Question about Nikon D3100 Digital Camera
Buttons not working pressing lens
I've been using my D3100 problem free for over a year now, but all of the sudden the buttons next to the view screen are all frozen, and I can't use them. While taking pictures I can't review, access my menu or anything else. I love this camera and don't have money to replace it! How do I fix it?
    Scholar:
  • Nikon Expert
  • 111 Answers
The very first thing I would do is turn off the camera and take out the battery. While the battery is out, go ahead and recharge it. This may not be the issue, but it forces you to keep the battery out of the camera for an hour. After an hour replace the battery back into the camera and turn it on. See that the battery indicator is showing that you have a full charge. Check to see if the controls are working...Let me know.
Posted on Oct 16, 2013
  • 3 Answers
SOURCE: black screen when in picture mode cant take pictures
PER007 in solution #3 is correct.
  • Follow the URL: http://www.nikonusa.com/email_images/nikonusa/service_advisory/launch_all.html
  • Fill out the form
  • Mail in your camera if it's listed
  • Receive your working unit free of charge
I had the same problem with my CoolPix5400 and this resolved the issue.
Posted on Dec 23, 2007
  • 4 Answers
SOURCE: My camera will not take a picture unless lock button is held
Had this problem two weeks ago. On the road to recovery, changing the purpose of the function button seems to have helped me - <Menu>, <Set-up1>, <Controls>, <Func.> Change chosen option away from the top one (User Setting). I found the third one down with the flash symbol least confusing. Then <Set> and <Menu> button to escape from the menus.
Having done all this the camera will take pictures again without pressing the lock button. However, I'm not convinced the func. button works as described in the manual. Hope this helps?
Posted on Feb 10, 2008
SOURCE: D50 won't take a picture!
I was having the same problem.. And since I could not afford to take it to the shop, I tried everything I could think of...
Then I fixed it!!
It seems that the slide door behind the shutter was stuck for some reason... If you remove the lens.. (make sure the camera is in manual mode)... snap a shot so the shutter is up.. then gently slide the panel in the back down....
Once I did that.. the camera was working again.... Hope this easy solution works for you guys....
Posted on Feb 25, 2008
MarkDay
  • 111 Answers
SOURCE: lens error nikon coolpix 4300
This error occurs if camera is turned on before lens cap is removed. If you are removing the lens cap before turning the camera on and still getting this message, camera should be serviced by a qualified technician.
Posted on May 17, 2008
  • 51 Answers
SOURCE: r09 shows up when I try to take a picture. Cannot access preview screen. Camera seems frozen.
This means Bent lens lever. Gently straighten it or get it replaced.
Posted on Mar 11, 2010
D3100 DOESN'T RECONIZE NEW AF-S 50MM 1.8G LENS
There are a series of small brass "buttons" on the outside bottom of the lens where contact is established. If a new lens, there may be some dirt or grease on them preventing contack. Wipe lens and camera buttons carefully with a lent free cloth and retry. Then it is time to go back to the seller.
Mar 31, 2014 | Nikon 50mm f/1.8 AF Nikkor Lens
My Nikon d3100 only takes black photo's when the lens finder is working but the lcd is showing a black screen but still has icons so what is wrong?
sounds very much like a CCD unit failure. This will require another trip back for repairs and now that it is out of warranty it is going to cost plenty.
Jan 24, 2013 | Nikon D3100 Digital Camera
Nikon d3100 taking blank images
The problem could be the imaging sensor in the lens housing, this will require a camera technician to find the extent of repair that is needed.
Apr 10, 2012 | Nikon D3100 Digital Camera
Dropped my Nikon d3100 now pictures are coming out black is that because there is damage to the lens or the camera itself? Can it be fixed?
Yes and probably.
There apparently is damage to either the lens or the camera, most likely the camera. Though without being able to see any pictures damage to the lens is also possible.
If you can't see the menu when you press the MENU button then the damage may be restricted to the LCD screen. If the photos are black when viewed on a computer then the damage may involve the sensor. Without having an authorized Nikon repair shop take a look at it, it's impossible to know just what is damaged. And without knowing that, it's impossible to tell whether it can be fixed, and how much it would cost.
Apr 02, 2012 | Nikon D3100 Digital Camera
Autofocus Lens for Nikon 70-300 1:4-5.6 AF25-166-4553 is mountable on a D3100?
You didn't specify the make of the lens. Assuming the lens has a Nikon mount then yes, it will mount on a D3100. The big question is whether it will autofocus on the D3100. The D3100 does not have an autofocus motor, relying on the lens to have one. Not all lenses do. Nikon designates lenses with an autofocus motor as AF-S. Other manufacturers use different designations.
If you need further assistance, feel free to reply to this post and give the make of the lens.
Mar 13, 2012 | Nikon D3100 Digital Camera
D3100 is showing a blurred image on the screen and sometimes get better with a little pressure. Could you help me?
Dear Robert,
RELAX. Take a deep breadth. Your D3100 is working perfectly. I'm a proud owner of this little genius of a DSLR myself.
What you've stated as a problem, is in-fact the D3100's auto-focus at work.
When the shutter button is pressed half-way, it focuses the subject. When it is pressed the full way, it snaps the pic. Simple.
So, you should be happy, that your camera is working fine.
Have fun, save your memories, and this camera will go a long way.
Gimme a thumbs up too please ;-)
Rebel K
Sep 11, 2011 | Nikon D3100 Digital Camera
I have just bought a Nikon D3100 but haven't taken a photo yet as I can't get rid of the info display. i either have info display or a black screen.
Hi, With DSLR's you're supposed to look through the view finder to take a picture however if you'd like to use live view on the LCD you need to turn live view on. If you look on the back of your camera there's a toggle around the red record button, you switch it and it'll turn live view on. If you need anymore help feel free to contact me and I can give you a hand =)
May 15, 2011 | Nikon D3100 Digital Camera
My D3100 will not autofocus or take pictures even if the lens is set to Auto Focus. If the lens is set to Manual, all works well. How do I get auto focus to work again
Go to your settings when your in shooting-mode (Press the 'i' button on the bottom left).
There, change your focus mode from MF to AF-S or AF-C or AF-A.
Should work.
Feb 05, 2011 | Nikon D3100 Digital Camera
Hi I just bought Nikon D3100 and I was just taking snaps and playing around with the buttons on it and all of a sudden my camera would not autofocus while taking pics! How do I get it to autofocus again?
If it's not autofocusing at all, then you've probably turned it to manual. On this camera, the autofocus is in the lens (so take care if you buy extra lenses for it!) so the auto/manual switch will be on the lens itself. Exactly what it looks like depends on which lens you have.
Jan 21, 2011 | Nikon D3100 Digital Camera
Video screen won't work
If you are talking about viewing the shot you just took, press the "info" button on the top of the camera (next to the shutter button), that will turn the LCD on and off.
Oct 23, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Nikon D3100 Digital Camera Logo
19 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
