Question about Frigidaire 12 cu. ft. / 340 liter Upright Freezer FFU12C2A
Need Seal replaced - Frigidaire 12 cu. ft. / 340 liter Upright Freezer FFU12C2A
    New Friend:
  • 31 Answers
Carolyn,
If this is a commercial freezer we offer a custom made gasket option. It's a simple process at coolergaskets.com
Step 1: visit our custom made gaskets page HERE and identify the gasket profile material that best matches your existing gaskets.
Note: If you have a hard time with this we offer a $1 gasket sample ring.
Step 2: Input the outside edge dimensions you need your gasket to be (length and width) and how many sides it has (3 sided gaskets are most common for walk-in coolers/freezers, You will want precise measurements. Here's our " How to measure your gasket" video.
Step 3: Select the quantity you want and add that gasket to your cart where you will be able to proceed to check out there. Then relax because your gasket is in good hands!
Posted on Dec 13, 2013
My upright freezer get icy all the time.
Check the rubber seal around the door edge is correctly fitted.
If you need to adjust the hinges and level your freezer
Clean the seal and then smear a small quantity of vasaline over the seal.
If it keeps icing, you may have to replace the seal
Hope it helps
Feb 03, 2016 | Freezers
INSTRUCTIONS on Using Vaseline and hairdryer heat to help create a better seal on Kenmore upright manual defrost Freezer gasket??
cleaning the gasket first is a must . warm soapy water .then check the seal gasket with a magnet .before greasing it with vaseline,unless this unit is OLDer than I am it is a magnetic seal but they do split and need replacing .
Oct 17, 2015 | Kenmore Freezers
My freezer had some frost buildup around the top right corner. Replaced door seal and now it's worse than ever. Any suggestions?
If the seal is working now you probably just need to defrost it one good time. Having the door open to work on it would allow a lot of moisture to get in which leads to the frost. If you get rid of it and dry it out it shouldn't be a problem if seal is good now.
Sep 24, 2015 | Frost Freezers
HOW DO I REPACE D00R SEAL
To replace your seal you'll have to remove the screws around the perimeter of the door's inner panel. Once all the screws are off separate the inner panel from the old seal and peel the seal away. It should peel away easily- if not use a Putty Knife to remove it.
Now take your new seal and "soften" it up a little by placing it in hot water for 10 minutes or so. It'll make it easier to place back in the correct position around the door since the seal was probably all twisted up and sharply folded doing shipping/storage.
Now simply lay it back in the same position the old seal was making sure there are no folds, creases or cuts in the seal. It must lay flat or it will leak all over again. Note: there is a sealant that you may want to get that's specially made for these seals to guaranty the seal gaps are filled and the seal stays in place. I use "Kitchen and Tub" Caulk when I don't have any refrigerator caulk available.
Now reassemble the door inner panel, your new seal, and the outer door all together with the screws you previously removed and you're all done.
If you need more info an excellent source is "Appliance Parts Pro". http://www.appliancepartspros.com/parts-for-frigidaire-ffu14k0dw0.html
Click on your Seal (item #1) and see the comments below that other customers asked.
Hope this helps.
Jun 27, 2014 | Frigidaire 14.1 cu. ft. Upright Freezer...
How can I replace the seal for the lid?
no need to replace unless damaged. You should be able to pull the seal off the door and place it in the dishwasher or use the solution described below in a sink to clean it. If removal is impracticable then the recommended cleaner (on the door) is a spoonful of regular dish washing liquid + 1/4 C of Lysol (the real stuff- brown smells horrible) and a quart of very warn water....add to this about 1/8 C of household bleach..clean with a sponge/ rag and rinse. This will clean and totally disinfect the door/ seal. Also, remember that unless you have a true allergy to mold there is no proof that it will harm you, its around us every day. Ever taken a walk in the woods at daybreak or sunset- look at the specs flying around- they're mold at max!
Dec 29, 2012 | Magic Chef 7 cu. ft. / 198 liter Chest...
Door does not seal tight
Clean the seal on the metel and the seal real good with some steel wool or a good stiff scrub brush. If the magnates in the seal are pulled away for te metel to far you can take a blow dryer on high while pulling firmly on the bad spots and letting the dryer reform them. This takes a little time but may fix it until your ready to replace the entire seal outfit. Also for good measure just because>>>>>
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Jan 27, 2010 | Kenmore 20.6 cu. ft. Upright Freezer 24092
Kenmore commercial upright freezer not sealing well - thawing
If the door seal does not seal completely, replace it. This is very important for freezers.
Contact Rick at Restaurant Parts and More.
\1-888-814-1110. He can most likely get what you need. Just have model and serial numbers and he'll do the rest.
Home Depot and Lowes is a definite no.
Apr 04, 2009 | True 23 cu. ft. / 651 liter Commercial...
How to replace the door seal on a frigidare upright freezer
most fridge door seals are attached to the door by screws. If you flap the seal up from the bottom you should see some screws. if you go to the site below it gives your guidance on replacing the seals on fridges, as all fridge seals are pretty generic you should find it useful
http://www.wikihow.com/Replace-a-Refrigerator-Door-Seal
I hope this helps
Dec 08, 2008 | Frigidaire 14.1 cu. ft. Upright Freezer...
How to find and replace a freeezer door seal
on many models, it is not possible to fit a replace,ent door seal - they are foamed into the door and to replace the seal means replacing the whole door
Aug 27, 2008 | Freezers
Frigidaire 12 cu. ft. / 340 liter Upright Freezer FFU12C2A Logo
78 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
