Question about GE (PSS26MSRSS) Side by Side Refrigerator
How to unclog drain tube on model psw26psta - GE (PSS26MSRSS) Side by Side Refrigerator
  • GE Master
  • 842 Answers
I use compressed air, you can use canned air but might be difficult to force all the air down the tube. I have also used a steam gun which works great.
For the canned air you would need to close off the inlet side with a rag or something to allow all the air pressure down the tube to clear that tube out.
GE has a "S" shaped tube behind the unit by the compressor, this can get clogged from time to time. I would look there as well.
I hope this helps you, good luck.
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Posted on Oct 15, 2013
2 Suggested Answers
SOURCE: how do I unclog a grommet drain tube on, a general
turn off ref. defrost and remove all ice from drain area. you might have to remove rear panel. chip as much ice from drain hole then microwave water to near boil and use a little at a time till water flows freely.
Show a picture of the drain tube so I can access it with the back of the refrigerator off
There should be a tube, that leads to a defrost pan, under the box. Follow it up to the freezer. If the freezer is still freezing, you may never get it unclogged.
Sep 07, 2014 | Refrigerators
How to repair;kenmore model number596.69952012 frozen drain tube; removing parts and unclog
You will most likely have to remove the rear panel in the freezer and pour hot water in the drain trough until the drain clears up and the water drains down the drain tube.
Aug 16, 2014 | Refrigerators
Why does my air conditioner leak water on passager side floor
The Evaporator box has a Drain tube, this is blocked and not letting the water drain off ,hence the build up of water in the box which will overflow into the passengers side .
The drain tube needs to be unblocked to let the water drain off.
Jun 12, 2014 | 2001 Mitsubishi Montero
Need help to unclog a drain on a GE Profile Bottom Freezer Refrigerator Model PFSS6PKW/PFSF6PKW. Specifically, where does the drain end? Behind the freezer & how to access it? Also found eroding t
You should be able to see where the drain tube comes out over the drain pan. Get some thin wire and run it down the tube and when it comes out in the drain pain, tie something onto it like a small piece of cloth and pull it back up through the drain tube to swab it out. The tape is no big issue, if you want to do something about the rust, there is a product that autoparts stores sell that turns rust into a hard, rigid metal. Or you can use a blow drier to make sure it is dried out and then spray rubber under coating on it.
Nov 18, 2013 | GE Refrigerators
How do I unclog a grommet drain tube on, a general electric psw26psta refrigerator
Oct 14, 2013 | GE Profile PSW26P Stainless Steel Side by...
Top freezer whirlpool refrigerator condensation water leaking/dripping
there is a drain in the freezer that sum time get Clogged the drain is located below the evaporator coil you have to remove the evaporator cover to unclog it make sure the refrigerator is unplugged before trying this you can't unclog the freezer drain without removing parts
Sep 10, 2013 | Refrigerators
How do I unclog defrost drain on a model TBX18W?
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Sep 26, 2009 | Refrigerators
Frigidaire FRT18IL6D
Hi thanks for your question. to unclog. pull fridge away from the wall. remove back cover , clean all coils. let fridge thaw for at least 24 hrs. get small plastic hose to push up the drain tube from the back. blow up yhr drain tube to clear the tube. thanks the appliance doc. please rte my answer, thanks.
Oct 12, 2008 | Frigidaire FRT18B4A Top Freezer...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
53 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
