Question about Brother P-touch QL-550 Thermal Label Printer
QL-550 Label Stuck
The last label on the DK paper roll became detached from the backing paper and is now stuck behind the roller onto the feeder surface behind the roller. There seems no way to lift the roller out of the way to remove the label.
Any ideas?
  • dburgess661 Apr 24, 2009
    Thanks for the reply
    I failed to say that its the sticky side of the label that is stuck (not to the roller) to the feeder surface, so its not possible to pull the label through.
  • James Porteous Feb 08, 2013
    I have the same problem - how do you dismantle the printer to get to the back of the roller
  • 48 Answers
Normally theres a lever you pull (the same one you use to manually pull the labels through), if you pull that, you should be able to blow the label out, or pull it through.
Posted on Apr 24, 2009
P touch QL 560 wont work with new paper
brother touch ql 560 Questions & Answers - Fixya
www.fixya.com > Forum > Tags
Get free help, tips & support from top experts on brother touch ql 560 related issues. ...i just set up a new computer with the vista windows and i have a brothers ql-500 p touch the install disk will not work with the vista what can i do go ... QL 550 won't print I have a Brother PTouch QL550 that won't print anything on the label.
[PDF]Creating Labels - Top Edge Engineering
www.topedge.ro/info/USER-GUIDE/.../OL-500-560-650-1050.pdf
pe nd ix. Software User's Guide. QL-500. QL-650TD. QL-560. QL-1050/1050N ..... This manual describes how to create labels using the P-touch Editor software .... want to create a new label layout or open an existing label. .... When this check box is not checked, labels won't automatically be cut ..... Used to select the paper.
Oh Brother! - Compatible Brother Labels saving you money
www.ohbrother.co.uk/
Compatible with Brother P-touch QL-500, QL-550, QL-560, QL-570, QL-580N, ... Thermal Quality Grade A Paper with Strong Adhesive and Sharp Print. ... Oh Brother! you won't find Brother replacement labels any cheaper on the internet.
brother QL-560 - Oh Brother! - Compatible Brother Labels ...
www.ohbrother.co.uk/index.asp?search=QL-550
Feb 03, 2016 | Office Equipment & Supplies
Paper feeder - roller is not grabbing the paper to feed into machine.
First check if the paper release lever is pulled, thus releasing the tension on the rollers. If this is alright, then there is a real possibility that you have a label or something stuck on the feed rollers or in the paper pan. If you can remove the platen, then you can remove the gunk, if not, then you will probably need to get someone to service the machine for you. Digging in behind there can sometimes solve the problem, but it can also sometimes create other problems. Hope this helps.
Oct 17, 2013 | Brother ML-100 Typewriter
I have a label stuck in a Brother QL650TD
You will have to take off whatever component you can to get to the label and pull it out. Make sure to clean off the roller it is stuck on or you will get stuck again.
Oct 05, 2012 | Brother P-touch Ql-650td Thermal Label...
STUCK LABEL IN THE P-TOUCH QL-500 LABEL MAKER, This is now the third printer I have purchased and replaced because of stuck labels on the rubber roller, this is a great printer until this happens. Any...
I downloaded service manual
You need to remove the top cover
Remove the curved cover 1st , has 2 plastic pins to press inwards
Lift the curved cover upwards
Remove the darkcover beneath the labels
At the back 5x self tapping screws
At the from 2x machine screws, left hand one is under a label
Prise off the cover by inserting a screwdriver at the back edge
Voila
Remove the stuck label
Reassemble
Apr 01, 2011 | Office Equipment & Supplies
Label stuck under typewriter platen/roller of Adler Royal
Roll a new piece of paper the best you can. Dribble a little paint thinner on the paper, letting it run down under the roller. The thinner will disolve the adhesive on the label. After a couple minutes, you should be able to roll out the paper and the laber with no problem.
Aug 28, 2009 | Office Equipment & Supplies
I have labels stuck and now paper stuck to the label and I figure out how to get to them. It on the black roll thing
The black roll thing is the fuser roller. If you have a label stuck to this unit them it will need to be replaced. The fuser roller that you see has a coating of teflon and if a label is stuck to it, the coating will be damaged when you try to pull off the label. The HP part number you need is RG9-1493. Check with your local printer repair shop for pricing, If they can't get you what you need check Ebay.com We have service manuals for his unit available for $6.95 for a download if you need one. The manual is at www.ccl-la.com/hplj3330.htm The service manuals have disassembly instructions, parts lists and troubleshooting tips.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Jun 23, 2009 | HP LaserJet 3330 All-In-One Printer
Remove a label stuck to the metal floater behind the pleten myself
Take a quarter piece of typing paper. Soak it in paint thinner. Roll this down where the label is stuck. The paint thinner will dissolve the adhesive on the label but will not harm anything in the typewriter.
Apr 24, 2009 | Brother ML-100 Typewriter
Remove stuck label
THIS IS COMMON FAULT WITH PEOPLE WHO USE LABELS ON TYPEWRITERS. U MUST NEVER TURN THEM BACKWARDS OR U WILL GET ONE STUCK IN MACHINE. THE ONLY WAY TO GET IT OUT IS TO REMOVE PLATEN AND CLEAN THE JAMMED LABEL FROM THE FEED. AND ON SMITH CORONA MACHINES THIS IS NOT EASY TO DO ONESELF.
Mar 18, 2009 | Smith Corona Wordsmith 200 Typewriter
HP 3210 getting paper jam because label stuck on roller.
I ran heavy card stock through printer several times, it caught the label and pulled it out on the paper eventually.
Feb 04, 2009 | HP Photosmart 3210 All-In-One InkJet...
Brother P-touch QL-550 Thermal Label Printer Logo
458 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
