Question about HP G60-120US Laptop
Cooling fan replacement
I need to replace the coolong fan on HP G60-120US
  • HP Master
  • 32,281 Answers
Remove the fan from the heatsink and take it with you to a electronic hobby parts shop, they usually have a range of computer fans, select one that is the same size as your faulty fan.
You may need a new connector or cut the connector off the old fan and solder it onto the leads on the new fan. Make sure you insulate the soldered wires so that they don't short against each other.
Posted on Apr 25, 2009
My engine is running hot and the coolong fans do not go on
Checking codes would be best. First check the fuses. pull them out and look. Then start the car and turn on the A/C, if the fans come on the replace the coolant sensor, first. If not, the swap the cooling fan relays. Things that could be wrong are fan/s, fuses, relays, wiring, and the computer.
Mar 13, 2015 | 2006 Dodge Charger
My honda tiburon 2003 is over heating when slowing down an coolong when speeding up what's up?
check to see if you have a viscous fan hub on the fan if so have it replaced as it is failing . From your description of the problem when the vehicle slows down there is a drop of air flow through the radiator which results in the temperature going up and as you speed up the air flow increases and cools the radiator down
Jan 07, 2015 | Cars & Trucks
COOLONG FANS NOT TURNING ON? CAR OVERHEATING......
Some vehicle's cooling radiator fan does not turn on untill needed. If your Temperature Gauge is working as far as you know, Try running your car for over 10 miles; the fan should start working. If not, check your fuses. You can also try to directly connect the radiator colling fan motor to the battery and see if the fan works. If not, the fan motor may not be working.
Sep 08, 2013 | 2006 Dodge Magnum
Coolong fan only turns when I supply a ground to the sensor. Where does the ground come from normally?
cooling fan relay,replace sensor all it does is ground when it reaches operating temp.
TIM..............
Oct 24, 2010 | 1995 Ford Contour
Overheats then turns off
Check Fan. Or take to repair shop ask for a "Quote" for repair.
Apr 01, 2010 | Acer Aspire 9300 Notebook
Freezer works - refrigerator does not
evap fan between the two units is more than likely out. What this fan does is use the cooling from the freezer to cool the fridge. This fan is located in the space between the freezer and fridge and has vent slots in front of it for the transfer of the coolong from the freezer. This fan is more than likely on the same channel as the temp control setting for the fridge. To remove the fan motor you will need to remove that moulded channel and as soon as the channel is off presto there is the fan. Take model # and serial # to an appliance parts store for replacement. Good Luck hope this helped you
Dave
Jan 07, 2010 | Refrigerators
Coolong fan making a lot of noise
There are probably at least three fans in your refrigerator. I am assuming it is the fan in the refrigerator, check to be sure it is not being obstructed with ice or some other alien matter. If it is clear then you need to order a new fan ASAP. While you are at it check the condenser and condenser fan, they both probably need cleaning.
Good Luck,
Gilshultz
Nov 29, 2009 | Samsung RS2630SH Side by Side Refrigerator
I have a HP Media Center M370N 160GB HDD that I took to a computer repair shop. They replace the coolong fan with Delta Electronic Model Aso912L DC Bushless fan. I took it home and it worked for a couple...
Sounds to me like you could have a couple of possible problems.
First and most importantly would be to make sure that your cpu fan is clean and running. This is the fan that is located on the large heat sink on the mother board. A lot of times, especially on older systems, this fan and heatsink will get covered with dust and almost always cause an overtemp fault. Usually blowing this out with electronics cleaner will rectify this but if it has been like that for a while you may need to replace the cpu fan. Most electronics stores will sell these fairly cheap.
Your other problem may be that you need to purchase another case fan to cool the cpu more effectively. Generally though most premade systems come with enough fans.
Also you may need a new fan for the one that he replaced. It sounds to me like you may have a bad connector either on the replacement fan or the power supply wire. A real easy way to tell is to wiggle the wires a little bit. If your fan speed fluctuates odds are you've got a loose connection. It can appear to be fine but sometimes those wires on the molex connectors come loose and make don't make good contact. When that happens it may work fine for a few minutes, but then the first time that you get vibrations it stops working.
Jul 11, 2009 | HP (122226-001) Fan Controllers
PO481 code Chevy IMPALA 2003
Looked it up in Chilton's, confirmed in http://www.obd-codes.com/trouble_codes/
P0481 Cooling Fan 2 Control Circuit Malfunction
Each fan will throw a different code. See 3 fans listed for your model. Here's a link for the wiring schematic: http://www.chiltonlibrary.com/content/images/WD/GM/014/WD_GM_014788.pdf
Best of luck.
Greg
May 23, 2009 | 2003 Chevrolet Impala
HP G60-120US Laptop Logo
710 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
