Question about Sewing Machines
I bought a singer 112wsv110. Can i do welting and
I bought a singer 112wsv110. Can i do welting and single stich on it? Please help me with this machine. I want to do furniture upholstery on it. Thanks
    Champion:
  • 208 Answers
Semi industrial machine with a quarter horse power motor should have no problems
Posted on Oct 19, 2013
  • 323 Answers
SOURCE: singer sewiing machine clicking
Remove the needle , tighten the needle set screw so the clamp doesn't rattle and run the machine.This will give you a better idea of where the noise originates.
Remove the top cover and put a drop of sewing machine oil(not 3 in 1 oil) on anyplace that moves and rubs. Run the machine again and see if you still have the noise. Replace the top cover.
Open the side cover(left side) put a drop of oil on any thing that moves or rubs(Shafts or joints). Run the machine again.
Remove the bottom cover and repeat the above processes.
If you still have the problem and it is bothering either you or the machine then it needs to be seen by a technician.
sewman7
Posted on Jul 12, 2008
  • 323 Answers
SOURCE: Hi, Recieved the machine (Singer
Go to this site and you can download your manual.
http://www.singerco.com/accessories/manuals.html
sewman7
Posted on Feb 07, 2009
  • 69 Answers
SOURCE: yamata FY7568 only stiches ----------
Have you changed your needle? If you have a dull or bent needle it can cause the machine to not lock the stitches together and the result is a straight stitch on every pattern. Also, check your stitch width selector and make sure that it did not get accidently moved.
Posted on Feb 12, 2009
kent581
  • 87 Answers
SOURCE: FEW STITCHES DROP IN BOBBIN
Dropped stitches troubleshooting:
1>change to a new proper needle (proper needle means quilting needles for free motion, stretch needle for knits, leather needle for leather, microtex needle for micro fabrics.....etc.) of proper size. Most sewers never need a needle smaller then an 80/12 when sewing. Smaller needles bend more easily causing more problems.
2>If a new needle doesn’t fix the problem, remove parts from bobbin case area (as best as easily allowable) and clean out all the lint thoroughly, and oil with 2-3 drops of oil where friction occurs (turn hand wheel and look for rubbing)
3>If still skipping, try a different spool of thread (Yes, thread can caused skipped stitches, not common but I see it).
4>If you haven’t solved it yet, sounds like you could need to make a lower level adjustment like hook timing.
Hook Timing:
To time the machine, you want the tip of the hook to pass just over the top of the eye of the needle when the needle is in the left most or right most position depending on which side the eye of the needle will be higher
Posted on Mar 21, 2009
  • 415 Answers
SOURCE: my top stich is tight,but bottom is loose of my
Think in opposites... the top stitch is formed by the bottom thread tension and the bottom of the stitch by the top. So either the bobbin thread is too tight or the top thread is too loose. Check the bobbin thread first as that is the one most overlook. It should come out of the bobbin without having to yank it hard but it should have a little resistance.
Posted on Mar 23, 2011
Hi. I've bought a singer xl-1 embroidery machine and can't get the embroidery stiches to work
Have you talked to the vendor of your machine? It could be defective.
Jun 26, 2017 | Singer Sewing Machines
Welt foot for rex single needle walking foot for a rex not singer not consew not brother juki but for a rex
You can check with http://www.shop.heavysew.com/Rex_c109.htm if you don't find it on there site call them Heavy Sew com Online Shop
Apr 20, 2017 | Singer Sewing Machines
Singer 201K Hand Crank Sewing Machine - I have threaded machine correctly, but when stiching the threads are not interlintking i.e. stiches are not forming and thread from reel and bobbin remain loose. ...
Hi Wendy. No stitches like this is likely one of two things. The needle isn't fully inserted into the needle bar. Or it's out of time.
http://www.singerco.com/uploads/download/1297_201k.pdf
Luckily most singers of that era are similar. And there is lots of info on how to time them online.
Oct 14, 2012 | Singer Sewing Machines
Ihave a Singer Curvy 8770, needles keeping breaking and it's not stiching. I am just tring to stich basic frabic together
I would call Singer because something is not in alignment if your have checked all of the suggestions that your manual gives. Without seeing it, I don't know how anyone can help because we cannot see what the needle is hitting, it is like working in a dark room. Singer's phone # 1-800-4singer, JoAnn Fabrics usually has nice people who are very helpful and I know that they sold this model at my JoAnn's because I bought one for Xmas for my granddaughter. They probably will spot the problem right away
Apr 24, 2011 | Singer Curvy 8770 Electronic Sewing...
Instruction Book in English
Yep, just use this link to go to the Singer website and in the search box (middle right of the page) type in "2259"
Hope that helps,
Chris
Jun 07, 2010 | Singer 2259 Sewing Machine
Machine skipps stiches whats wrong
You need a heavy duty needle #16 or #18 to sew leather and teflon presser foot is helpful
Apr 15, 2010 | Singer 7442 Mechanical Sewing Machine
I have a rex 26-188 I need a new welt foot where can i get one ? thanks
Hi John, doing my best to help if I can. Most sites I have checked don't even have the 26-188 listed. I understand why you gave us a shot.
Try these folks. The site is lethargic as far as navigation but... check out the welt feet. You may have to go by size vs brand.
http://www.cutsewservice.com/RIDE/Index.aspx?categoryId=2
http://www.cutsewservice.com/prop.htm
1-800-225-2983
Thanks for using FixYa.
Kelly
Mar 14, 2010 | Rex Sewing Machines
In need of welt foot for rex 26-188 sewing machine. Is there one that is available for another machine that will work?
Well I'm not sure if this is a solution but, most walking foot machines are either like the Juki 562 or 3 and the Singer 111, 211  or newer models. REX's are particularly original, they should be using a very similar welting foot. Many industrial sewing stores in LA have them.. Kyle
Mar 26, 2009 | Rex Sewing Machines
Singer 533 missing stiches
Replace your sharp needle, code 2020, with a ball point needle, code 2045. This usually solves the problem. You can also put "Stitch and Tear" at the bottom to help stabilize the material. If you can do not have Stitch and Tear, try a piece of tissue paper for the short term.
Dec 22, 2008 | Singer 7462 Mechanical Sewing Machine
Sewing Machines Logo
81 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
