Question about JBL Cinema SB100
I recently purchased a 60" Samsung Smart TV and a JBL Cinema SB100 Sound Bar. I was really looking forward to using one remote and having the volume from the sound bar be controlled by the TV's remote. Unfortunately I've tried pairing the remote for the TV with the sound bar using both the instructions for the sound bar and the tv, but the TV/Remote won't recognize the sound bar. The sound bar does work when using the sound bar's remote, so as far as I know it's connected properly. Do you know if there are any tricks to this in order to get the TV remote to work on the Sound Bar. Thanks so much for your help! I hope we can figure this out.
2 Suggested Answers
Agent Jon
  • 100 Answers
SOURCE: we have recently just bought
Salutations ddog,
Really this is a question of sources. The reason your able to hear surround sound when connected to your DVD player is that is what is providing your audio and video source. When your watching television it would depend on how your getting your broadcasts. If you are either receiving an over-the-air broadcast or cable directly to your set, your television becomes the source. As your television is providing the signal, you would need it to loop back to your receiver to provide that surround sound.
Now for the good news, if you have a cable or satellite box these should have outputs to connect to your receiver to provide the audio source.
Also keep in mind not all broadcasts provide a version of surround sound. Most newer home theater systems will replicate surround sound artificially.
I hope this helps.
Jon
Go Ahead. Use Us.
Posted on Jul 28, 2008
How do I make the sound sinc with picture after I've connected to sound bar
I have a 60 in. Vizio, but I'm pretty sure this will help you out: With the remote that came with your TV (not TiVo, ScientificAtlanta or some other device programmed to control it), press the menu button, then click on audio. You should then see a choice that says "lip synch" or something like it. Click on that and a bar graphic should appear on the screen that looks something like this:
_ __________________ +. This allows you two synchronize and set the audio with the picture - either slow it down or speed it up by a few seconds either way by using the TV remote. I've never had to use it with my Samsung HT, but I know it's there and I know it's function. My TV is also a smart tv, so this should work for you. Good luck. . .
Apr 16, 2016 | Samsung UN55ES6500 55 Inch 3D 1080p Smart...
How do i set up a new remote control for a samsung ht ws1 sound bar
2-Function Remote Stopped Controlling my Sound Bar - Verizon Forums
https://forums.verizon.com/t5/Fios...Remote...Sound-Bar/td.../559715
Apr 6, 2013 - It won't even control volume through the TV (Samsung). ... Did theremote ever turn on the sound bar, or have you been controlling ... Does the sound bar or TV have sound (sound but not volume control)? ... NO, UNFORTUNATELY THE FIOS REMOTE NEVER POWERED ON/OFF THE SOUNDBAR - I HAD ...
Your remote reprogramming woes solved - Rogers RedBoard
redboard.rogers.com/.../your-remote-reprogram...
Rogers CommunicationsJun 18, 2014 - Once the TV turns off, press the SETUP button once to lock the code.... the Rogers remote to turn TV on/off but can't get the remote to control volume. ...New Samsung smart TV and I have entered all the proper codes but the ..... Doesanyone have a code for volume control of Samsung Soundbar HW-J250.
Wireless Genie remote Doesn't turn on/off the soundbar - AT&T ..
Jan 08, 2016 | Samsung HT-WS1 Speaker System
Where can I purchase a replacement remote?
There are a number of sources of replacement OEM remotes (or work alikes) that can be found by searching the internet.
Aug 22, 2015 | JBL Cinema SB100
The soundbar picks up my neighbors music. This seems to happen in the middle of the night when the unit is actually off. Can I change the bluetooth pairing password or any other solution
That's pretty weird all I can suggest is unplugging the speaker from its reciever. Whether it be a TV etc. another suggestion is to look up this sound bar and see if it's passive or active.
Apr 03, 2015 | JBL Cinema SB200 60-Watt Soundbar with...
How do i set my home theatre as the default speakers on my viera led/lcd tv. When i turn off the tv and my JBL SB350 soundbar it resumes to tv speakers when i turn it on again?
Page 104 of the manual. It's through the Viera link settings. I have a similar TV. It's a little convoluted.
Through Viera link you set sound selection to Home Cinema and it mutes your TV speakers when your external speakers are on. I use that now now with a similar sound box (Zvox). It works fine. That doesn't work with the playbar...
enable hotel mode by pressing, at the same time, the down volume button on the side of your tv and the 'tv' button on the remote 3 times. A menu will pop up where you can set max volume to 0.
Jan 01, 2015 | Panasonic VIERA Televison & Video
I just purchased a new hisense 40 inch smart led television but I seem to have misplaced (thrown away) the manual. I am wanting to add a sound bar but I am unsure of what type to buy because I am unsure of...
its a smart tv it will have an optical plug in. I have a samsung sound bar and a 50" LG the samsung has a optical input on it. look on the back of the sound bar you will see two spots that have a rubber flap on it and say optical on it
Feb 26, 2013 | Televison & Video
I have a Samsung sound bar Model HW-D450 which I purchased last week along with a Smart TV and Blu Ray DVD player. I think the thing is possessed. It is not compatible with the TV remote or the Comcast...
There is usually and option in the tvs audio menu to enable only an external speaker output. On the remote for the soundbar, at the very bottom-- there are buttons to fine tune the audio-video syncing
Aug 01, 2011 | Samsung Televison & Video
Hi , i have a sony dvd-surround sound system that works fantastic! i lost my remote for it in my move.i am trying to find a replacement remote.....any idea where to buy or order one? model-hcd-sb100
Required remote for DAV-SB100 (HCD-SB100) sound system is ..
988506939... REMOTE COMMANDER (RM-SS220)
Please search over internet for price.
Thanks.
Dec 03, 2009 | Televison & Video
Samsung HT-A100 Home Cinema system plays cd only with tv on!
You need to put away the remote for your TV and use only the remote for your HT system. Your HT remote should work on your TV by default. Your Samsung HT remote should have a TV button and a DVD/Receiver button (or HT button). When using only the TV, press the TV button and then use it for just the TV and when using the HT system, press the DVD/Receiver button and then you can use the HT system.
If for some reason your TV is not set on the Samsung HT remote by default, your HT users manual should have a list of codes that you can use to program your HT remote. Hope that helps you. Gary
Mar 18, 2009 | Samsung HT-A100T Theater System
We have recently just bought a samsung htx250r home cinema. we have a 50 inch samsung plasma, the dvd player sound works using the hdmi cable but the surround sound does not work when we are watching...
Salutations ddog,
I hope this helps.
Jon
Go Ahead. Use Us.
Jul 05, 2008 | JBL SCS200.7 Home Cinema Package System
JBL Cinema SB100 Logo
239 people viewed this question
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
 Grubhead
Grubhead
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
