Question about Norpro Apple Master With Vacumn Base & Clamp, Red 865R
After using a couple times the plastic piece that is suppose to stay in the holes that holds and guides the shaft towards the loop blade for slicing and coring broke and now the shaft wobbles and will not stay level and meet up with the loop blade correctly. Very disappointed in the quality of these parts!
  • Denise McMichen
    Denise McMichen Oct 16, 2013
    Problem has been resolved!
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 47 Answers
I think you should contact the COMPANY who makes the product ato see what they will do as far as repair or replacement.
Posted on Oct 19, 2013
Dismantle philips tc722/A to repair cable rewind
Briefly, you don't remove the top section, rather you get at the cable drive / release through the cord feed hole.
To do this I use a couple of large flat bladed screwdrivers and get fairly brutal with them to lever out the plastic surround to the cable inlet. it's tough plastic so don't be afraid.
Once the plastic surround is out you can see a piece of black plastic and white plastic. The black should fit in the socket on the end of the white. That's it, just push the white plastic down and the black seats the socket. To test, press the release mechanism and you should see how the black pulls the white drum release back toward the rear of the machine.
once you have done it once it takes about 5 minutes.
Aug 25, 2014 | Vacuums
Tip
Change the belt
You need a phillips screwdriver with a good point because the screws are small. Dirt is goning to fall out,so be ready.---O.K.-- I usually sit on a folding chair outside with the vac upside-down on my lap & the handle between my legs.The screws you must remove are located in recessed holes around the brushes & back towards the wheels.These hold on the base plate.Take this off & the drive shaft should be visible.The beater bar (brushes) should slide straight out towards you. (You may want to look for clogs & generally clean this area now.) Loop the new belt over the end of the beater bar nearest the drive shaft & line it up with the gap in the brissles,then slide the beater bar back in place.Now's the hard part--Hold the beater bar in & pull the belt straight back over the drive shaft--Make sure it's on all the way & lined up straight with no kinks or twists. Replace the baseplate (Don't over tighten the screws or they will strip out & not hold) &you're done.
on Sep 26, 2011 | Bissell Pet Hair Eraser Bagless Vacuum
The belt on my used Eureka Boss 5857 upright slips off the end of the motor shaft every time the vacuum is used. When I turn the brush roll slowly by hand, the belt walks toward the end of the shaft. It...
The brush roller could be worn and in need of replacement. Some Eureka uprights have a wire guide that prevents the belt from slipping off the motor shaft.
Apr 02, 2011 | Eureka 5856BVZ Boss Bagless Upright...
NEED TO CHANGE A BELT
First you need to remove the metal cover to expose the brush roll assembly. Push up the plastic cover connected to the foot pedal to expose the motor shaft. Remove the brush roll assembly and simply hook the belt on the motor shaft first then pull back the brush roll and push the brush roll back to the slot. There's a small piece of plastic on the left hand side of the brush roll. This piece would go in after the brush is set in the slot. Finally, replace the metal cover.
Jun 23, 2010 | Sharp Twin Energy EC-12TWT4 Bagged Upright...
How do you replace the pre filter catch on a dc07 please
The pre filter retaining clip is easy to fit, but hard to get the old one out. This is the easy way to do it:-
Turn the machine over, where the bottom of the clip should be is a plate blocking access, it is held in place by a torex headed screw. DO NOT remove this. Instead drill about an 8mm hole through the plastic plate, roughly in the middle level with the large 'A'. This will give you access to the bottom of the clip. Put a flat blade scewdriver through your new access hole and push out the broken clip. It should spring out with a couple of knocks with the palm of your hand. Turn the machine upright and push in the new clip. The hole is not seen and as long as it is a neat job, does not affect the strength of the plate.
Cheers Malc.
Jan 22, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Replace Kirby legend II fan (impeller blade)
In order to replace the fan you will buy a 2 or three piece lexan fan kit containing the fan a spacer and shaft.
You must remove the carpet head and then looking from the back of the machine you will find a series of philips screws on the outer edge of the fan housing facing towards the front, several of which may be partly covered by the motor housing. You will remove the forward facing screws to allow the housing to separate and reveal the fan.
If you are lucky there will be a sideways hole through the impeller shaft allowing you to slip a nail through to help twist the saft to unscrew it while holding the fan .
The shaft will turn off revealing a threaded motor shaft with spacers which the broken fan will slide off revealing a second spacer at the back . Be sure to replace these spacers in the same order when re-assembling the unit. Secure the shaft hand tight. Post back to advise if you need further help
Oct 07, 2009 | Kirby G4 Bagged Upright Vacuum
Brushes will not spin -- broken part
Did deeper, I finally just fixed mine today, I thought the same thing about it not wanting to come apart, but try one more time, and when your almost done, look underneath there is a long plastic piece with two screws almost side by side towards the front, take them out, remove the two rubber hoses on the top side and remove the turbine, opens real easy and clean it out, then wala it' work again...
Oct 16, 2008 | Hoover F7222-900 SteamVac Upright Vacuum
1957 Sunbeam Twin-Blade electric lawn mower shaft bushing
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=654762
Generic problem for all Vacuums
1957 Sunbeam Twin-Blade electric lawn mower shaft...
Posted by mower man on Jun 08, 2008
I have a late 50's series Sunbeam twin-blade electric lawn mower that I use regularly. The shaft bushing(s) on the left blade has worn out, and there's too much play for me to run it w/o ruining the machine.
It appears that the belt-run cog inside the housing is the part that is supposed to come off of the shaft to get to the bushings, but instead of a cotter pin or other fastener holding the cog in place, it looks like a rolled metal pin that may have been pressed in place.
How do I replace the shaft bushings so I can keep using this great vintage appliance!? I found a website that supplies parts for this model year, but no schematics or user manuals. Thanks!
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. This website is for vacuums and you would need to contact a local lawn mower shop in the yellow pages, they are amazing about the way they can fix old lawnmowers.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 08, 2008 | Vacuums
Norpro Apple Master With Vacumn Base & Clamp, Red 865R Logo
Top Norpro Vacuums Experts
Are you a Norpro Vacuum Expert? Answer questions, earn points and help others
