Question about Honeywell RTH8580WF WiFi Thermostat
Installed new termostat and heater doesnt turn off
    Master:
    Sergeant:
  • 449 Answers
Check your red and white wire connection they are crossed or shorted some were.
Posted on Oct 15, 2013
Installed a new rheem water heater last night and still no hot water. It has power thermostat set at 130.
Turn off the heater then open the bleeder valve on top of the tank to let the air escape. Once all of the air has been bled off, faucets included then turn your heat back on.
Jun 14, 2017 | Rheem Water Heaters
What could be wrong if the heater doesnt blow heat in my 2000 olds intrigue
you have two choices one check and see if your heater core is working properly , next check to see if you termostat is opening and closing you do all of this by checking the top return hose on your raditor.
Apr 17, 2011 | Car Audio & Video
Our Stadt heater is not working. I have tried to turn the termostat off then turn it back on & that didn't work. I also tried to press the reset button for 5 seconds then turn the termostat back on....
o my friend i hawe a same problem in macedonia it hawe a mystake in elektronk part in airconditioner...and maybe is dthe outside part of split termik is not ok maybe ...
May 20, 2010 | Heating & Cooling
My 94 gmc sierra has no heat, new heater core and blower works, also has new termostat...any suggestions?
You Might want to Check your Heater Control Valve,Its located under your Hood between 1 Heater Hose and your Water Pump.Its Vacum Operated and could be manual as well.Have someone turn your heat on and Off while you watch under the Hood at the Heater Control Valve to See if you see it Move.Or could have a Leak.More than Likely its Frozen Closed not allowing the Hot Water to Run Through Your Heater ore ,Which Results in No HOT AIR blowing inside. Try This 1st.
Mar 01, 2010 | 1994 GMC Sierra
Pilot is lit but when i turn the thermostat up the heater will come on. installed new thermostat but still will not heat pool?
do you change the sensor that come with the termostat? do you have a automatic control may be a temp sensor is bad ? last the pool take one degree per hour to heat are u give enough time?
Jun 16, 2009 | Jandy Laars Lt 400,000 Btu Heater
Not enough screws on my control board
I sounds like the thermostat you have is heating only. You need to buy and install a heating/cooling thermostat. The new thermostat will have a sheet with wiring diagrams to choose from.
Apr 23, 2009 | Honeywell L4064B2236 Fan/Limit Control...
Central heater Payne doesn't come on. Today termostat was switched off and after it was on heater didn't start. If turn off switch by heater manualy and turn back on heater works 2 mins and stops. Doesn't...
Did youever find out what was wrong with this? I have a 10yr old Payne unit that is doing the same and after $800 this is still not fixed. We've replaced almost everything. Thx!
Dec 18, 2008 | Heating & Cooling
Heater
A) check hoses are not blocked or crimped ad you have restricted flow
B )your heater radiatior is blocked, no flow
C) your termostat of the engine is not working or is not instaled at all
Oct 30, 2008 | 2007 Ford F
Termostat how to repair
one rad hose goes to the water pump the other goes to the thermostat on top of the motor. undo the hose clamp and take off the hose that goes to the thermo . DO THIS WHEN THE VEHICLE IS COLD. have a small container handy to catch any coolant that may leak out. be sure to keep the hose up so coolant doesnt leak all over the ground.Once you take off the hose the thermostat should be right there. 2 bolts to take it out. fairly simple actually. replace with the new one and put hose back on. replace any coolant that might have leaked into your container. Hope this helps you Crystal. let me know. Thanks, Mark.
Sep 21, 2008 | 1996 Chrysler Sebring
Honeywell RTH8580WF WiFi Thermostat Logo
88 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
