Question about Power Health Scooter Wheelchair Programmer Ds100 Dynamic Rhino Power
I have a silver leader 8 not a 4 and the parking light flashes but scooter wil not drive,help please
2 Suggested Answers
gewiz
  • 1263 Answers
SOURCE: i have a silver leader
hi,
ok so 7 flashes is a speed pot related error, you need to make sure that the speed pot is in the central position , look under the stem and you should see a cross head , now that should be straight not at slight angle, without you touching the throttle lever , if you have a meter disconnect the pot and take a resistance reading, it should show about 2.5K - using the centre tap , if it is a 5K pot fitted , in fact for that controller it should be a 5K pot , please check the terminal connections on the controller, good fitting and clean.
Take leave feedback.
Regards GeWiz.
Posted on Feb 11, 2011
My scooter wont go all of a sudden and the red light on the console is blinking a sequence of 4 times
Amigo Scooter Oxygen Tank Holder Light flash key turned ...
www.fixya.com > ... > Amigo > Amigo Scooter Oxygen Tank Holder
... key on my phoenix 3 scooter the red light flashes 5 times and the scooter will ...scooter wont move,although on the little speedo there is a red light flashing on ... ...light is flashing when the key is turned on. the scooter does not move at all ... flash up and down the console light and you at this point have to turn the key off ...
My pharmore wizard diagnostic light flashes 9 times and my ...
www.fixya.com/.../t25197681-pharmore_wizard_diagnostic_light_flashe...
Oct 8, 2014 - my pharmore wizard diagnostic light flashes 9 times and my scooterdoes not go, can someone help me please - Mobility Scooters question. ... Have no manual for pharmore 4 wheeled wizzard light on but wont move ... Why did it stop working suddenly and is blinking console light in 5-blink sequence?
Jan 31, 2016 | Video Game Consoles & Games
How to fix scooter when red light flashes 5 times
hi, i need you tell me what controller type is fitted to that scooter before i can be more precise with fault info ,, the controller is a black, or blue or silver box located under the rear cover of the scooter ,, the wires lead to this unit...
Regards
Rob
www.gewizrepairs.co.uk
Apr 10, 2014 | Drive Medical Phoenix 3 Wheel Compact...
Hello i have a kymco xl mobility scooter which has developed a fault flashing green light.2 flashes pause 2 flashes pause and so on.i haven't got a owners manual and trying to find one on line is...
Hi , is it the Midi or Maxi XL model ? PG Controller (normally a silver colour ) has the following as the listed fault
There is a bad connection to the motor and the controller
If 's it a Rhino controller normally a blue colour ,
The battery is completely empty. The scooter does not drive.
• Recharge the battery immediately.
If the scooter is left off for a few minutes, the battery may recover enough
to allow driving again for a short time. However, driving on an empty
battery may cause damage to the battery.
Regards
Oct 23, 2013 | Electric Mobility Health & Beauty
Aquasoothe travelite scooter, the batteries are fully charged, the battery gauge is showing full, but the battery light is flashing. It flashes 7 times then pauses, we can't get the machine to move or...
Response to similar query in 2011.
http://www.fixya.com/support/t5751777-aquasoothe_travel_lite_instruction
not my words. The link to the pdf for this is http://www.discovermymobility.com/store/scooters/summit-scooters/elite-portable-scooter/manual.pdf
you want page 22.
Problem Check Point
The driving of the wheelchair is too slow or insufficient, the status
indicator lamp flashes slowly Batteries are exhausted and need to be recharged
1 flash The battery needs charging or there is a bad connection to the battery. Check the connections to the battery or charge batteries.
2 flashes There is a bad connection to the motor.
Check all connections between the motor and the controller.
3 flashes The motor has a short circuit to a battery connection.
4 flashes Freewheel is engaged.
5 flashes Not used.
6 flashes The controller is being inhibited from driving; this may be because the battery charger is connected.
7 flashes A throttle fault is indicated. Make sure that the throttle is in the rest position before switching on the scooter
8 flashes A controller fault is indicated. Make sure the controller connections are secure.
9 flashes The parking brakes have a bad connection. Check the parking brake and motor connections. Make sure the controller connections are secure.
The-Active-Light
does not function,
the Battery/
Status indicator
flashes rapidly.
Count the number
of flashes:
10 flashes
An excessive voltage has been applied
to the controller. This is usually caused
by a poor battery connection. Check the
battery packs and controller
connections.
Sorry wasn't sure how much space they give you for answers. :)
Oct 11, 2013 | Health & Beauty
On my mercury prism scooter the fault light flashes 8 times . i have changed the battery but the fault remains and the scooter does not function
I believe that this is the same as the US version of the Drive Phoenix scooter. If so, here's a link to the troubleshooting guide which you will need a multimeter to check. An 8-flash on the Phoenix indicates that there is a probable motor fault, which isn't good news at all. This is a small scooter, and the motors are not designed for heavy loads, or long climbs up steep hills. Other problems arise when folks drive their scooter through mud or other unstable surfaces and they get stuck. This can burn out the motor as well. More on the Phoenix here.
Jan 10, 2013 | Health & Beauty
I have a silver leader 4 mobility scooter with a dynamic ds 100 unit under the rear end the status light is flashing 7 times which from what i have been able to find out is the wig wag potentiometre have...
hi,
Regards GeWiz.
Feb 11, 2011 | Power Health Scooter Wheelchair Programmer...
Drove a few minutes, parked the next day it would not move, charged batteries, still nothing it is giving code 8
According to the owner's manual, you have a motor problem. To further diagnose and verify the problem you would need a digital voltmeter to check the motor. An experienced technician can do the necessary checks and order/replace the motor if necessary.
8 Flashes
• Indicates a motor voltage problem.
• Your scooter will not operate until the problem is corrected.
Remedy: Contact your authorized Golden Technologies, Inc. dealer.
Hope this helps.
Dec 22, 2010 | Golden Technologies Companion II Travel...
Scooter battery shows full charge but scooter does not move ! red led light flashes 8 times !
Plamont unfortunately that flash code usually means a controller error. The controller is the brains of your scooter. Take the seat off and remove the rear shroud that covers the batteries and motor/gearbox assembly. Check all the wiring connectors for damage or loose connections. After checking the connectors turn the scooter on and see if you still get 8 flashes.
Did Medicare purchase the scooter? If so they will pay for most of the repair costs. You can contact your provider that sold you the scooter or a repair service Repair Xpress@ 1-877-581-3733 or Roadrunner Mobility @ 1-800-467-2668 Hope this helps you
Sep 12, 2010 | Golden Technologies Liteway 3/4 Wheel...
Scooter does not respond to control. Diagnostic light flashes 5 times. Can you help?
Hi ,
5 flash - >> Brake feedback error
Drive inhibited Check that the Park Brake release
switch is off. Check the Park Brake
and wiring for open or short circuits.
Check the brake connections, the two wire leading to the brake, if the rear motor comes away fro mthe frame make sure there is a good connection between the rear part and the main frame.
Regards
GeWiz.
Jan 27, 2010 | Golden Technologies Companion II Travel...
My pride IV scooter will not start I get a click
An 8-flash code indicates that the controller has shot craps. The controller is located under the shroud beneath the seat by the batteries and it controls all of the power and automatic functions of the scooter. They are damaged most often by water infiltration like running through deep puddles, etc. or by over-amping the scooter by driving it through unstable terrain like sand, mud, wet grass. There's no fix for it but a replacement and it's pricey...several hundred dollars.
Aug 10, 2009 | Pride Mobility Products Casual CL20KD Lift...
Power Health Scooter Wheelchair Programmer Ds100 Dynamic Rhino Power Logo
Top Power Health Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Power Health Health and Beauty Expert? Answer questions, earn points and help others
