Question about Jeep 2001 Grand Cherokee Limited
Code p0700 whats is meaning?
The proplem the gear strat in scend shift espically in the morning
  • 1,258 Answers
This is not a tape deck
Posted on Oct 14, 2013
Whats a p0700.....
P0700 Fault Code Definition
  • Transmission Control System Malfunction
What does this mean?
The purpose of the automatic transmission is to match the engine's optimum power and torque characteristics to the driver's desired rate of acceleration and speed by auto-selecting different gear ratios or 'speeds' to power the wheels.
When the code P0700 is set in the Powertrain Computer, it means that the Powertrain Computer or PCM is seeing greater than a specified RPM difference between the rotational speed of the Input RPM Sensor and the Transmission Output RPM Sensor. This can occur during shifting or when driving at steady speeds in the same gear. It often implies that the transmission is slipping.
Symptoms
  • Check Engine Light will illuminate
  • Vehicle will not shift properly
  • Decrease in fuel economy
  • In unusual cases, there are no adverse conditions noticed by the driver
  • In some cases, there may be performance problems, such as dying when coming to a stop after driving on the freeway and/or misfire-like symptoms
Common Problems That Trigger the P0700 Code
  • Defective Shift Solenoids
  • Defective Engine Coolant Temperature Sensor
  • Defective Valve Body
  • Dirty transmission fluid that restricts the hydraulic passages
Common Misdiagnoses
  • Engine Misfire problem
  • Internal Transmission problem
  • Driveline problem
Jan 02, 2016 | Cars & Trucks
Transmission down shifting to 2 code po 700 or but it does not shift to 3rd gear anymore was resetting it 1st time lasted a month then every 2 or 3 weeks now i can"t reset it anymore no codes
P0700 Transmission Control System Malfunction OBD-II Trouble Code Technical Description Article by Dale Toalston ASE Certified Technician Transmission Control System TCS Malfunction What does that mean? Many vehicles have a control module for the automatic transmission called a transmission control module (TCM). The engine control module (ECM) communicates with the TCM to monitor the automatic transmission for faults. If the TCM detects a fault in the automatic transmission and sets a transmission related fault code, the ECM is informed of this also and sets a P0700 in the ECM memory. This illuminates the Malfunction Indicator Lamp (MIL) to let the driver know there is a problem. If this code is present and the MIL (Malfunction Indicator Lamp) is illuminated that basically means there is at least one transmission code set in the TCM's memory. P0700 is an informational code only. It doesn't point to a direct fault in the engine, only a general fault in the transmission. More diagnosis is necessary to identify what the transmission fault is. This requires a scan tool that will communicate with the transmission module. Symptoms Symptoms of a P0700 DTC may include: Malfunction Indicator Lamp (MIL) illumination The transmission may exhibit drivability problems like slipping, etc. Causes More often then not, the cause of this code is that there is a transmission problem of some kind. The TCM detected the problem and set a code. P0700 means that a fault code is stored in the TCM. However this doesn't rule out the possibility of a failed PCM or TCM (unlikely). Possible Solutions For a P0700 the only real solution is to acquire a scan tool that will communicate with the transmission control module. Extracting this code from the TCM will be the first step in repairing the fault in the transmission. If the TCM compatible scan tool will not communicate with the Transmission Control Module then that is a good indication that there may be a fault with the TCM itself. Register now to ask a question (free) Related P0700 DTC Discussions pt cruiser P0605, P0700, and P1391 What does P0605, P0700, and P1391 mean....I just put in a new catalyst on my car for smog but light engine turned back on...and I can't seem to know what is wrong ...please help me out here... 2002 Dodge Intrepid P0700 & P0841 code my code scanner come up with the codes PO700 and PO841. the 700 code i was told it was the input and output sensors.i had those changed a month and a haft a go. now they are back on and the po841 is on were is the 841 sensor located the machanic i go to tells me my transmission has to be replaced bu... ODB Codes Dodge Caravan 2005 P0700 and P0522 Hello I have a 2005 Dodge caravan and need a fix for these codes please.. P0700 and P0522 came up.. basically ths is stuck in limp mode or 2nd gear.. I am thinking I need a new Transmission Control module.. but can anyone confirm that... 2001 Honda Civic accord p0700 and p0740 Hi I went to get my Honda civic check and p0700 and p0740 codes came up the car has a lil leak But however the car is not slipping or anything. it's not showing no Transmission sign issues. I wanted to know what could possibly be the problem thanks you... 2005 Dodge Caravan P0700 and P0420 I have a 2005 Dodge Grand Caravan.The other day the check engine light came on.I stopped at auto parts store and they checked codes for me.P0700 and P0420 are the codes that came up.What do these mean and why did they show up?My van is running fine.Do I need a tuneup?Or is it something else?I am hop...
Read more at: http://www.obd-codes.com/p0700
Copyright © OBD-Codes.com
May 23, 2015 | 2006 Dodge Dakota
Why my 2001 town & country 3.8 will not shift gears?
p1784 shift up /down wire open,,,P0700 Transmission Control System Malfunction
Read more at: http://www.obd-codes.com/trouble_codes/
P0732 Gear 2 Incorrect ratio
Apr 23, 2015 | 2001 Chrysler Town & Country
What does 2005 equinox check engine codes p0700 and p0713 mean?
P0700 Transmission Control System Malfunction P0713 Transmission Fluid Temperature Sensor Circuit High Input Full list of the OBD2 DTC from P0700 to P0999
Jun 27, 2014 | Chevrolet Equinox Cars & Trucks
I have grand cherokee 2001 limited the code p0700 is apper the gear is started scend shift espically in morinig
possible causes
Shorted or open circuit within Transmission Control Module (TCM)
- Faulty Transmission Control Module (TCM)
symptoms
- Engine Light ON (or Service Engine Soon Warning Light)
- Driveability problems
- Transmission shifting problems
p0700 description
The transaxle Control Module (TCM) monitors the malfunction of sensors and actuators relating to transaxle control. When the TCM detects a malfunction with the control, a signal is send to the Engine Control Module (ECM) to trigger the Engine Light or Service Engine Soon light. The ECM stores the P0700 code and it means the TCM detected a malfunction with the transaxle controls.
Read more: http://engine-codes.com/p0700_jeep.html#ixzz2hihK6PVo
Oct 14, 2013 | 2001 Jeep Grand Cherokee
My van won't shift out of third gear
P0700 just tells you that there is a transmission fault code stored in the Transmission control module, you must now have that tested by the dealer.
Jun 13, 2012 | Cars & Trucks
2002 jeep liberty auto trans check engine lte on code p0700 and will not shift of=ver 2nd gear when goes into 3rd gear it feels like in neutral
p0700 is pretty much the generic code for saying the computer that controls your transmission has a problem, it may not be the actual computer its self, but one of its sensores, or a bad wire, i would recomend taking it to a reputable transmission shop
Apr 03, 2011 | 2002 Jeep Liberty
Tranny service light came on and mechanic read
It may be a shift solenoid or a speed sensor look up the codes online google your cars year, make ,and model and be sure the fluid is not too low, check the fluid level warm while the motor is running.
Oct 05, 2009 | 2002 Dodge Intrepid
2002 Dodge Caravan, Tranny would shift, DTC P0700, P0725
replace the input speed sensor to transmission and the wiring pigtail all are available at your chrysler dealer take your vehicle registration in to the parts counter so they have your vin # to get the right part and it is the front of trans by fluid linres to radiator.
Mar 08, 2009 | 2002 Dodge Caravan
Jeep 2001 Grand Cherokee Limited Logo
37 people viewed this question
Top Jeep Audio Players & Recorders Experts
Thomas Perkins
Thomas Perkins
Tom Chichester
Duff Howell
Are you a Jeep Audio Player and Recorder Expert? Answer questions, earn points and help others
