Question about ITT Jabsco Manual Marine Toilet Compact Manual Marine Toilet
Jabsco model 37010-0090 electric head. sometimes no motor run or flush when button pressed. By turning slotted shaft on end of motor , button then activates motor and flushes.
Sounds like the motor commutator and brushes need some attention. Not a difficult job if you have been there before but it can be tricky for a novice.
Posted on Oct 30, 2013
I have a husqv weedeat, its start fine, rpms fine, shaft from the motor to the head is fine, whats not fine is head has no torq and doesn't even spin. can you point me in the right direction?
If I understand your question correctly this may be what's wrong.
Inside the shaft there is a long piece of metal that connects to the engine and runs all the way down to the head from the engine. Sometimes, that piece of metal strips on either or both ends - as normal wear and tear and prevents and head from spinning. I hope that this is the case in your situation. If you were to remove the shaft from the motor section, inside the shaft should be an internal shaft. If the end of the shaft is rounded around where the shaft is pushed inside of the engine, well then it is stipped-out and needs to be replaced. If you inspect the other end where the head connects to the internal piece of metal and it is rounded around the end, well again that end is stripped-out and needs replacing. In summary, if either end of the internal piece of metal is rounded over instead of being flat, it is most likely in need of replacement.
In order to replace the "internal shaft" locate the Model Number on your Husq Weed-eater, call your local dealer and order the part and replace it. Sometimes, there might be an 800 number to help to locate a part. Your owners manual may have a exploded view of the part and part number. Sometimes the internet can provide part number and exploded views if you search the model number on line.I hope this helps.
Mar 11, 2017 | Miscellaneous
How to get motor to start? problem with GFCI - not resetting
There should be a rubber plug on the back side of the motor. Remove plug and insert screwdriver into slot of motor shaft and turn motor over manually. This will most often break the corrosion loose in the motor. Pool filter motors corrode when sitting. This will cause the electric motor to partially or permanently freeze up. After turning by hand the motor should start up when plugged back in. Make sure the plug is not connected when attempting to turn motor over. You will have to remove the cover to access this slot in the armature shaft.
May 29, 2014 | Intex Krystal Clear 2650 GPH Model SF20110...
Stihl fs 55r head won't turn
Check drive shaft. Some models have a flexible cable drive shaft that is prone to breaking. also make sure the drive shaft is engaged in the clutch drum and in the gear head end.
Mar 25, 2013 | Stihl Garden
Jabsco electric toilet won't flush
Check the power source to toilet and all wiring conversed.
Sep 07, 2017 | Jabsco Home
Electric control button raises the head of the Tuffcare hospital bed but will not lower it. It doesn't even make a clicking sound. All other functions are working through the control mechanism. Is there...
The problem you are describing happens quite often and there are several solutions.
1. The manufacturer sometimes supplies a manual crank that fits in the end of the motor to manually turn the motor and lower the bed. This crank is usually lost or misplaced (look for it on the bed frame). With the weight of the mattress and person off of the head you may be able to use a pair of pliers or other tool to carefully turn the motor shaft.
2. There is a bolt and nut at the end of the head motor shaft or a hitch pin and bolt. Remove this bolt at the end of the motor shaft where it attaches to the head frame and the head frame will drop to level.
3. Fixing the hand control usually involves taking the two halves apart and bypassing the push-button switch by shorting across the head down switch. This is the best way to diagnose a bad hand control. This is the most difficult solution for the average end user. You ultimately will purchase a new hand control anyway so this may be a viable solution. The hand control gets the most use and abuse and is usually the faulty part.
You may have a bad relay on the junction box control board where all the motors and hand control are plugged in. If the motor runs in one direction, the motor is OK. If you have the micro-switch style 6 button switch hand control you may be able to clean the switches by spraying contact cleaner is the switches and pushing them several times. Check the hand control plug for bent or bad pins at the control board junction box. The hand control pendant runs about $100 and the junction box controller is about $400. Hope this helps.
Nov 27, 2010 | Health & Beauty
Pump leaking
Some impellers have a screw in the middle which screws into the centershaft with reverse threads. If it has one, unscrew that first. Next, there is either a flat on the shaft near the opposite end or there is a slot in the end of the shaft for a screwdriver. Hold the shaft securely, and unscrew impeller. Sometimes a big pair of pliers is needed, but be careful not to damage impeller.
Jul 22, 2010 | Hayward 2HP Pool Pump Motor A O Smith...
I strip the cable inside my lawn trimmer it would turn my cutter below. Is this something I can repair or must I take it to shop?
Hi and welcome to FixYa. I am Kelly. When you say you stripped the cable I am assuming that your talking about the flexible drive shaft. This can be replaced at home. However,.... ou did not state if this was a gas or electric model. At the moment I am assuming it is a 25cc Gas trimmer. To replace the flexible drive shaft the motor will have to be unmounted from the drive shaft housing. It will have 4 flat sides on each end that must mate correctly into the slots of the motor and the power head or you will not be able to re-mount the engine.
With a good model number I can provide you with a source of the replacment parts and probably what mounting hardware that has to be removed to change the fl;exible drive shaft.
Thanks for using FixYa.
Kelly
Jun 15, 2010 | Ryobi 15" Electric Factory Reconditioned...
Head will not drive. Can feel it slip between nut and motor.
inside the shaft is a flexible drive cord, at each end is usually a hex or torx head fitting that slides into a sleeve, theese can sometimes strip or even snap off and need replaced. remove one end of the shaft (either the engine or the spool) and the cord should slide right out easily. inspect each end for stripping and to make sure it didn't snap off inside the sleeves.
Sep 24, 2008 | Ryobi 15" Electric Factory Reconditioned...
ITT Jabsco Manual Marine Toilet Compact Manual Marine Toilet Logo
219 people viewed this question
Top ITT Jabsco Boating Experts
Mike
Steve
Steve
Richard Marshall
Level 1 Expert
Are you an ITT Jabsco Boating Expert? Answer questions, earn points and help others
