Your next option is the service center.
Jun 27, 2008 | Olympus Camedia C-5050 Zoom Digital Camera
Sony Cyber-shot DSC-U10 low battery indication.
possible short circuit that is draining battery at a speed. get your camera tested at some good repair shop,
Jul 02, 2006 | Sony Cyber-Shot DSC-U10 Digital Camera
Canon PowerShot SX120 IS Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
