Question about Proscan PS36810 TV
Proscan PS32610 Tv keeps blowing fuses when i replace them then plug it back in
  • Deezl Sep 27, 2007
    hi is it worth fixing
    how much is a power supply $$
Posted on Sep 27, 2007
    An expert who has answered 500 questions.
  • 556 Answers
Tv keeps blowing fuses it is due to short ckt in your tv in 1 power supply. 2 horl output section it is mainly due to 1 switching transistr 2 main fil cap 3 rectifier diodes 4 print short 5 h/output tra. 6 eht transformer
  • manahar modern Sep 27, 2007
    it ia a simple thing for tech. to fix it.
    with out spending much.
The sound volume keeps going all the way up and wont stay to a normal level I have a32 inch proscan flatscreen tv
See if resetting the electronics to factory defaults cures the issue. If not, get some ear plugs till you have the main board replaced.
TV Parts Universal TV Stands DLP Chips ShopJimmy
Sep 23, 2017 | Proscan Televison & Video
Samsung dlp 5065w keeps blowing fuse
samsung motherboards are bad for going out. they are 125 dollars online, if you have the technical skills to replace them.. basically just plug and play, with LOTS of screws to take off.
Oct 06, 2012 | Samsung HLN5065W 50" DLP TV
How much to fix a proscan 42 in tv on off switch
That is not the problem, a circuit board is shorted out and it shuts off as a safety function. The cost to repair can be as high as $500.00 New TV's are very cheap I would just replace it. Proscan is not the best brand for reliability, Vizio is better and cost only slightly more at walmart
Sep 07, 2012 | Proscan 42LA45H 42 in. LCD TV
How many amps is the fuse that is located on the back of the TV near the power cord. It says T5AL/125 or 250 v. f800
Something else is going on to cause the fuse to keep blowing. Sounds like you have an issue on your power supply in the unit. Also check the outlet that your plugging it in to. Good luck!
Jun 28, 2012 | Zenith E44W46LCD 44" Rear Projection...
We had a trasnformer blow and our power went of.the tv didnt make no noise our nothing.when the power came back on the tv wont come on.
It sounds like you might get lucky and have blown the in-line fuse. By lucky, I mean, it could be worse, but you need to open the tv and check for the "white/Slow Blow" fuse that connects to the power plug of the tv.
Hope this helps :)
Mar 04, 2011 | Proscan 32LA25Q 32 in. LCD TV
Proscan lcd tv model 26lb30h blows fuse on power board
If the fuse blows again after replacing it, there's a shorted diode, bridge rectifier, capacitor or transistor in the power supply.
I repair these power supplies. If you need furhter assistance, write to
Jun 20, 2009 | Proscan 26LB30H 26 in. LCD TV
125 v 4 amp fuse keeps blowing
if you plugged a 125 volt tv in to a 220 volt outlet you more than likely fried alof of the componets in the tv. Putting a bigger fuse in there is only going to increase the risk of it catching on fire so i would not recomend that. you might replace the power supply and cross your fingers and hope that nothing else cooked when the 220 volts hit it
Mar 14, 2009 | Televison & Video
Replaced fuses & they keep blowing
there could be a shortage in any of the dc line that cause the fuse to blow up again, either overloading or chortage will cause this, try to see for any sign of other componenet failure, wires that has been bended and cripped, transistor that has been twisted or alike
Sep 04, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
ProScan Projection TV PS60690 shuts off
It won't turn back on now? Any clicking, indicator lights, etc?....accordianman
Feb 15, 2008 | Proscan PS60690 60" Rear Projection...
Proscan PS36810 TV Logo
464 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
