Question about managemylife.com
GE dishwasher does not drain leaves 2 inches of water
    Renaissance:
    An user who is expert in 3 categories / brands.
  • managemylife... Master
  • 825 Answers
1 - out of account
2 - Clean all device
3 - Scan Anti Virus
4 - promising device driver
5 - open a new browser site
Posted on Oct 15, 2013
GE profile dishwasher drains real slow---have always had this problem---leave tub bottom with 1/2 inch of water in it. Have cleaned all the lines etc--food out of the traps
From your description, it sounds like there is an obstruction in the plumbing.
Many dishwashers are installed near the kitchen sink, the drain may be connected to the garbage disposal outlet. These can easily get clogged.
If you see a connection under the sink which appears to come from the area of the dishwasher, this is likely the case. If you get that cleared out it should solve your problem, and prevent other problems in the future.
Jul 13, 2011 | GE Dishwashers
Leaves 3 inches of water after cycle
Here is a tip that I wrote that will help you with your dishwasher2_bing.gif not draining problem...
Dishwasher2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Jul 24, 2010 | GE Dishwashers
My GE Profile doesn"t drain completly, leaving about 2" of water.
Sounds like a water level sensor is on the fritz. The drain valve is probably opening if the level drops at all.
Jul 31, 2009 | GE 24 in. Profile PDW9880JSS Built-in...
My dishwasher does not completely drain. It leaves about 3 inches of standing water. What could be causing this?
Without knowing the model of this GE ? dishwasher, it is very hard to be specific. Most DWs have a float/switch that sense when the dishwasher is filled and empty of water. They can fail.
If you can run a cycle without the dishwasher over flowing but it simply does not fully drain, I would pull the lower spray arm and the filter beneath that arm. Look closely for debris that could be blocking the pump. SOme dishwashers simply have a timer that controls each phase of the wash, including the drain cycle. If something is blocking the drain pump, an obstruction could cause this problem.
Good Luck, Please report back with what you find.
Apr 05, 2009 | GE Dishwashers
LEAVE MORE WATER THAN SHOULD BE
There is a drain hose that runs from your dishwasher to underneath your sink. (usually connects in right below the drain spout)
It sounds like this may have become clogged, or the sink drain is clogged causing the water to back-up in to the dishwasher drain hose.
Mar 20, 2009 | GE GLD5800L Dishwasher
GE Profile PDW7300, Leaves 2 - 3 inches of dirty water in bottom
check for a clogged discharge hose where it connects to the plumbing under the sink...this is the most common area for a clog. if no restriction is found, the discharge valve will need to be tested
Feb 20, 2009 | Dishwashers
Dishwashing machine not fully draining (2 inches of water remain). I have an open problem concerning this problem. I have a new pump. dishwashing machine not fully draining (2 inches of water remain) For...
Following a cycle, a small pool of clean water inside the tub is typical. Excessive water means the pump isn't pumping water out properly, the drain hose isn't carrying it to the drain pipe, or the house's drain lines are backed up. If dirty water spews from the air gap, the drain line is kinked or clogged. Note: If you've recently installed a garbage disposer, be sure the knockout plug for the dishwasher was removed when the connection was made (see your disposer instructions).
Apr 19, 2008 | GE 24 in. GLD5860LSS Stainless Still...
GE Monogram Won't Drain completely
the drain was clogged. A handyman used a snake to clean it out.
Apr 04, 2008 | GE 24 in. Monogram ZBD6880KSS Stainless...
managemylife.com Logo
21 people viewed this question
Top managemylife.com Computers & Internet Experts
Steve
Paul Bade
Are you a managemylife.com Computer and Internet Expert? Answer questions, earn points and help others
