Question about Corporate Express CEB95005 Calculator
Explain the "f" "3" "2" "0" "ADD" functions on a calculator
Where can I find a user guide or manual for the Casio HR-100TM calculator?
Couldn't find a manual or user guide. The closest I got were two pages, one with the calculator, and one with the group of calculators that explains some of the functions.
If you have a specific questions, please ask.
Good luck,
Paul
Mini printer Compact Type Printing Calculators Calculators CASIO
http://www.casio-intl.com/asia-mea/en/calc/printing/miniprinter/product_list/?m_no=145
May 14, 2016 | Casio HR-100TMPlus Calculator
How do I reset to just basic adding
Dont know what you are saying.
Basically turn it off and on if your stuck.
Jan 05, 2016 | Staples SPL-250 10-Digit Display...
Can't find a manual online. What does 5/4 mean, and how do I turn it off? Same for E. My biggest problem is that when I add up numbers with the print function on (for depositing large batches of...
The manual for the Canon P1-DHV is online at http://www.usa.canon.com/app/pdf/calculator/P1-DHV_G_USA_HWB.pdf>.
When the display shows "5/4", the calculator is doing 5/4 rounding which means: 5 or above round up, 4 or below round down. To control rounding press the "5/4" key.
When the display shows "E" the calculator could not complete a calculation. It can be because of dividing by 0, or because the total exceeded 1 trillion, or because the operator entered calculations faster than the calculator could complete them. Press the CI/C key to clear it.
I can't explain why you are not getting a total on the tape. Try the following example from the manual exactly as shown, and let me know if your tape shows the total.
  1. Clear the calculator (press [CI/C])
  2. Choose 5/4 rounding (press [5/4] until "5/4" displays)
  3. Choose add mode (press [DEC] until "A" displays)
  4. Choose cost-sell-margin mode (press [B-T] until "B" displays)
  5. Turn printer on (press [PRINT] until "PRINT" displays)
  6. To calculate: $12.55 + $15.75 - $5.30
  7. Key in: 1255 [+] 1575 [-] 530 [=]
  8. Tape shows: [0. C] ... [12.55 +] ... [15.75 -] ... [5.30 =] ... [23.00 *]
Apr 07, 2011 | Office Equipment & Supplies
How do you graph a greatest integer problem
To graph a greatest integer function, follow these steps:
1.) Press Y= 2.) Press MATH, then scroll to the right one column and select "int(" 3.) Enter your function inside of the parentheses, and make sure to put a closing parentheses at the end of the function you are inputting. 4.) After you have closed the parentheses to the "int(" command, add 1 to the end of the equation. This is because the "int(" command tells the calculator to take the lowest integer of the value inside of it. If you add one, then instead of .68 becoming 0, it becomes 1, and 1.724 becomes 2, etc.
Feb 27, 2011 | Texas Instruments TI-83 Plus Calculator
Probability calculation
Go to the following URL:
http://mathbits.com/mathbits/TISection/Openpage.htm
Download the Probability App PDF file at the bottom of the Statistics 1 section. This will explain all of the functions you need to know and what values to give to them.
Sep 22, 2009 | Texas Instruments TI-84 Plus Calculator
What does MC,MR,M-,M+ on the calculator mean and do?
MR is Memory Recall
MC is Memory Clear
M+ is Memory add
M- is Memory subtract
These are used to add and subtract the answers to multi-step equations so you can do the small steps with the calculator, then store, change or recall the total as needed. You might add a long string of numbers in groups this way. Or you can do all operations in one parenthesis, then just store the total of each.
A good problem to illustrate this would be : (123 x 3) + (55 - 24) + (10^2) - (7 x 8) = ???
Using MR, M+ and M-, you can do each one as a group, and only store the answers. 123 x 3 = 369 so M+ to put 369 in memory. Clear it from the calculator. 55 - 24 = 31, so M+ to put this in memory and add to the 369 already there. Clear it from the calculator. 10^2 = 100, so M+ this to memory also to add it. Clear it from the calculator. 7 x 8 = 56 so M- this to SUBTRACT it from memory. Clear it from the calculator if desired. Now, when you then hit MR, you will get the total of all of these small equations in parenthesis -- 444.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 18, 2009 | Office Equipment & Supplies
INSTRUCTIONS FOR THE KEYS ON THE CALCULATOR
To get a subtotal when adding, finish entering the last number before the subtotal, hit the +, then hit the diamond/pound sign key (just above the 7)
To get a grand total when adding, finish entering the last number in your list, hit the +, then hit the *.
Jan 14, 2009 | Casio HR-100TMPlus Calculator
Percentage function
Pick up the small instruction booklet here and look at page 4, the "%" key has 4 functions...
http://education.ti.com/educationportal/downloadcenter/SoftwareList.do?website=US&tabId=2&paneId=18#27
Aug 10, 2008 | Texas Instruments TI-30XA Calculator
Graphing inequalities
While the graph function menu is on the display press the F3 button to display the graph you want to do. Then press the function key that corresponds to the graph that you want. If you have the manual it explains it on page 117. Kind of hard to explain it here when you can't type the buttons. LOL
Jun 07, 2007 | Casio FX-9750GPlus Calculator
Corporate Express CEB95005 Calculator Logo
108 people viewed this question
Top Corporate Express Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Corporate Express Office Equipment and Supply Expert? Answer questions, earn points and help others
