Question about Cobra Digital DC4330 Digital Camera
Bad media or camera?
I am nore sure what happened nor not sure if it is broken.. When I entered the media inside the camera then turn it on and it refused to be turned on.. I pulled it out then turned it on.. it seems fine.. is it bad media or bad camera?
    Brigadier General:
  • 5,158 Answers
You can get the manaul and software here... the manual may offer some clues... as well you may need to reinstall the software
Robert
Please take a moment to rate this solution thanks
Posted on Feb 01, 2009
Camera shuts itself off
What is the age of the camera and how well used are the batteries? are you recording from battery or from power cable? The only things you can do are make sure the battery and power is good and make sure the recording media is good. With that in mind if the camera is older than 5 years, they have a battery inside the case that you cannot change. This battery keeps the date and time in memory and when it looses charge, the camera has to be sent in for repairs.
Dec 23, 2017 | Panasonic AG-DVC15 Mini DV Digital...
Broken LCD screen on the inside
They will repair it for $50 if you send it in to them, otherwise you can probably get a screen on ebay.
Aug 17, 2009 | Nikon COOLPIX P80 Digital Camera
My screen went blank
Sadly you can't do much :(
it might be a bad solder or a bad connection of the flat ribbon inside. You can try to fix the ribbon but it's a really fragile part. It depends how comfortable you are with this.
And if it doesn't work you then might have a broken electronic part inside.
Jun 20, 2009 | SanDisk Sansa e260 MP3 Player
Fujifilm finepix s700 is not turning on
OK
First check the battery door to make sure that it is closed properly. If you have a media door (the door which covers where the media cards are inserted) make sure that is closed properly. If this is the case then check that there is no plastic broken off. The doors contact with microswitches which allow the camera to turn on.
On the camera there is also a playback button. (green triangle) If you hold this and the camera turns on then your power switch is faulty.
Failing all of this then put some power into the camera via an adapter. If the camera turns on then it is likelly to be a battery fuse.
In all instances you will need to send the camera to be repaired at the fujifilm service centre. Web address below.
http://www.fujifilm.co.uk/technical/camera_repair/
Dec 17, 2008 | Fuji FinePix S700 Digital Camera
Samsung A506
Sounds like its broken. the black ink stuff could mean the screen is cracked and it has bled internally. I had the same problem (screen bleeding). the not-turning-on part could be because ur not using full batteries, the batteries are not in the right way, or the screen crack is shorting something inside and not allowing the device to come on. get it replaced. when you turn it on press the menu/ok button is there any noise, tune. this happens to me to show its entered the menu section. if you are getting this sound, then its turning on but the screen is cracked. if not then you have a dead camera or change the battery positions or use new batteries.
Sep 20, 2008 | Samsung Digimax A503 Digital Camera
Sony cyber-shot dsc-w50
Sounds like you have two problems, both which mean bad news. The clicking could be a broken gear in the lens unit or off track lens.
The colors may be caused from a bad ccd or sensor internally.
Aug 03, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Question
my gpx 3837 mp3 player will not charge nore turn on !
Jul 01, 2008 | GPX MW3837 MP3 Player
Kenmore coldspot fride problem
The water line could be frozen. Take a hair dryer and heat up the tube where the water enters the ice maker. MAke sure it doesn't get to hot and start melting the plastic,
Feb 01, 2008 | Refrigerators
Lens won't turn/ something's dangling
Do not try to fix it. Return under warranty- this should not have happened.
Aug 02, 2007 | Nikon D50 Digital Camera with 18-55mm Lens
Cobra Digital DC4330 Digital Camera Logo
Top Cobra Digital Cameras Experts
Greg Cann
Greg Cann
Daniel Dollive
Daniel Dollive
Nobody
Nobody
Level 1 Expert
Are you a Cobra Digital Camera Expert? Answer questions, earn points and help others
